Home » Archived » BIRT » Table styles help needed
Table styles help needed [message #265154] Mon, 28 January 2008 18:14 Go to next message
I need help with the following (I am using BIRT 2.1):
- How to have "grid" type tables i.e. by default, if we have tables in our
report, they dont have the "grid lines" on the columns and rows. Eg the
table in Microsoft Word. I tried defining the style for the column with
the borders but it doesnt work. My table has a border though
- How to specify the margins/padding between the columns. I have two
columns (column A is right aligned and co B is left aligned. As a result,
these two columns appear close together. I want to put some space between
them
Thanks a lot!
Re: Table styles help needed [message #265189 is a reply to message #265154] Tue, 29 January 2008 04:01 Go to previous message
The first problem is caused by wrong target element selection. You should
select Cell element rather than Data element, which can be easily done
through the outline view. In the same way, you can set the margin and
padding style in Box item of the style editor.
Re: Table styles help needed [message #265880 is a reply to message #265154] Tue, 29 January 2008 04:01 Go to previous message
Re: Table styles help needed [message #266597 is a reply to message #265154] Tue, 29 January 2008 04:01 Go to previous message
Re: Table styles help needed [message #267327 is a reply to message #265154] Tue, 29 January 2008 04:01 Go to previous message
Re: Table styles help needed [message #268030 is a reply to message #265154] Tue, 29 January 2008 04:01 Go to previous message
Re: Table styles help needed [message #268731 is a reply to message #265154] Tue, 29 January 2008 04:01 Go to previous message
Re: Table styles help needed [message #269443 is a reply to message #265154] Tue, 29 January 2008 04:01 Go to previous message
Re: Table styles help needed [message #270154 is a reply to message #265154] Tue, 29 January 2008 04:01 Go to previous message
Re: Table styles help needed [message #270878 is a reply to message #265154] Tue, 29 January 2008 04:01 Go to previous message
Re: Table styles help needed [message #271602 is a reply to message #265154] Tue, 29 January 2008 04:01 Go to previous message
Re: Table styles help needed [message #272332 is a reply to message #265154] Tue, 29 January 2008 04:01 Go to previous message
Re: Table styles help needed [message #272861 is a reply to message #265154] Tue, 29 January 2008 04:01 Go to previous message
Re: Table styles help needed [message #273137 is a reply to message #265154] Tue, 29 January 2008 04:01 Go to previous message
Re: Table styles help needed [message #273601 is a reply to message #265154] Tue, 29 January 2008 04:01 Go to previous message
Re: Table styles help needed [message #274014 is a reply to message #265154] Tue, 29 January 2008 04:01 Go to previous message
Re: Table styles help needed [message #274396 is a reply to message #265154] Tue, 29 January 2008 04:01 Go to previous message
Re: Table styles help needed [message #274785 is a reply to message #265154] Tue, 29 January 2008 04:01 Go to previous message
Re: Table styles help needed [message #275156 is a reply to message #265154] Tue, 29 January 2008 04:01 Go to previous message
Re: Table styles help needed [message #275567 is a reply to message #265154] Tue, 29 January 2008 04:01 Go to previous message
Re: Table styles help needed [message #275963 is a reply to message #265154] Tue, 29 January 2008 04:01 Go to previous message
Re: Table styles help needed [message #276353 is a reply to message #265154] Tue, 29 January 2008 04:01 Go to previous message
Re: Table styles help needed [message #276758 is a reply to message #265154] Tue, 29 January 2008 04:01 Go to previous message
Re: Table styles help needed [message #277161 is a reply to message #265154] Tue, 29 January 2008 04:01 Go to previous message
Re: Table styles help needed [message #277535 is a reply to message #265154] Tue, 29 January 2008 04:01 Go to previous message
Re: Table styles help needed [message #277953 is a reply to message #265154] Tue, 29 January 2008 04:01 Go to previous message
Re: Table styles help needed [message #278326 is a reply to message #265154] Tue, 29 January 2008 04:01 Go to previous message
Re: Table styles help needed [message #278716 is a reply to message #265154] Tue, 29 January 2008 04:01 Go to previous message
Re: Table styles help needed [message #279126 is a reply to message #265154] Tue, 29 January 2008 04:01 Go to previous message
Re: Table styles help needed [message #279543 is a reply to message #265154] Tue, 29 January 2008 04:01 Go to previous message
Re: Table styles help needed [message #279913 is a reply to message #265154] Tue, 29 January 2008 04:01 Go to previous message
Re: Table styles help needed [message #280307 is a reply to message #265154] Tue, 29 January 2008 04:01 Go to previous message
Re: Table styles help needed [message #280704 is a reply to message #265154] Tue, 29 January 2008 04:01 Go to previous message
Re: Table styles help needed [message #281103 is a reply to message #265154] Tue, 29 January 2008 04:01 Go to previous message
Re: Table styles help needed [message #281496 is a reply to message #265154] Tue, 29 January 2008 04:01 Go to previous message
Re: Table styles help needed [message #281889 is a reply to message #265154] Tue, 29 January 2008 04:01 Go to previous message
Re: Table styles help needed [message #282274 is a reply to message #265154] Tue, 29 January 2008 04:01 Go to previous message
Re: Table styles help needed [message #282677 is a reply to message #265154] Tue, 29 January 2008 04:01 Go to previous message
Re: Table styles help needed [message #283077 is a reply to message #265154] Tue, 29 January 2008 04:01 Go to previous message
Re: Table styles help needed [message #283467 is a reply to message #265154] Tue, 29 January 2008 04:01 Go to previous message
Re: Table styles help needed [message #283859 is a reply to message #265154] Tue, 29 January 2008 04:01 Go to previous message
Previous Topic:Set a XML DataSource Programmatically
Next Topic:Table styles help needed
Current Time: Fri Jul 18 23:17:20 EDT 2025
Powered by FUDForum. Page generated in 0.14758 seconds
