Home » Eclipse Projects » Eclipse Platform » Eclipse 3.0 does not start
Eclipse 3.0 does not start [message #264862] Sat, 31 July 2004 08:19
Originally posted by: joerg_diederich.freenet.de
on my new SuSE Linux 9.1 I cannot start Eclipse 3.0. Whenever I try it, I
get the error message "An error has occurred. See the logfile ...". The
contents of this logfile is:
<--- snipp --->
!SESSION Jul 31, 2004 14:12:16.992
eclipse.buildId=I200406251208
java.version=1.4.2_03
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=de_DE
!ENTRY org.eclipse.osgi Jul 31, 2004 14:12:16.994
!MESSAGE Error installing bundle:
reference:file:/opt/eclipse/plugins/org.eclipse.update.confi gurator_3.0.0/
!STACK 0
org.osgi.framework.BundleException: Error converting plugin at
/opt/eclipse/plugins/org.eclipse.update.configurator_3.0.0.
org.eclipse.core.runtime.adaptor.EclipseBundleData.generateM anifest(EclipseBundleData.java:222)
org.eclipse.core.runtime.adaptor.EclipseBundleData.loadManif est(EclipseBundleData.java:177)
org.eclipse.core.runtime.adaptor.EclipseBundleData.getManife st(EclipseBundleData.java:159)
org.eclipse.core.runtime.adaptor.EclipseBundleData.loadFromM anifest(EclipseBundleData.java:266)
org.eclipse.osgi.framework.internal.defaultadaptor.DefaultBu ndleData.initializeNewBundle(DefaultBundleData.java:77)
org.eclipse.osgi.framework.internal.defaultadaptor.DefaultAd aptor$1.begin(DefaultAdaptor.java:451)
org.eclipse.osgi.framework.internal.core.Framework.installWo rkerPrivileged(Framework.java:746)
org.eclipse.osgi.framework.internal.core.Framework$2.run(Fra mework.java:664)
org.eclipse.osgi.framework.internal.core.Framework.installWo rker(Framework.java:715)
org.eclipse.osgi.framework.internal.core.Framework.installBu ndle(Framework.java:659)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.i nstallBundle(BundleContextImpl.java:219)
org.eclipse.core.runtime.adaptor.EclipseStarter.installBundl es(EclipseStarter.java:800)
org.eclipse.core.runtime.adaptor.EclipseStarter.loadBasicBun dles(EclipseStarter.java:429)
org.eclipse.core.runtime.adaptor.EclipseStarter.startup(Ecli pseStarter.java:222)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:127)
at org.eclipse.core.launcher.Main.basicRun(Main.java:183)
at org.eclipse.core.launcher.Main.run(Main.java:644)
at org.eclipse.core.launcher.Main.main(Main.java:628)
Caused by:
org.eclipse.osgi.service.pluginconversion.PluginConversionEx ception: Error
parsing plugin manifest file
/opt/eclipse/plugins/org.eclipse.update.configurator_3.0.0 at <missing
argument>.
org.eclipse.core.runtime.adaptor.PluginConverterImpl.parsePl uginInfo(PluginConverterImpl.java:555)
org.eclipse.core.runtime.adaptor.PluginConverterImpl.fillPlu ginInfo(PluginConverterImpl.java:111)
org.eclipse.core.runtime.adaptor.PluginConverterImpl.convert Manifest(PluginConverterImpl.java:655)
org.eclipse.core.runtime.adaptor.EclipseBundleData.generateM anifest(EclipseBundleData.java:219)
... 22 more
Caused by: java.lang.NullPointerException
org.apache.xerces.parsers.AbstractSAXParser.parse(AbstractSA XParser.java:987)
at javax.xml.parsers.SAXParser.parse(SAXParser.java:345)
at javax.xml.parsers.SAXParser.parse(SAXParser.java:143)
org.eclipse.core.runtime.adaptor.PluginParser.parsePlugin(Pl uginParser.java:459)
org.eclipse.core.runtime.adaptor.PluginConverterImpl.parsePl uginInfo(PluginConverterImpl.java:552)
... 25 more
Root exception:
argument>.
... 25 more
!ENTRY org.eclipse.osgi Jul 31, 2004 14:12:17.252
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: No application id has been found.
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:313)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
<--- snipp --->
Any help is really appreciated.
Previous Topic:build of 3.0rc3 fails
Next Topic:PHP in eclipse
Current Time: Sun Jul 27 03:12:25 EDT 2025
Powered by FUDForum. Page generated in 0.04015 seconds
