Home » Newcomers » Newcomers » Images from web in Eclipse
Images from web in Eclipse [message #264588] Mon, 22 September 2008 10:42 Go to next message
Hello there,
Currently I'm busy playing around with eclipse and there is a litle thing
that does not work yet. I have an image. (lets say
http://www.jvw.nl/images/eclipse.jpg ) and I want to show it in a eclipse
application. I read it from the web with an input stream but the image is
not shown. There are no errors reported whatsoever.
Does anyone know how to accomplish this?
Re: Images from web in Eclipse [message #264604 is a reply to message #264588] Mon, 22 September 2008 14:01 Go to previous messageGo to next message
Can you show us what you did to show the image? i.e. show us some code :-)
Wayne
jjtb somhorst wrote:
> Hello there,
> thing that does not work yet. I have an image. (lets say
> eclipse application. I read it from the web with an input stream but the
> image is not shown. There are no errors reported whatsoever.
Re: Images from web in Eclipse [message #264652 is a reply to message #264604] Tue, 23 September 2008 05:54 Go to previous messageGo to next message
here is some code I use to create the image:
I've got an Object which generates an url string, creates an get method
for the apache httpclient and finally does the following:
InputStream in = getImage.getResponseBodyAsStream();
return this.loader.load(in)[0];
As you can see here I return the ImageData that was generated from the
InputStream. Tests with a filewriter object (plain old java) showed me
that the image that I write to the disk using this getresponsebodyasstream
was a valid image.
In the code that is using the return value I do the following:
ImageData data = this.gm.generateMap() // method wich returns the
imagedata shown above
Image img = new Image(this.map.getShell().getDisplay(),data);
this.map.setImage(img);
the this.map is a Label instance.
Even when I do a map.getShell.redraw the image is not shown.
Re: Images from web in Eclipse [message #264696 is a reply to message #264652] Wed, 24 September 2008 06:19 Go to previous message
When I set the image as background for the Label it does work now.
Previous Topic:Forced line-wrapping in Eclipse editor
Next Topic:Very slow refreshing of TableViewer
Current Time: Mon Jul 21 21:12:59 EDT 2025
Powered by FUDForum. Page generated in 0.11156 seconds
