| html report exported to word causes error.... [message #264475] |
Mon, 14 January 2008 14:22  |
Originally posted by: ukraine.believe.gmail.com
When we run an html report and export it to word on our test server (where
headless = false), it works.
But on our live server (headless = true) - it seems to export to word fine,
but when you open up the .doc file, all you see is the following error:
+ org.eclipse.birt.report.service.api.ReportServiceException: Error happened
while running the report; nested exception is:
java.lang.NoClassDefFoundError
We haven't had time yet to reboot either server to see if being in head mode
or not is 100% the problem. Does anyone know if this a documented issue -
if the server has to be in head or headless mode?
thanks in advance,
mike.
| looks like a bug [message #264502 is a reply to message #264475] |
Tue, 15 January 2008 09:02  |
i stopped tomcat on our live server, changed "headless = false" - started
tomcat and it worked fine. it shouldn't need to be that way.
"Mike S." <ukraine.believe@gmail.com> wrote in message
news:fmgcq4$67v$1@build.eclipse.org...
> fine, but when you open up the .doc file, all you see is the following
> error:
> happened while running the report; nested exception is:
> mode or not is 100% the problem. Does anyone know if this a documented
> issue - if the server has to be in head or headless mode?
> thanks in advance,
> mike.
FUDForum. Page generated in 0.03679 seconds
