| disable content assist auto cycling [message #264227] |
Sat, 13 September 2008 17:22  |
I have couple of simple questions (I hope)
1. When scrolling content assist variants (with Up/Down keys), if you
reach bottom of the list and press down one more time, you jump to the top
automatically. The same in reverse direction. How can I switch this off?
If the option is the last - stay on it, no matter how may times I press
Down. The same with first item and pressing Up.
Also I couldn't find a way to select the first and the last variants of
content assist, all combinations Home/Page Up+Alt/Ctrl/Shift do something
else.
This is very irritating. when searching for appropriate item in a big
list, you have to explicitly note whether the list ended, or find yourself
cycling the same list for 2 or 3 times. To workaround this feature you
have to remember and type couple of characters to dramatically shorten the
list, then press Down several times.
Also I noticed that when using PgUp/PgDn to scroll content assist
variants, it stays at the bottom, doesn't jump to the top.
2. When content assist variant suits me, the only choice I have is to
press Enter so it goes into my code. Can I configure so selected content
assist variant goes into my code on any character I type (not requiring to
press enter explicitly), in most cases it would be "." (after I found
appropriate class or object), "(" (... method name), or " " (... variable
name)
This is uncomfortable because I have to press "Enter" instead of
continuing to type code.
I can fairly say I'm a former .net developer, so I'm a bit addicted to
their keyschemes
| Re: disable content assist auto cycling [message #264272 is a reply to message #264227] |
Sun, 14 September 2008 10:28   |
> top automatically. The same in reverse direction. How can I switch
> this off?
You can't.
> press Down. The same with first item and pressing Up. Also I couldn't
> find a way to select the first and the last variants of content
> assist, all combinations Home/Page Up+Alt/Ctrl/Shift do something else.
Home and End work for me.
> yourself cycling the same list for 2 or 3 times. To workaround this
> feature you have to remember and type couple of characters to
> dramatically shorten the list, then press Down several times. Also I
> noticed that when using PgUp/PgDn to scroll content assist variants,
> content assist variant goes into my code on any character I type (not
> requiring to press enter explicitly), in most cases it would be "."
> (after I found appropriate class or object), "(" (... method name), or
> " " (... variable name)
You can accept a proposal with '.' and it then also opens content
assist for you again after the '.'.
Dani
> their keyschemes
| Re: disable content assist auto cycling [message #264315 is a reply to message #264312] |
Mon, 15 September 2008 10:19  |
Originally posted by: 4cs6fcg02.sneakemail.com
Wojtek schreef:
> Sergei Karimov wrote :
>> if you reach bottom of the list and press down one more time, you
>> jump to the top automatically. The same in reverse direction.
> Actually all lists seem to do the same. For instance a Search will also
> restart the found hits.
> This is annoying in that half the time I am doing this without looking
> at the scroll bar, and I miss when the elevator jumps to the top.
> As another poster pointed out it cannot be altered. There must be an
> open bug for it somewhere. Maybe some bug guru can find it? I always
> seem to miss to open bugs, so I open another one, which is then marked
> as a dup.
A good thing to do would be to give some clearly visible warning that
the end has been reached, just like Firefox does if you use the search
mechanism with Ctrl-f.
H.
Hendrik Maryns
http://tcl.sfs.uni-tuebingen.de/~hendrik/
Ask smart questions, get good answers:
http://www.catb.org/~esr/faqs/smart-questions.html
FUDForum. Page generated in 0.12255 seconds
