Home » Newcomers » Newcomers » Problem launch Glassfish 2ur2 on Eclipse 3.4
Problem launch Glassfish 2ur2 on Eclipse 3.4 [message #263602] Sat, 23 August 2008 03:41
Originally posted by: alekirk2004.yahoo.it
I have see
Eclipse 3.3 and GlassFish Java EE 5 integration
https://glassfishplugins.dev.java.net/eclipse33/index.html
GlassFish on Eclipse Ganymede
http://blogs.sun.com/arungupta/entry/glassfish_on_eclipse_ga nymede
When i trie to launch a web project on Glassfish i obtain this error:
Publish failed using Ant publisher
Could not replace with temp file /tmp/tmp55985.LIST.
I have tried to modify eclipse.ini but eclipse does not seem to read -D
style command line arguments. I added the -Djava line to the eclipse.ini
file and all sorts of werid errors stopped.
I have the same problem and i don't understand how i can resolve it.
Some help?
Note:
The same web project is ok using tomcat 6.
While if i use netbeans it's ok on tomcat 6 and glassfish 2ur2.
Previous Topic:How to redirect the -debug log to a file ?
Next Topic:GMF
Current Time: Mon Sep 01 05:15:25 EDT 2025
Powered by FUDForum. Page generated in 0.04978 seconds
