Home » Newcomers » Newcomers » moving projects around
moving projects around [message #263579] Fri, 22 August 2008 16:47 Go to next message
Originally posted by: me.somewhere.com
I've had this problem before and it drives me batshit crazy. Can't
remember how I solved it either.
New computer with new eclipse install. I copied existing projects from old
computer and paste then into new computer. Then I set the workspace to
base of those folders, but when I launch eclipse it doesn't show the
projects.
If I try to import the projects it says "xxx overlaps the current
workspace".
Why must this be so complicated?
thanks.
c
Re: moving projects around [message #263588 is a reply to message #263579] Fri, 22 August 2008 17:04 Go to previous messageGo to next message
Originally posted by: codeslave.ca.ibm.com
To import old projects into a new workspace...
a) assume you have all the old stuff in c:\workspace1
b) launch Eclipse. Point it at a new workspace, say, c:\workspace2
c) import > existing projects
d) point Eclipse at the old projects, and optionally have it copy them
over into the new workspace; you can also just point at them if you
don't mind having projects in root workspaces (or more)
e) if you copied them over, you can safely delete the old ones in
workspace1, as they'll also now exist in workspace2. If you're just
linking, then DO NOT delete the old projects in workspace1!
Why is this complicated? Because Eclipse retains metadata and histories
of your projects, so you can't just copy them into a workspace and have
it "find" them; you can also have folders in your workspace which are
not projects, or are closed/deleted projects (but which still physically
exist, even if Eclipse can't see them or has been told NOT to see them).
Or, simply put: *it's more complicated because it's more powerful.*
Personally, I'd like to see a "reopen project in current physical
workspace not listed in active workspace" option so that you can
reimport an existing project you might have
project-from-workspace-deleted (but not bits-from-the-disc-deleted) w/o
having to go thru this song-and-dance.
However, it doesn't bother me enough to file a bug report. Maybe you'd
like to do so?
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=platform
Nick
> old computer and paste then into new computer. Then I set the workspace
> to base of those folders, but when I launch eclipse it doesn't show the
> projects.
> workspace".
> thanks.
> c
Nick Boldt :: Release Engineer, IBM Toronto Lab
Eclipse Modeling :: http://www.eclipse.org/modeling
http://wiki.eclipse.org/index.php/User:Nickb
Re: moving projects around [message #263591 is a reply to message #263579] Fri, 22 August 2008 17:36 Go to previous messageGo to next message
> projects.
> workspace".
> thanks.
> c
I had a similar problem and the following worked for me.
Set the workspace to a empty folder %newWorkspace then import the
existing project.
Michael
Re: moving projects around [message #263594 is a reply to message #263588] Fri, 22 August 2008 18:05 Go to previous messageGo to next message
Thanks Nick.
If I copy the project folders out of the new workspace and import them in,
it does indeed work. However, I don't see an option to have the src copied
into new workspace. The project folders are staying in their old locations
and my new workspace stays empty.
Could be due to my old Eclipse version, 3.1.1?
c
Re: moving projects around [message #263599 is a reply to message #263594] Fri, 22 August 2008 19:24 Go to previous messageGo to next message
--------------070207000206010202080902
c wrote:
> Thanks Nick.
> in, it does indeed work. However, I don't see an option to have the src
> copied into new workspace. The project folders are staying in their old
> locations and my new workspace stays empty.
> c
There's a checkbox on the first page of the import wizard for copying
the projects into the workspace. I miss it and have to back up
regularly. I'm pretty sure it has been there since before 3.1.1
Steve
Content-Type: image/jpeg;
name="importcheckbox.jpg"
Content-Disposition: inline;
filename="importcheckbox.jpg"
/9j/4AAQSkZJRgABAQEASABIAAD/4QAWRXhpZgAATU0AKgAAAAgAAAAAAAD/ 2wBDAAsICAoI
BwsKCQoNDAsNERwSEQ8PESIZGhQcKSQrKigkJyctMkA3LTA9MCcnOEw5PUNF SElIKzZPVU5G
VEBHSEX/2wBDAQwNDREPESESEiFFLicuRUVFRUVFRUVFRUVFRUVFRUVFRUVF RUVFRUVFRUVF
RUVFRUVFRUVFRUVFRUVFRUVFRUX/wAARCAIrAdQDASIAAhEBAxEB/8QAGwAB AAMAAwEAAAAA
AAAAAAAAAAMEBQECBgf/xABXEAABAwICBAYNCAcGBAUEAwABAAIDBBEFEhQh MVQGE3GT0dIH
FSIyNkFRU1VhkZKyFiNSc4Gis9MzNGJjlaGjQnJ0lKSxQ4LB4SQlNUTwRWTC w1ZlhP/EABoB
AQADAQEBAAAAAAAAAAAAAAABAgMEBQb/xAA5EQEAAQIDBAgFAwQCAgMAAAAA AQIRAyFRBBIx
cRMUM0FSkbHwMjRhY5IFIoGhwdHhI/FCciRDU//aAAwDAQACEQMRAD8Awmzi R7nyMbI9xLnO
kGYuJ2kkqcVLG/8At4fcC0+DODU9fFLUVge6NhytYy+s2vrtyhVsQw58bncR Q1AAOrKxx1L6
6rasKmvo57nhRsmJXTvxKqaxg/8Abw+4F101m7we4FHS0rqqugpXExmWVsZJ brbc22KefBK1
tXUw0tNUVMcEr4zLHC4g5TYnVe3/AHXRNdETaZYRh1TF4dNNZu8HuBNNZu8H uBdDhWICWKI0
NSJJQTGziXXeB4wLa1xLhtbTzxwzUdRHLL3kb4nBz+QEa1O9RqbkpNNZu8Hu BNNZu8HuBdDh
deKg05oanjw3OY+KdmDfLa17K0/g5iceGSV0lJKyOOTI5jo3B41XLiLam+sq s14cWvMJjCqn
hEoNNZu8HuBNNZu8HuBUUWloUsvaazd4PcCaazd4PcCooloLL2ms3eD3Amms 3eD3AqKJaCy9
prN3g9wJprN3g9wKiiWgsvaazd4PcCaazd4PcCooloLL2ms3eD3Amms3eD3A qKJaCy9prN3g
9wJprN3g9wKiiWgsvaazd4PcCaazd4PcCooloLL2ms3eD3Amms3eD3AqKJaC y9prN3g9wJpr
N3g9wKiiWgsvaazd4PcCaazd4PcCooloLL2ms3eD3Amms3eD3AqKJaCy9prN 3g9wJprN3g9w
KiiWgsvaazd4PcCaazd4PcCooloLL2ms3eD3AmnM3eD3AqKWTdgsvaczd4Pc Caczd4PcCo2S
yndhNl7TmbvB7gTTmbvB7gVGyWTdgsvaczd4PcCaczd4PcCo2SybsFl7Tmbv B7gTTmbvB7gV
GyWTdgsvaczd4PcCaczd4PcCo2SybsFl7TmbvB7gViMSSxiRtLTBp2F+Vt/a Vk2W0+XLExvk
ij+Bqzry4QvRRFXF0ySDbBRc5H0qOWQxNzOp6YtvYlmV1uWx1KCWZw2KOI5m 1R/c/wD5sUZx
nK04dOrZZhla+Jsho6NgcLgSyxMNuRzgUOGVY2wYb/moOuvVA0tTieINr5Xx QQvkcXsFyPnL
DxHyrhtLwYqZ44GYlVGSVwY1oYRck2H9hcHW6440+UTP93R1WjX+rxlVFPSB hkpKdwkOVroi
yQE+S7SRf1Ky7BsSAF6GiYfI+aFpHKC64U2DG88B/wD7Si//AGr0VCIcQaIJ JhFO5gEJcO5c
7yHl/wDnkPNt/wCo4mzTTTRETM34/wAfV2bD+nYe0RVVVMxEWeUdhGIbph4/ /wBMHXWfU1Vf
gNUyRrRSzEZmSQPBa8X2XaS1wuNY1jVrXs6jDjR0E1RirzA83ZTwtALnuG0n 9n1/9r+P4Qi+
DUh/+6qPghWGw/quLtO0RgYlMWmJdW1fpWDgYM42HVM2mH1Lg/ioxvA6Svy5 HTNOcWsA4Etd
bWdVwbepFmdj7wKoOWX8V6LycamKcSqI4RMrUzemHi8MrxBRS0ry1mZ2dj3R h4BtbWCD5Fl1
M+IzTlobScXfv9GiNx6rtuttvAzhIP8A6Z/Xj6ykHA/hH6MPPx9ZfVVxsdde /NcecPGivaqa
NyKf6MrDiynxOkmlIbHHMx7iG2AAcCdQ/wBgvQxY7QtqKdwqHtaMYkq3fNvH zR2E6vXs2+pU
vkfwj9Fnn4usnyO4R+jP68fWVsWdlxZiZxIy+sM8ONoopmN3j/uP7tbAMQpq memp2Skympqp
u6Y4WY5hsb28vi2+pUMIxigw2hpcNbO6VoEznVccT2tpy9uUZQ5oJ8ZNh4/G oo+CXCeJ2aKg
kifYjNHVMabHUdYdddBwN4RgWGGah+/j6y5+h2WZmJxItNu+Pr/ltGJjxETF Gd5/snixmjps
N0OKpkeYMMnp2ztjkbmke4FrW3AcAANpACoCell4LPoJ5gydtYKgB7Hvzji8 thlabHUNth61
Z+R3CP0Z/Xj6yfI7hH6M/rx9ZbU07LH/ANkXvfjGt1N7aLx+z10sweKTilvf I7hH6M/rx9ZP
kdwj9Gf14+suzrWz+OPOHN0GN4ZYPFJxS3vkdwj9Gf14+snyO4R+jP68fWTr Wz+OPODoMbwy
weKTilvfI7hH6M/rx9ZPkdwj9Gf14+snWtn8cecHQY3hlg8UnFLe+R3CP0Z/ Xj6yfI7hH6M/
rx9ZOtbP4484OgxvDLB4pOKW98juEfoz+vH1k+R3CP0Z/Xj6yda2fxx5wdBj eGWDxScUt75H
cI/Rn9ePrJ8juEfoz+vH1k61s/jjzg6DG8MsDik4pb3yN4R+jDz8XWT5G8I/ Rh5+LrJ1rZ/H
HnB0GN4ZYPFJxS3vkbwj9GHn4usnyN4R+jDz8XWTrWz+OPODoMbwyweKTilv fI3hH6MPPxdZ
Pkbwj9GHn4usnWtn8cecHQY3hlg8UnFLe+RvCP0Yefi6yfI3hH6MPPxdZOtb P4484OgxvDLB
4pOKW98jeEfow8/F1k+RvCP0Yefi6yda2fxx5wdBjeGWDxScUt75G8I/Rh5+ LrJ8jeEfow8/
F1k61s/jjzg6DG8MsHik4pb3yN4R+jDz8XWT5G8I/Rh5+LrJ1rZ/HHnB0GN4 ZYPFJxS3vkbw
j9GHn4usnyN4R+jDz8XWTrWz+OPODoMbwyweKTilvfI7hH6LPPxdZcfI7hJ6 L/1EfWTrWz+O
POE9BjeGWFxScUt35HcJPRf+oj6yfI7hJ6L/ANRH1k61s/jjzg6DG8MsLik4 pbvyO4Sei/8A
UR9ZPkdwk9F/6iPrJ1rZ/HHnB0GN4ZYXFJxS3fkdwk9F/wCoj6yfI7hJ6L/1 EfWTrWz+OPOD
oMbwywuKTilu/I7hJ6L/ANRH1k+R3CT0X/qI+snWtn8cecHQY3hlhcUnFLd+ R3CT0X/qI+sn
yO4Sei/9RH1k61s/jjzg6DG8MsLilojijWMZUOLY+KjuRtHzYVz5HcJPRf8A qI+spvkpwhcB
xuCRyuAsHOqWg28Q1PCzr2nAnhXHnDTDwsWmc6ZZtdFQthBppnvfm1hw8XsV GnGbSh+5/wDz
YvQfJLHf/wCPxf5ofmLqeCPCENc2LBWRB3fZahhv7XlUp2jBiLb8fzML1YeJ M33f6Lz6qHtr
jkE07IeMkkY1zw4i4mB8QJ2AqGkjoqXEaWpkxSlyQzMkcAyW9gQTbuF2dwex +VxkqODVNPM7
v5XVRaXnykNlAv67a1weDOMnbwUpP84/85csV4URbf8A608m001z/wCP9JU+ D7s88dvFilF/
+1aeDVVAxrp668hiaDHABqkd6z5B/wDPIaruDnCZoY2kwWOjY2QS2hqGm7xs cS55OrXbXYXP
lUpwDhA4lzuC9GXHWSKpzbnkEoA+wALzf1PA61VTXh105XymY+j0v03aadmp roxaas7cI0uu
12LUmMUUvbG0dZEC6CaNupwv3hH+x/738ji/zuB0p/8Au6j4IV6A8HseO3gt R/5t/wCcsrHc
Fx2ChM1XhsVJRU+vJFM1waXEAnvi4km2sk7B4gsf0vYq8HbKcXErpnjwnOb5 OrbtuwsTZpws
KmqM4nOMoew4BVEEfA6hY+ZjXAy3BcAf0rkUnADXwMoOWX8V6Lk2ntq+c+rC j4YeyRYnDHM3
glik0U00MsFM+WOSGV0bmua0kG7SD9mxeRp+FGLYbhTYqV0Mop8DjxJ8tYZJ pJJHXzAkvGo/
y8ltSr3TPvv/AME+/f8AL6Si+fVvDzFKTD8Wm4ijdLTU1NVQjK7KBKQC13dd 0RfaLX8isYnw
zxPBqnFaSpp6aonhZA6mkia5jBxrsoEgJJ1HybbeJP8Ar+UXi1+73/l7lF4b GOGGK4HTY7DO
yjnrMOhhnilZE9kb2vcGkOaXEgg3/ta/sXXGazhEcX4PB1VSUelVcgZHDxkj XM4u44wZm5jf
Nq2bNerXF9PfctMWi/vV7tF5bh9U1lBwDrZoqp0VWxsd5qcujN87QS2xJAOv VcrAmxfFcApc
exXDxWPwyCGDR24rxxvKSA/KJCH5bHkvsU3sbsza3e+kIvJPx3Hu21Dhbo8P gnruMmZNlfKx
kLWiwIu27y4+IgAeVZJ4QTYnUcHK6tpaYllZNA9rWyXZIxr8z2HOAQQO9LTb yqJmI4+87eqL
39/y+hovC4Rw1xPENBq3UL5aKrc/PHDQTg0zNZa4zHuH7LGwGs+pWqHFscxr gvJjDZqGmp54
JnxwtheZImgOynPnAJ1C/chKptEzoRaZs9gi8Dh2NcIKHgThFYB2yfVcU0yN pJJX07CCXPkA
eTJsGzL9uxeo4N4s3GsJFWysp6xpe5olghfE02PjY8kg/arWzmEXyiWsiIoS IiICIiAiIgIi
ICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICITYXOxUKjG8OpXBs1U 0Ei4yguHtAKC
+izYpKitjFQKo08b9cbGsbfL4icwOs7ftXJjmG3FHj/kj6Fn0kaLbrRRZL8R GHOa6qrGzQO1
OdYZmHxam7R4tnkXPylwre/6buhWpqipExMNVdXPAWdFj2H1DssdSCQL62uH +4VoPDwHAggi
4IWkQrLs55PjXnOHPghX8jPjavQlee4c+CFfyM+Nq6tl7ejnHqzxezq5Srdj 7wKw/ll/Feir
8A66nh4HUDJHkOBluMpP/Ed6kXNtFM9NXl3z6tKJjdh7HEsNpsXopKOta99P ILPYyV8eYeQl
pBt6tizouB+CxQyRNpHlklLobg+okceJuTkuXEga/FsW2oqqrp6GndUVc8VP AzvpJXhrW+LW
TqVE8XmuEfAuDEMErqbCo44Kypihg4yWR+XJG4FoO3YAddrrSj4K4QylrKd9 Jxza0AVDp5Xy
vksLC73Eu1eLXq8S1IJ4aqBk9PKyaGQZmSRuDmuHlBG1cwzx1DC+J2Zoc5t7 W1gkH+YKkvws
yXcE8GfRVlJLSvljrcukOlnkfJJltlBeXF1hYWF1axDBKHFIqeOric4Uzw+F 0cr43xuAtcOa
QRq9avPeyJjnyOaxjRdznGwA9a5UCjXYPRYlhRw2tidPSOa1rmvleXOAIIu6 +YnUNd7ld8Rw
ujxbDpMProeNpZQA+PMW3AII1gg7QFbUUdVBLM+FkjTLGbOZsOwH7e+HtTiX sq1+CUGJCn0m
J2emJMMkUr45I7ixs9pDgCNovrWPNwYkGK4LHRQ0tLhGFPdKGte50kji0i1i 2w1kkkuJN16d
dXyMjAL3NaCQAXG2smwHtTid1mZT8GsMpJmyU0U0TWPL2wsqZRCDt1RZsm3X s2rik4M4VQy5
6WCSNuZzhCJ5DC0uvmtEXZBe52DxrWRBiwcEsKpqdlPTtrIoozdjY6+obk26 m2f3I1nUNXsW
jQYfS4ZSNpaKIRQtJNrkkk6ySTrJJ2k6yp3SMY5rXOa0vNmgnvja9h9gK7IC IiAiLo2eN074
Q75xjQ5zbbAb2/2KDuirV1fT4dCJalz7OcGNbHG6R7j5A1oJOoE6hsBPiVkG 4BF9flFkBERA
RdWSMkbmjc1wuRdpvrBsR7Vw2eJ7g1krHON7AOBJsbH2HUUHdEVetxCjw2ET V9XBSxE5Q+eQ
MaT5Lk7UFhFDS1lNW0zamkqIqiB17SwvD2m22xGpc09TDVxCWnkbIwgG48Vw CLjxaiD9qCVE
RAREQEXVkjJG5o3NcLkXab6wbEe1cveyJjnyOaxjRdznGwA9aDlERAREQERE BERAREQEREBE
RBw9oexzXC7XCxHqWTJTwNxWVnEsytpo7AtB/tO6AtdZFQ62M1PqpYvjeq1/ BVyTT8UJJqiG
CIvmexkbbAl1gAqpxPDHbZ4D7FXggbW47e5dHTAPfc6s5Hcj7Br+0LZfNCw2 2n1LPD2eKqIm
b3lNeLuzaGWarCHG5NKT5S1q50zCfpU3uhXzUt8TR9pXXSORa9Tp+v8AT/Cn WJYOlUR4RQuH
FCnEDg51hlvdbTMSw+JgaypiDRsGZd+P9YVWsmdPkpIyQ6fU4j+ywd8f+nKQ ujDwoojdZziz
VLR41rmhzTmaRcEbCvP8N334JV4t4mfG1a8NMylaWxZg0m4aTqbyLF4a+Cdd yM+Nq6Nmj/mo
5x6oxZ/ZPJU4AxF3A2gIoHS65e7GTX847ym6LA4P8LsQwTgzhlLS4fx8fFyP znLrJmk/bHk8
iLPFw66sSqY1nXVam1ofWVl462LR6eWV1Yx0MweySkgMzmOyka2hrrggkbPH 4tq1EXI0eIrT
i9RNSSTVE1Ewx5ozTYfUua5+d13OZHIC0kZCWyhw1kfSXFbBibauMCqq6OEO e6Ix0dRMM5me
SSInt8WQ/OAtI2eNe4RTcu8rV04q4sWhmbij8QfFKA1rp2wub/YDCCI72y7D m238atYs4/J2
nZRisbFIWgyubVOmiba9y1hErjcAWuNtzssvQIq91kvPR6c3gk1szqp0zHZZ HRseJjEJLEtB
JffJ6y7yElZ8FNUCVzKHtnFSyzhwdK6XjC0uguSX3dszjXrAvssvYorXzurb KzyMtPXxcJmM
FbVxQxvjbTtNNUzsfHlFw6RsnF3JzAmRpcNt9i4lp4qnCphMzGX1bJYX1YzV TdYeMxisQCBr
No/EBbxL16KFrvGTCuMk4pTira0ifjS/jeLEWV3F8XfuM1+L2d1tza7rVxKC opXUtPRzzltZ
mp3Z53FzSTnMgJNwQ0P2eVo1Aat5cFjHPa8taXNvlcRrF9tk0QyMdpmyS4ZK 9lW5kNTcmnfJ
dt2OALgw3IvYHaNevVdU+D+k6cM3bC/EHTdN4zLx9xbi83c27+/F9z3vqXpE SMvfv3Y7rPE1
AxTSMUFK+ve8kl0zo6hojZxje4bGSGvswOs+JwcR4rkE9ZI652EU9MKute10 zy2o0SvY9hsL
MLeMEhBJcc735Ra1tlvcIndZMy8xBFXvwypqqp9fpBEbXMa54IjLIzJkYP7W p2sXcDcBRaA2
eOsqKB+LMbFTsdT8bJUMeZA6Q689nP2juXXFral6xFPejusyMZwxuI1WFueK j5mZzrwzSR5f
m3azkI8dhr8pHjKxKWOulcxkT8WY9wjFe6cyi0vGsvxZd3OW3GX4vubW9S9k iQdzB4SQ1UeE
00NDNURxMka2Z7GyzycWGm3ePbIe6y3LXX8txdZ5GIR0tEYp6+pYIiKx4gmi JhzG2RryX8aO
UuLQSdZYvXIkSm7yEmnDF6TMa+X5whsNp42NHHO7syNux3cgdxINlrEX19YK OoikdT03bOL/
AMS/ji58pFjOwgtLrixYT3vlOw3XsUUIl5KrgdRyugqn4ucLjkkyOgkqJJM2 VhbdzLyFuuTX
e19R8SnrHyvwTA5zUV8ZGRz56WAzyi8TtZbkftJ1kjxrdrcNocTYxmIUVPVs YczWzxNeGnyi
4VlO6x3vMOlZNLSmrlxqeEsAgkEE8TnSZjm41sbW2He2ztDbX9aoNc6HRqbE zizITAcsVI2o
zXDIbfohmABzeQXJXtl1MbDIJC1ucAgOtrAO0X+wexIHiWNxxlRlL62fEdEt ciWOOF4h5iW7
z+yQfGQNWtwXZPHBV8bWVM7TYhs9LUwlhsb2M73F19Ww2FvWvRJt2qZm903e IodJrGUclDPi
+R8UQrHz8c3M7PHYszi3e8Zcs1WOvxK/PFURYw2KI4mZ2TRNpyXzOg0ezc+Z wOUutxmt5zXt
bxL07GNjY1kbQ1jRZrWiwA8gXEsUc8T4pWNkje0tcx4uHA7QR4wl9Pfv0Q8N OzEHSwNixCti
poy9sEjYKmq7sSvBzGOQE2AZ+kDh95aNXTirixaGZuKPxB8UoDWunbC5v9gM IIjvbLsObbfx
r08MMVPCyGCNkUUbQ1jGNAa0DYABsC7qJTd5OgMg4QxGA4nNT5RlbUCqjELB H4892SkuP9qz
wfLbV6emn0mlin4qSLjGB/FytyvbcXs4eIqVFN0CIigEREBERAREQEREBERA XnsVqm0mJV8z
wSGUUJAG1x4x4AHrJ1L0K8bwik4vhOx0xIphTRuIyk53tc+w+zNf2K9GHGLe ie9Wqrd/ct0e
ahoRE5wNRKTJO4eNx8X/AE5F2471rJOKwOJJkJJ29y7oXHbOD6Z9x3QvQjDs 5JmZlr8d6047
1rI7aQfTPuO6F1disQ2F3uO6E3EZth1QGi5KkwkiUSVr9svcx/3B4/tNzyWX nNIfiErKaHPe
Q2c7KRlb4z7P5leoji4uEF3cRsFgPIPIscWd2LNsOnvlcLw7YsHhr4J13Iz4 2rVop21LHvbs
Di0fYsrhr4J13Iz42q2zX6ajnHqnF+CeTM4HcFqDGuB+F1NW6oEjWys+amLR YTSHYOVF04EY
jh8HBKhjqK18UrTJdgme23zjvEDZFy49VsWv908Z7515uiiquKYs+ioiLJAi IgIiICIiAiIg
IiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIg IiICWB2gIiDr
lB8Q9i6Fo8gUi6FTBLqWix1BdLDyBSHYV0V4RKGaSOCN0khDWt8a8TjXDeLK +CmjdJrsHDY3
1+te3lijlbaRjXgeJwuq7qCjdtpYDyxhaUTTHGFKomeDE4IT6RhLn3v84Vzw 18E67kZ8bVuR
08NO0tgijiBNyGNDbn7Fh8NfBOu5GfG1dOzzfHon6x6s8SLYcx9E3Y38BMN5 ZfxXonY38BMN
5ZfxXouTH7WrnPq2p+GGvo1Pu8HNN6E0an3eDmm9CkRcrRHo1Pu8HNN6E0an 3eDmm9CkRBHo
1Pu8HNN6E0an3eDmm9CkRBHo1Pu8HNN6E0an3eDmm9CkRBHo1Pu8HNN6E0an 3eDmm9CkRBHo
1Pu8HNN6E0an3eDmm9CkRBHo1Pu8HNN6E0an3eDmm9CkRBHo1Pu8HNN6Fg8N IYWcE65zIYmu
AZYtjAPft9S9EsDht4JV/Iz42ro2T5jD5x6s8Xs6uUpOxv4CYbyy/ivRZfAT hLhGG8DqCmrq
6Ommbxhyy3bcGRxuLjWPWNVwRtBRWx4/5auc+qafhh69VqquipCxjg+SV/eR xtzOPQPWdSsr
JcyU4jiLIi1tZJGwwOcLAsA2A+UOze8FzRHGU1TaMlunr2TymF8UsE4Gbi5W 2JHqIuD9hKtr
FZFWR0WHw4i4OxE1IfGAcxjjHfXP93ML+UhUa00UPCYSONBWVr5YwyCQhtVA LAXjOslv9otA
A1vNzsTjETwuiirepvL0z3sjAL3NaCQASbazqAXZeJoMUr642q66jmPGQufT MqGukgfxrdWQ
RtcwbQQ4uOoa9t+2HY3iMsVTJUYlR34sGWNk7XyUhLgHHi+KaWBoLr5y61hf x3WyaWze0Reb
glhfi2Fyx46+qifHMxkuaEtndmb3F2sAvt1Nse59RU1ZVVkTcRn010UUMzYg BE0tiYRHmedV
yQC43OoeMGyhEN5F5A4w/iQJMd4ihD5BFidof/EWDCBmLcm1zxqFzk1bCr+G TSyY22WrqHwV
E9DC80ZDQ0nus1rjMcpPl1X1+JTYbznsY5rXOaC82aCdptfV7F2XjcQrnTVE jn4lxlRDJO00
GSPLCAyTKSC3NrABuTY31C1lYr6/EafC9JbXsjEtU+J0kpZFHTsa59jmMbwC bNF3AjyWJuot
lc77PVIvMUuJvkNC2vxynps7QY3080T2Vjs5GXO5gDjYNuGButx9SqMrhRxv gl4QPpIxPUGS
V7YQY3h/cx3LLDMCXWIufEbJYjN7JFgUM2K1tHVVDpjFUsY0MpcjQ1rzGx1i SCe+JG3YT47E
TU1fJUikqX1T4I6upPEwvhF3sDHWbsu2+Uvudfi9SWzsRnF2yoomVFRJPxcs UbY3hgDoy4nu
QduYeVSrnDu/q/rh8DFalWXXQ6veYeYPXTQ6veYeYPXV9FYUNDq95h5g9dND q95h5g9dX0QU
NDq95h5g9dNDq95h5g9dX0QUNDq95h5g9dNDq95h5g9dX0QUNDq95h5g9dND q95h5g9dX0QU
NDq95h5g9dNDq95h5g9dX0QUNDq95h5g9dNDq95h5g9dX0QUNDq95h5g9dND q95h5g9dX0QZ
kRk4yeOVzXOieG5mtLQe5B2XPlVGhpqnFopKl2JVNM3jpI2RQNjsAx5ZclzX G5y3V9v65WfW
j4GKvweP/lj/APFVP470i0XlHHJ27RzenMR92D8tO0c3pzEfdg/LXXhDxzsK LKfNxj5YmgNn
fDe72gjO3um8oWbhVTXxVPa8GNvFve6USyyVJYBxZyte4hzrh51nYTaxAUxN /wDo3Wp2jm9O
Yj7sH5ado5vTmI+7B+Ws2nxyvIhlmNJJFUwipZxTXAQxh7Q4OdmOY5X3Bs3W 06vJJJjOIvpH
mlpopKkC7WkW1Oc3JYOc25yuNxcXLbXCJ3fd17tHN6cxH2Qflp2jm9OYj7IP y1i/KHGJpYoc
PpW1j42Z5iyARZ+7c3LlllY6PvDrs/b6tfpjVwNzZpoxkeI3XeO5cbWafWbj V6x5U98Dd7lP
tHN6cxH2Qflp2jm9OYj7IPy1fZNHI57WPa50ZyvDTctNgbHyGxB+1drqL+7I 3WVhskpdWU88
pmdSz8UJSAC8FjXgm2q/d21eRZ3DbwSr+RnxtV7DTeuxj/GD8CJUeG3glX8j Pjattn+Zw+ce
sKYnZVcpYvAjAYa7gnRzy4DgtSXGT56paHSPtI4d182dmzadQHIC3uxv4CYb yy/ivRMe3S1Z
d8668ymJtGfp/htqGppIKtrWzxh+U3adhafKDtB5FMi5eDZXp6GnpXOdFH3b 9TpHOLnu5XG5
KsIiTN+JwERFAIiICIiAiIgIiIOr2h7HMdezhY2NlxFEyGJkUTQyNgDWtGwA bAu6ICignfSy
1ANNLIHyBzXMLbWytHjcPGCpVC+rp4nlkk8THDa1zwCFamZjgiU/bF25VHtj 6ydsXblUe2Pr
Ktp9JvUPOBNPpN6h5wK150Vy1We2LtyqPbH1k7Yu3Ko9sfWVbT6TeoecCafS b1DzgS86GWqz
2xduVR7Y+snbF25VHtj6yrafSb1DzgTT6TeoecCXnQy1We2LtyqPbH1k7Yu3 Ko9sfWVbT6Te
oecCafSb1DzgS86GWqz2xduVR7Y+snbF25VHtj6yrafSb1DzgTT6TeoecCXn Qy1We2LtyqPb
H1k7Yu3Ko9sfWVbT6TeoecCafSb1DzgS86GWqz2xduVR7Y+snbF25VHtj6yr afSb1DzgTT6T
eoecCXnQy1We2LtyqPbH1k7Yu3Ko9sfWVbT6TeoecCafSb1DzgS86GWqz2xd uVR7Y+snbF25
VHtj6yrafSb1DzgTT6TeoecCXnQy1We2LtyqPbH1k7Yu3Ko9sfWVbT6Teoec CafSb1DzgS86
GWqz2xduVR7Y+snbF25VHtj6yrafSb1DzgTT6TeoecCXnQy1We2LtyqPbH1k 7Yu3Ko9sfWVb
T6TeoecCafSb1DzgS86GWqz2xduVR7Y+snbF25VHtj6yrafSb1DzgTT6Teoe cCXnQy1We2Lt
yqPbH1k7Yu3Ko9sfWVbT6TeoecCafSb1DzgS86GWrtCXPlqJXRujEkgIa4i9 srR4ifIVmUVc
/Co5aWoo6suE80jXxU0kjXNfI541tB8TlrRyxzNzRSNe0G12kELnOLkAONvo tJUb2qbaMupx
Wjrad0FXhlXPC/vo5cNmc08oLLLrTYlQUUbI6TCqqBkYIY2LDJWhoJuQAGar nWtbP+zJ7juh
M/7MnuO6EvGnvyM2NHWYZCakxYNOw1X6ctwuUcdt77uO62nb5Su8+I4fVRyR 1GE1MzJWhr2y
YZK4PANwCCzWAVrZ/wBmT3HdCZ/2ZPcd0JeNPfknNhyy4PPFBFNgMskdPqhY /CZCIv7oyatg
2KwcVo3Zr4ZWHO8SOvhs3dOFrOPcbRYWPqHkWpn/AGZPcd0Jn/Zk9x3Qp3o9 /wDSM2czGqeN
z3MoK5rpDmeW4fMC42Aue41mwA+xdu38e54h/kJ+or+f9mT3HdCZ/wBmT3Hd Ci8ae/IzUMJZ
KdNqZYXwiqqOMYyRuV2URsZcg6xradqo8NvBKv5GfG1bzXBwuFg8NvBKv5Gf G1b7LN9ow+ce
qmJFsOrlKTsb+AmG8sv4r0Tsb+AmG8sv4r0U4/a1c59U0/DDbWbKZ6+vlpop nw08FhI6M2c9
xF8t/EACDq161pKjJFUUta6qpWCZsoAlhLspuNjmny+Kx8gXPTa61To+GXC5 IXtnklpZHtie
2Z2YxkmzSHHWbkgWJ8a6dtZpMZkoYIIHNgy8aX1GWUAgHM1mU3brtckawR4t c79JxGaEzwaN
TQuEgjc4Oe9wvbNa4AG3UTrUFbhc9fWxOmnpzSRSNlZGacmVjm/RkzWF/H3N 7Ei+tTVa5Twl
w7HaeUAUjnOdxkbbyQva17XPDS5hIAeNe1pI1jyqSPHKCRsrmyyBsTc2Z0L2 h48rCR3Y2d7f
aPKFm0HBOOhOVgw9rWlmWSGhEczg1wdZ7w6zr216hr1pRcFGULJGwdr43BoE U0VAGTAtcHAy
ODu71gXADb+pVysv3tCPHIJa2lp2Q1Q0lj3Nc+llZlykDugWjLt2m3i8oVib E6enrGU0vHNe
+1ncRIY9ewZ7ZQfUTfZ5VCyirTUUtRPVwOliD2S5KctbI1xB1AvJaRlGu5G3 V5KdZwcFZi2m
vkpzZ7HtdJTZ5oy23ctkLu5abHUBtJN9ahC32+oDTMqGPnkjkNmcVTSvL9QN 2tDSS2xHdAW8
V7qCHhFTuikEjsszTLa8UjYzkc4Wz5SM1hcgXO3UpX4ZUxQUYoaqKKemi4nP NAZGvbYX7kOa
QbtHjXWfBTPQtpzUAEPleXBm3OHjZfxZ/wCSZC27E6RkYkfMGNL3su5pFi0E uvcagA0m51e0
LmixGnrw8wcaCw2c2aF8Th5DZ4Bt69moqtUYNHUvq+MkIiqYjGWNaO5LgA52 u4NwG+LxHbdd
cEwYYQ2UCLDmGS2uiotHva/fd06+31JkM6j4ST1VTLZoZGZgyOKWkmjcGiUM JzOs1173sLZd
QN1qtx2gdHPJxsgjgjMrnuhe1rmDa5hIs8ett9o8oUT8EzuiJn/Rvc+2TbeU SW2+qyq4bwZO
FNnFI7D4JHQmKKohoGsmb5C92az9gJ1C5CmLWzT3t8EOAI2HWFyuACAATc+M +VcqECr0/wCn
q/rR8DVYVen/AE9X9aPgakd6JWERFCRERAREQEREBERAREQEREBERAREQERE BERAREQEREBE
RBXp/wBPV/Wj4Gq3Tfov+Z3+5VSn/T1f1o+Bqt036H/md8RVp4o7nM0ohjzl rnawAG2uSTbx
royqjdqeeKfmy5XkXvq8h9YSrhM8GRrWOOYHK/YbG9thUNPRujmDy2NjbOsx mxl7bNQ8hP2o
LLaiFxcGysJabEBw1HyLkzRNaXGRgAvclw8W1Um0U2QNPFgxR5Iy0nujcEE6 tWweXaVyaBwa
4DK8WblBcW69V9Y2bAUFrSoLMPHR2f3vdjuuTyqVZpoJnHNJllLm5XDjXM8Z P9ka9vkCunju
6txffDLe/e6r39e3+SCVF1bnzPz5bX7m3kt4/tuuyCt/xZf7w/2CweG3glX8 jPjat7/jS/3h
8IWDw28Eq/kZ8bVvsnzGH/7R6qYvZ1cpYfBPhnhnB/glhdJWsqnSuZJJ8zA5 4sZpBtHj1IrX
Argvg2M8DcMqMRoIqiZrZWB7r3sJnm38yitj26Wq9+M6app+GP8AH+3sURFy LiIiAiIgIiIC
IiAiIgIiICIiAoHUkT5HPvIHONzllc0HVbYD6lOimJsWV9Di+lNz7+lNDi+l Nz7+lWES86ot
CvocX0puff0pocX0puff0qwiXnUtCvocX0puff0pocX0puff0qwiXnUtCvoc X0puff0pocX0
puff0qwiXnUtCvocX0puff0pocX0puff0qwiXnUtCvocX0puff0pocX0puff 0qwiXnUtCvoc
X0puff0pocX0puff0qwiXnUtCvocX0puff0pocX0puff0qwiXnUtCvocX0pu ff0pocX0puff
0qwiXnUtCvocX0puff0pocX0puff0qwiXnUtCvocX0puff0pocX0puff0qwi XnUtCvocX0pu
ff0pocX0puff0qwiXnUtCvocX0puff0pocX0puff0qwiXnUtCvocX0puff0p ocX0puff0qwi
XnUtCOKFkAcGZu6NyXOLiTa208gXYNc2+SRzQTewt/1C7IiXHznnn+xvQnzn nn+xvQuUQcfO
eef7G9CfOeef7G9C5RBx8555/sb0J8555/sb0LlEHHznnn+xvQnznnn+xvQu UQdWty31kkm5
J8awuG3glX8jPjat9YHDbwSr+RnxtXRsnzGHzj1Z4vZ1cpSdjfwEw3ll/Fei djfwEw3ll/Fe
itj9rVzn1KfhhtrzcsdVLj1S+nirQ6KeP581R0drMjC5vF59ZILv7G03uvSL qGMaXENaC83c
QO+Nra/sAXLE2aMFuI4rNBRtbNQQz1MLqi74nua1oDe5tnBJu6+a4sPEdqqz Y7iNo5KWBr5a
1kBhjy3MYcx7iCHSNa49ydhbt8dtfoanDaKsp2U9VR088DCC2OWJrmttqFgR YKHtRTSmq0wa
a2pIzMqGNcwNBu1obYCwJO259am8e/fv+RUpKzFquSGJ7YKKaNgfUMmizl4L iO5DZLN1Nvtd
bMB4tef2yxekpOM46CaHjpzJOKZ8hia15AaWCTMddxmaDlsLt8Y3Tg2GFlOw 4dSFtMbwNMDb
RG97t1dzr8iS4Nhk83HTYdSSS5+MzvgaXZ9XdXtt1DX6govmc0lLNJLNUh8k D2skAYInEuaM
rTZ/kNyTyEKyujIo43PcyNrXSHM8tFi42tc+XUAPsXdAREUAiIgIiICIiAiI gIiICIiAiIgI
iICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICwOG3glX 8jPjat9YHDbw
Sr+RnxtXTsnzGHzj1Z4vZ1cpSdjfwEw3ll/Fei832OsXqmcGnQOqAI4ah7Y2 lre5abOts163
OOvyoujFwKqsSqY1n1Yzj00ftl79QiaR75GxU0sgjdlLmloF7A+Nw8oUy5w7 v6v64fAxcFMX
dMos1RuU3vR9ZM1RuU3vR9ZaSK1oRmzc1RuU3vR9ZM1RuU3vR9ZaSJaDNm5q jcpvej6yZqjc
pvej6y0kS0GbNzVG5Te9H1kzVG5Te9H1lpIloM2bmqNym96PrJmqNym96PrL SRLQZs3NUblN
70fWTNUblN70fWWkiWgzZuao3Kb3o+smao3Kb3o+stJEtBmzc1RuU3vR9ZM1 RuU3vR9ZaSJa
DNm5qjcpvej6yZqjcpvej6y0kS0GbNzVG5Te9H1kzVG5Te9H1lpIloM2bmqN ym96PrJmqNym
96PrLSRLQZs3NUblN70fWTNUblN70fWWkiWgzZuao3Kb3o+smao3Kb3o+stJ EtBmzc1RuU3v
R9ZM1RuU3vR9ZaSJaDNm5qjcpvej6yZqjcpvej6y0kS0GbNzVG5Te9H1kzVG 5Te9H1lpIloM
2bmqNym96PrJmqNym96PrLSRLQZs3NUblN70fWTNUblN70fWWkiWgzZuao3K b3o+smao3Kb3
o+stJEtBmzc1RuU3vR9ZM1RuU3vR9ZaSJaDNm5qjcpvej6yZqjcpvej6y0kS 0GbNzVG5Te9H
1kzVG5Te9H1lpIloM2bFKZDI10bo3Ruyua619gPiJ8RCqyYvTRyvjDamVzDZ 3EU0koafIS1p
F/UrTf1ys+tHwMUPB11sLfq1mrqbny/PvTdjNF5Q9uYN2xH+Hz9RO3MG7Yj/ AA+fqLb4xZtH
jrKqJ876aemoxHxrKqcsEcjPpCziWi2vugNX2qbUp/crduYN2xH+Hz9RcduY N2xH+Hz9RXGY
7RymN8NRBJSOhklNSyVpYAwgHXs8Z131WXZ2PYYyhZWvxGjbSPdlbUGdojcd eoOvYnUfYm7S
fuUe3UG64j/D5+onbqDdcR/h8/UWhSYzR11VU01NURyTUzg2RjXtJFwCDYG9 tdvsKhmx2KN1
exkb3SUcec3sGv1XsD6th1KLUozVe3UG64j/AA+fqJ26g3XEf4fP1FqUdaau Ay5MndvZa9+9
cW/9FYzlTu0mbOpaqKsh42BxLbkEFpaQRtBB1g+orG4beCVfyM+Nqv4eb1+M f4wfgRKhw28E
q/kZ8bVrs0W2nD5x6wriTfDq5SqcA8BwjEeBeGz12F0VTNaUcZNTse63Gv1X IRX+xv4CYbyy
/ivRTj9rVzn1TT8MNtc4d39X9cPgYuFzh3f1f1w+Bi56e9aV1ERWBERAREQE REBERAREQERE
BERAREQEREBERAREQEREBERAREQEREBERAREQEREBERAREQEREGa39crPrR8 DFV4PkdrH6//
AHVT+O9Wm/rlZ9aPgYqL8GaJZH01dWUrZHF7o4jGW5ibk90x1rnWl4zhH1a5 ItqIXl5eD9XU
xztMNJQtIBEVJVSCOZ4ka/MQGt4t3cnum3PdaycoWh2om9MYj7IPy07UTemM R9kH5ajK97+/
Ja86M53Bueajc0sjgkN3lvbCeYvcHRuHzrgHt1R2uNmoi6sUuGV1A2OopqWm NSHPzxT4jNKC
HBvdca9hdfuALWt61Z7UTemMR9kH5adqJfTGI/0Py1P8+qLzot0kNRBW1jpB CYZnCRjmvOYH
KGlpFrW7m97+PYLa8Z/BytAEoxJ000jJmSxS5BG0SazlLWBx7sN74nVdXu1E vpjEf6H5SdqJ
fTGI/wBD8pRFozuXnRfoIHUtMY5HNLjJI/uT4nPJH+6tZh5QsbtRL6YxH+h+ UnaiX0xiP9D8
pMtS/wBHbDNdbi/+MH4ESo8NvBKv5GfG1a9FRRUMJjiL3l7i98khu57jYXNg BsAGoeJZHDbw
Sr+RnxtW2zTfacPnHrCmJ2dXKUnY38BMN5ZfxXosjscY7bglFTaN+qzSR5s/ f3Oe9rau/t9i
LXGwq6sSqYjvn1UjFopiImXslzh3f1f1w+Bi4XOHd/V/XD4GLjp720rqIisC IiAiIgIiICIi
AiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiIM1v 65WfWj4GKhQ0
1Ti0UlS7Eqmmbx0kbIoGx2AY8suS5rjc5bq+39crPrR8DFX4PH/yx/8Aiqn8 d6ayj6O3aOb0
5iPuwflp2jm9OYj7sH5azK6PIcVxFtVVMqaaUCBoqniNxyMsziychzE22X7r VrsV1ixzGpqq
qkhw1r6OMzMYSY2jMy4F38bfWW2txYtfbquZutud/wDdq9o5vTmI+7B+WnaO b05iPuwflrEf
wgxkiKlp4GT15c8yAUuQxhoZ3OR8zQe/75r3DVqvfVxJi+Kw1D4aGh/8ZUyG WSMhkhjyxxXb
Yyxg63bQ47NhvcPJG63O0c3pzEfZB+WnaOb05iPsg/LUEFXidbK8g09GyFob LBJGZJM5YHd8
14AALgNhvY69errRYhPScEoq2smZUyinDw6KNwzkjuRa7iSbges+JRfj/o3V ntHN6cxH2Qfl
p2jm9OYj7IPy15qSuM+FvpnuqXvppJLPqo3xve10LyDZ4BtfMP8AlXtgdQU8 ERDKw2SUurKe
eUzOpZ+KEpABeCxrwTbVfu7avIs7ht4JV/Iz42q9hpvXYx/jB+BEqPDbwSr+ RnxtWuz/ADOH
zj1hTE7KrlLxvAVzYMCkM9DWScZUOcx8dDLK1zbAanNaRtBG3xIvbdjfwEw3 ll/Fei3xcaKc
SqLd8+qnRRVnMy21zh3f1f1w+Bi4XOHd/V/XD4GLgp728rqIisCIiAiIgIiI CIiAiIgIiICI
iAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiIM1v65WfWj4GL Koq5+FRy0tRR
1ZcJ5pGvippJGua+RzxraD4nLVb+uVn1o+BiqyYvTRyvjDamVzDZ3EU0koaf IS1pF/Umd7WR
9VE1WFGv084LNpu8dqpeM2W77JfZqXElRhMtU+qkwOV9RI0sfM7CpS9zSLEE 5LkW1ciu9uYN
2xH+Hz9RO3MG7Yj/AA+fqJb6T7/g3vrCg6TBXUTaN2APNIx2dsBwmTIHeUN4 u19ZXeepwqqp
xT1GCTSwAhwikwqVzQQLA2LLbNXIrnbmDdsR/h8/UXHbmDdsR/h8/US06T7/ AIN76wq6Xhmk
w1PaWfj4G5Ipe1cuaNvkaclwNZ1BSRYnQwRcVDhVXHHn4zIzDZgM175rZNt9 d/Kpu3UG64j/
AA+fqJ26g3XEf4fP1EtOk+/4L/WEUmKUU0hklwure8tylzsNmJI16r5NndH2 nyqXt/Hb9TxD
/IT9RO3UG64j/D5+onbqDdcR/h8/US06T7/g3vrBhLJTptTLC+EVVRxjGSNy uyiNjLkHWNbT
tVHht4JV/Iz42rZpaqKsh42BxLbkEFpaQRtBB1g+orG4beCVfyM+Nq12af8A 5NHOPVXE7Krl
KTsb+AmG8sv4r0Tsb+AmG8sv4r0U4/a1c59U0/DDbXOHd/V/XD4GLhc4d39X 9cPgYuenvWld
REVgREQEREBERAREQEREBERAREQEREBERAREQEREBERAREQEREBERAREQERE BERAREQEREBE
RBmt/XKz60fAxQ8HXWwt+rWaupufL8+9TN/XKz60fAxVeD5Hax+v/wB1U/jv TX+Ed7ZznyLL
r8eFBUSRuoaqWKGMSzTxcXkiab6yC4ONspPcgq/ceULFxLA+2FZPUid0bzEx sY41/FktLiRJ
GCGvabgEHXa9rbUiYvms1n4pRx1kdHJVwMqpRmZA6Roe4a9YbtOw+xZmGcLK HEqmoa2qoGxM
k4qLLWNdI85sutlu5BPe6ze42Kl2kqX4vpc8MT2zSRzSBmJTsET2taLCMDJJ YtBBOW+wjUtC
lwx0NXFNIYjxbZxcbRxkgcLavINaErrcaw52k5a+lOifrFpm/M/39fc7Dt8i gbwjw507WGtp
RFI1nEy8e3LM5xcMrfKe58S8/T8GZ4KR8D6aGZ0UbY4nuxapAcA5p1NseK70 HuSbEW2K9Bg1
UaOtFXLDJU1VNxRebbczzYkMbcDONeUX22TImNHpc58iZyoQQANYXOYeUKLj Jw83r8Y/xg/A
iVDht4JV/Iz42q9hmutxf/GD8CJUeG3glX8jPjat9n+Zw+dP9mWJ2dX8pOxv 4CYbyy/ivROx
v4CYbyy/ivRMftauc+q1Pww21zh3f1f1w+Bi4XOHd/V/XD4GLnp71pXURFYE REBERAREQERE
BERAREQEREBERAREQEREBERAREQEREBERAREQEREBERAREQEREBERAREQZrf 1ys+tHwMVF+D
NEsj6aurKVsji90cRjLcxNye6Y61zrV5v65WfWj4GKRVmZiSIvDM7UTemMR9 kH5adqJvTGI+
yD8taaKN6fcJ3WZ2om9MYj7IPy07US+mMR/oflrTRN6fcG7DM7US+mMR/ofl J2ol9MYj/Q/K
Wmib0m7DM7US+mMR/oflJ2ol9MYj/Q/KWmib0m7CvRUUVDCY4i95e4vfJIbu e42FzYAbABqH
iWRw28Eq/kZ8bVvrA4beCVfyM+Nq32Wb7Rh849WeLlh1cpSdjfwEw3ll/Fei djfwEw3ll/Fe
itj9rVzn1TT8MNtc4d39X9cPgYuFzh3f1f1w+Bi56e9aV1ERWBERAREQEREB ERAREQEREBER
AREQEREBERAREQEREBERAREQEREBERAREQEREBERAREQEREGa39crPrR8DFI o2/rlZ9aPgYp
FSrimOAiIqpEREBERAREQFgcNvBKv5GfG1b6wOG3glX8jPjaunZPmMPnHqzx ezq5Sk7G/gJh
vLL+K9E7G/gJhvLL+K9FbH7WrnPqU/DDbXOHd/V/XD4GLhc4d39X9cPgYuen vWldREVgREQE
REBERAREQEREBERAREQEREBERAREQEREBERAREQEREBERAREQEREBERAREQE REBERBmt/XKz
60fAxSKNv65WfWj4GKRUq4pjgIiKqRERAREQEREBYHDbwSr+RnxtW+sDht4J V/Iz42rp2T5j
D5x6s8Xs6uUpOxv4CYbyy/ivRQdj6vpKXgPhrKiqgheeNIbJIGm3Gv160UbR XTGNXee+fVai
mZpjJ6Jc4d39X9cPgYuFzh3f1f1w+Biyp7yV1ERWBERAREQEREBERAREQERE BERAREQEREBE
RAREQEREBERAREQEREBERAREQEREBERAREQEREGa39crPrR8DFIo2/rlZ9aP gYpFSrimOAiI
qpEREBERAREQFgcNvBKv5GfG1b6wOG3glX8jPjaunZPmMPnHqzxezq5Sq9jR nF8DoD2vcc8s
juMAj+c7oi/fX8Vtf0fJZFe7G/gJhvLL+K9FfaJnpaucq00xuw21zh3f1f1w +Bi4XOHd/V/X
D4GLmp72krqIisCIiAixeE/CBnB7DeODWyVEpyQxk7TbafHYerygar3WbwQ4 XzY/UTUtZAxk
7GcY10QIaW3AIIJJvcj/ALW10nEpird73TTsuLVgzjRH7YesREV3MIiICIiA iIgIiICIiAiI
gIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgzW/rlZ9aPgYpFG39crP rR8DFIqVcUxw
ERFVIiIgIiICIiAsDht4JV/Iz42rfWBw28Eq/kZ8bV07J8xh849WeL2dXKUn Y38BMN5ZfxXo
nY38BMN5ZfxXorY/a1c59Sn4Yba5w7v6v64fAxcLnDu/q/rh8DFz0960rqIi sCIvP8JeFdLg
NO5kbmT1x1MhDr5Da9322DWNW0+LxkRVVFMXlphYVeLVFFEXl4Ph3iMeIcJJ BEO5pWCnLvpE
Ek+LxEkfZfxr2XAHCH4dgrqidjWy1hEgIdf5u3c38Q2k/br8g+f4FhM/CLGm wOe5wceNqJHP
7rLcZjc3uTf16zyr7RHGyKNscbGsYwBrWtFg0DYAFy4Mb1U1y9z9TxIwcGjZ aJ5uyIi63z4i
IgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiDN b+uVn1o+BikU
bf1ys+tHwMUipVxTHAREVUiIiAiIgIiICwOG3glX8jPjat9YHDbwSr+RnxtX TsnzGHzj1Z4v
Z1cpSdjfwEw3ll/FeidjfwEw3ll/Feitj9rVzn1KfhhtrnDu/q/rh8DFwucO 7+r+uHwMXPT3
rSuoiKwyeE2KnBsBqaqNzRNbJFcgd0dQIvttrNvUvi8kj5ZHSSPc97yXOc43 LidpJX0Dsm1Z
EeH0jZW2cXyvj1X1WDT5Rtd/PyKj2PME0uufiVREx9PT9zGXHWJdRuB6h5fG RbZq4sW9eJuw
+l2CaNl2OcerjP8A1EPRcC+DAwalFbU5jW1EYu0gjimmxy2Pj1C9/Jb1n1SI uummKYtD5/Gx
q8aucSvjIiIrMhERAREQEREBERAREQEREBERAREQEREBERAREQEREBERAREQ EREBERAREQER
EGa39crPrR8DFIo2/rlZ9aPgYpFSrimOAiIqpEREBERAREQFgcNvBKv5GfG1 b6wOG3glX8jP
jaunZPmMPnHqzxezq5S47HVXTxcB8OZJURMcDLdrngEfOvRSdjhjTwFw0loJ vL4v3r0U49+l
q5z6lPww3Fzh3f1f1w+Bi4XOHd/V/XD4GLCnvWldRQ1dSyio56qQOLII3SOD dpAFzb2LyPBr
hzNjGNaDVUrI2zZjCYybtsCbOudeobRbWNmvVE1xTMRPe6MPZsTFoqxKYyp4 vK8N8TZifCOX
i43MFKNGu498Wudc+rWT7PsX0TgjST0PBiigqonRStDiWO2i7iRfyaiNS+U4 /wCEOJ/4qX4y
vuCwwc66qpet+pzGHs2FhU8OPlH+xERdTwRERAREQEREBERAREQEREBERARE QEREBERAREQE
REBERAREQEREBERAREQEREBERBmt/XKz60fAxSKNv65WfWj4GKRUq4pjgIiK qRERAREQEREB
YHDbwSr+RnxtW+sDht4JV/Iz42rp2T5jD5x6s8Xs6uUunY88CMO5ZfxXonY8 8CMO5ZfxXots
ftauclPww9EucO7+r+uHwMXCiYKiGSUwyxBsjs1nxkkGwG0OHkXHTMd68u+P +D2J/wCFl+Ar
43hWIyYTXsrIR86xjww/RLmFoOsHZe9vUvq2Ny1hwLEA+WAt0aS4ERBtlP7S +Orl2if3RMPo
/wBGpirCrpqjKf8ACxBNG6ubPXZ52F+eQX7qU7bE3uLnUTtF769i9BjHDzFM SvHSnQYD4ond
2dm1+3aPFbbY3Xl17HBeAs87GVGJPELTZzYLEuOvY7ZbV4gb6/EQsaN+f20v R2qdnw7YuNF7
cP8AUKXAqixSXHKeooGvZAx9p5SLMLNRc0nYSRbVyHVa4+uLJpIp6GljpqU0 sUMYs1jYXavv
/wA1Nxtd56n5l3XXbh0RRFrvltt2qdqxN/dtEe82giz+NrvPU/Mu66cbXeep +Zd11reNXHno
0EWfxtd56n5l3XTja7z1PzLuul41M9Ggiz+NrvPU/Mu66cbXeep+Zd10vGpn o0EWfxtd56n5
l3XTja7z1PzLuul41M9Ggiz+NrvPU/Mu66cbXeep+Zd10vGpno0EWfxtd56n 5l3XTja7z1Pz
Luul41M9Ggiz+NrvPU/Mu66cbXeep+Zd10vGpno0EWfxtd56n5l3XTja7z1P zLuul41M9Ggi
z+NrvPU/Mu66cbXeep+Zd10vGpno0EWfxtd56n5l3XTja7z1PzLuul41M9Gg iz+NrvPU/Mu6
6cbXeep+Zd10vGpno0EWfxtd56n5l3XTja7z1PzLuul41M9Ggiz+NrvPU/Mu 66cbXeep+Zd1
0vGpno0EWfxtd56n5l3XTja7z1PzLuul41M9Ggiz+NrvPU/Mu66cbXeep+Zd 10vGpno0EWfx
td56n5l3XTja7z1PzLuul41M9Ggiz+NrvPU/Mu66cbXeep+Zd10vGpno0EWf xtd56n5l3XTj
a7z1PzLuul41M9Ggiz+NrvPU/Mu66cbXeep+Zd10vGpno6t/XKz60fAxSKKJ j2ulfK9rnyOz
HK3KBqA2XPkUqpVxTHAREVUiIiAiIgIiICwOG3glX8jPjat9YHDbwSr+Rnxt XTsnzGHzj1Z4
vZ1cpdOx54EYdyy/ivRS9jmMO4DYcSTtl/Fei1x6o6WrnJT8MN1EVeuqdCoK mqyZ+IidJlvb
NYE2v9i4oi7Tg4xGnfV4bVU0ZaHzQvjaXbASCBdfHYaKpqKxtHFC91S52Ti7 WIPjvfZbx32L
622fFnbKGj/zb/yl0oHiXEp3S0dJHUGGOTj4H8ZxjHFwHdZWn+x6/EqYmDNW bv2L9Q6rFVNr
34c2Pwb4HRYfxNZX/OVje6EdwWRnxcrh5dnk2Ar1aq0+J0NZUS09LW0880JI kjjla5zNdtYB
uNatKaaYpi0ObGx68evfrm8iIiliIi6l7BIGFzc5BIbfWQNp/mEHZEXVr2PL g1zXFhs4A7Dt
sfaEHZF1c9jHNa5zQXmzQTtNr6vYj3sjAL3NaCQASbazqAQdkREBEUZmjE7Y S75xzS4C20Cw
P+4QSIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICI iAiIgIiICwOG
3glX8jPjat9YHDbwSr+RnxtXTsnzGHzj1Z4vZ1cpSdjfwEw3ll/Feij7G1TE eA9CzjAHRula
4HVY8Y4/7EIr7RE9LVzlFMxuw31Qx3/0DEv8LL8JV9dZI2Sxujka17Hgtc1w uCDtBC5Im03a
TF4szKzCMSrK18DavJhtRZ0tu/ZYAFjfU7b7f+bispHNqsRpKLuHDDYYoe67 03mDdZv6lP2i
wn0ZRf5dnQp6ahpKLNolLDBntm4qMNzW2XtyqYimLzHezpo3at5jS1rJ8L0e ioq+mdAxjXsb
SvjdFGHND2sdaxOW/eE7NXiWdxrWysiqX4wKB/GmnZGKrjiBxet9vnB3We2b xEeKy9kupYwy
B5a3OAQHW1gHaP5BRfPNr3Wefp24k2bD6SqleZJ4Y5agiSxY6O2fZ9IlgsNX feXXFjsj34hU
wRS4iKrR2OpG0wl4tspLwC4tGW17Xz6rBelyNz58oz2tmtrt5EDGB5eGtD3A AutrIGz/AHKm
+dx5yannjoWy1T8Sc2SpeKkQPkLxGHPy5Wt7oC5brYLkWvcKpOMRFHFxM1Uy eSnf3LjI9/Ei
ZuUlmYHPxbjciz/Xey9gomUsEVRLURwRsmmsJJGsAc+2y52myiJHlqdr2UEL a6pxOoos79dP
T1kUrXWblBGZ0pb35uTbWB4guuIU5gmrjG7E4zJUMkIY2qe2aPixZoMZuzuh rLdYsLgg2PsE
S+dyGDiArnYJSCBtTFOYnZwx5e9p4p1rutrOa2sjbZV8Rw5zIqqInEJaYPgm OWaVz75znykH
NsAOVv2C69MiTPePN0GkduY8vbDjuNk4/j+N4nibHJlv3F/0ezuu+vrurNXp kVfM+LSHxRWq
ABmIdcBpYANuoPdbykHyLbRLjy0jKyLEI2F2IPrGviETryGAxZW8YXW7i/f9 93V7W8S4fRVs
UNBIH1jwaZzqwlzzM79HcMN+4dqOoC512sTdeqRTew8XNPPDU1cj5MTdEZW5 pQ2pjLWmVoEb
YyC13c3GaOxI2i+sqhlW+l4mB+Ix0ck7nU00rat8rRlaMrg1zZAC4vILzYW8 hFvZPYyQAPa1
wBBAIvrGsFdlF8k97ypfWPjLpu2IxU0wNLkbKIQ7i/7QHzebNm1P9XqVvgwy djKjjauonaS0
hs9LURFh13sZnuJvq2Gwt61vol+KO6IERFAIiICIiAiIgIiICIiAiIgIiICI iAiIgIiICIiA
iIgIiICIiAiIgIiICwOG3glX8jPjat9YHDbwSr+RnxtXTsnzGHzj1Z4vZ1cp ZHAHEo6LgnTR
uo5pS58jszKSoeO/I75sbmnZ4j/O6Lb7G/gJhvLL+K9F04+Jh9LVemeM9/8A pSmjKM22iIvN
biIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIi ICIiAiIgIiIC
IiAiIgIiICIiAiIgIiICwOG3glX8jPjat9YHDbwSr+RnxtXTsnzGHzj1Z4vZ 1cpdOx3RU03A
jDnyQRveTLcltyfnXop+xv4CYbyy/ivRTjxHS1c59Sn4YbaIi5WgiIgIiICI iAiIgIiICIiA
iIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiA iIgIiICIiAsD
ht4JV/Iz42rfWBw28Eq/kZ8bV07J8xh849WeL2dXKUnY38BMN5ZfxXos3gFN IzgbQNa+wBl1
ZQf+I71It8bCqnFqn6yrTVFoetREXnthERAREQEREBERAREQEREBERAREQER EBERAREQEREB
ERAREQEREBERAREQEREBERAREQEREBERAREQEREBERAREQEREBYHDbwSr+Rn xtW+sDht4JV/
Iz42rp2T5jD5x6s8Xs6uUs3gJHK7gfQlkT3NvJrDT5xyLrwGE3yQoclDBK28 lnuAufnHetF1
42JbEqjLjLKKcnr8k3n4+ZPWTJN5+PmT1lIi8x0o8k3n4+ZPWTJN5+PmT1lI iCPJN5+PmT1k
yTefj5k9ZSIgjyTefj5k9ZMk3n4+ZPWUiII8k3n4+ZPWTJN5+PmT1lIiCPJN 5+PmT1kyTefj
5k9ZSIgjyTefj5k9ZMk3n4+ZPWUiII8k3n4+ZPWTJN5+PmT1lIiCPJN5+PmT 1kyTefj5k9ZS
IgjyTefj5k9ZMk3n4+ZPWUiII8k3n4+ZPWTJN5+PmT1lIiCPJN5+PmT1kyTe fj5k9ZSIgjyT
efj5k9ZMk3n4+ZPWUiII8k3n4+ZPWTJN5+PmT1lIiCPJN5+PmT1kyTefj5k9 ZSIgjyTefj5k
9ZMk3n4+ZPWUiII8k3n4+ZPWTJN5+PmT1lIiCPJN5+PmT1kyTefj5k9ZSIgj yTefj5k9ZMk3
n4+ZPWUiII8k3n4+ZPWTJN5+PmT1lIiCPJN5+PmT1kyTefj5k9ZSIgjyTefj 5k9ZMk3n4+ZP
WUiII8k3n4+ZPWTJN5+PmT1lIiCPJN5+PmT1kyTefj5k9ZSIgjyTefj5k9ZM k3n4+ZPWUiII
8k3n4+ZPWTJN5+PmT1lIiCPJN5+PmT1kyTefj5k9ZSIgjyTefj5k9ZMk3n4+ ZPWUiII8k3n4
+ZPWWDw0bKOCdcXSscLM1CMj+23x5ivRLA4beCVfyM+Nq6Nk+Yw+cerPF7Or lLL4CyxN4IUI
c2a4Ml7TZR+kdsBcEUnY/nibwPo2uka0h0lw42/tuRc+0U4k41cxV3z3fVrR NMUxk9eo5pmQ
Rl8hsNnrJOwD1qRVK1wjko5n/oopw6TksQD9hIP2JEXlWVYYu41ejCOnM2zi dJHG38lrWv6s
y0IZmTxh8ZuNnrBG0H1qjJSRVWPtpxkipaXLWGONmXPKSbOJta2o7Nuu6non CSSsmZ+ilnLo
+SwBP2kE/atKqYiMlYmbraIiyXEREBERAREQEREBERAWdVR6ZjFLQySSMgfD LM8RPLHOLXMA
GYEEDuzsPiWiqDtXCej/AMHUfHCr0cVauCb5O4f9Ot/iE/XT5O4f9Ot/iE/X WhdLq29OqN2N
Gf8AJ3D/AKdb/EJ+unydw/6db/EJ+uoH1FV21aysdLT02ccTxLLslOvU+TaP 7OqzRc2u+9lh
cJm0jsdkdNLhgqW00ZhiqIA+pkdmfYQuLgWuvYAgO12UxVM2Tuxnk9J8nMO+ lW/5+frrqcAw
sSBhkq85BIb2wnuQNptn9YWE7Hq4Y5UNpqhksY4xmhPlY6SNzWOIJjbGHNBL dV3m4OzXq6ux
E8fDNRY2MQiEUgqKzNE51K28dyGsaG6tvdbL37q1iiqcs0bsaPQ/JzDvpVv+ fn66fJzDvpVv
+fn66vseHMaWuDgRcOHj9a5um9OpuxoxaijiwrEcP0SWoy1EropGS1D5QRxb 3gjOTY3YNnlW
nFC2SJj3lxc4AnuiFRxY/wDmOD/4p34Eq0qf9Wi/uD/ZVqzsRldxo0f7fvu6 U0aP9v33dKlV
OpY51ZE6P9IxjnN9esalVZPo0f7fvu6U0aP9v33dKy21UoADJWQtOZzeNcGZ jmOrW038WoWV
oTSPqnw8aeLu7K8Aazbvdni/+bCgtaNH+377ulNGj/b993SoaEt7XMvKXAMs 43Ay6tY1bLLv
TPlcSHZnRf2Xvblcfs/7D7dqDvo0f7fvu6U0aP8Ab993SpUQVY75SCb2JF+Q 2XMUTZWlzy4n
MRqcRsNvEuGbHf33f7lS036H/md8RUQk0aP9v33dKaNH+377ulSrh3enkUoR 6NH+377ulNGj
/b993Ss6GAwUkMobTguya2w2drI2m5uu3GzBtOXy8ZxrWuIc0WBzN2avWgvG CIEAlwJ1C8h1
/wA1zo0f7fvu6VmxTSVEsTTUFzg65ezKWjuXbNX8iPatGle58AL3ZnBzm3tt sSEHOjR/t++7
pTRo/wBv33dKlRBVaMrnsuSGusL8gP8A1WdTUUeK12IGrlqMtNMIY2RTviAH FseSchFzd52+
RaX/ABpf7w+EKng5tV4x/jB+BErUZXRV3JPk7h/063+IT9dPk7h/063+IT9d aF1WxF1QMNqj
SAmo4p3Fgbc1jb+anenUimJlB8ncP+nW/wAQn66fJ3DvpVv8Qn66w2VnB+jw +pnwV9LHWiK0
ssTmNmZcgZpnOBIIJuS8EjXqJuFxhdbieJtFO7FcuVsp0mmMcpktxZaQ8xhp HdkamD+V1O9K
LRo3fk5h30q3/Pz9ddXYBhbHNa6SrBebNBxCfWbX1d35AVjHGqh0ZldibYq5 tMJKfDwGAVR4
rNmykF7u6vqYR3vKumC4hVVtVTaRiNHXNbUdy6CqZM5hMT7h2WOMAbLCxO3W pvOeZuxa9m98
nMO+lW/5+frp8nMO+lW/5+frrQul1XenU3Y0Y9HGKTFqyijklfAyKKVglkc9 zS4yAjM4kkdw
Np8ZVHht4JV/Iz42q/Eb8JK//C0/xzKhw28Eq/kZ8bVts/zOHzp/spX2VXKU PY98CcP5ZfxX
oouAFNDJwMoHPhjc4mW5LQT+kciz2jtq+c+rSj4YeqXBAcCCAQdRB8a5RYLK faqktbI/J5vj
XZPdvb+StgBoAAAA1ADxLlFMzM8SwiIoBERAREQEREBERAREQFnV0dVFiFNX UsGkcVFJC+Jr
mtcQ4sNxmIGrJ5fGtFFMTabomLs7tpiPoWq52D8xO2mI+harnYPzFoorb0aI t9Wd20xH0LVc
7B+YnbTEfQtVzsH5i0UTejQt9Wd2zxH0LVc7B+YnbPEfQtVzsH5i0UTe+had Wd2zxH0LVc7B
+YnbPEfQtVzsH5i0UTe+hadWUBXYjiFHJPRPpIaV7pSZZIyXkscwABjnfTvr 8i1IpTHG1hjc
S0AXBFj/ADXKKJqumIs7aR+6k+70ppH7qT7vSuqKLpdtI/dSfd6U0j91J93p XVEuO2kfupPu
9KaR+6k+70rqiXHbSP3Un3elNIPmn/d6V1RLjqwEN16iSTblN1zHIYmlpjc7 WSC0jxm/jK5R
B20j91J93pTSP3Un3eldUS47aR+6k+70ppH7qT7vSuqJcdtI/dSfd6U0j91J 93pXVEuO2kfu
pPu9KaR+6k+70rqiXHVty57iLZje3k1Af9Flg12HVtY6GifVxVUomBikYC05 GsIIe4fRvq8q
1kUxNkTF2d20xH0LVc7B+YnbTEfQtVzsH5i0UU70aIt9Wd20xH0LVc7B+Ynb TEfQtVzsH5i0
UTejQtOrO7Z4j6Fqudg/MTtniPoWq52D8xaKJvfQtOrO7Z4j6Fqudg/MTtni PoWq52D8xaKJ
vfQtOrOw+GpfW1VdVQaOZmRxMic9rnAMLzc5SRrz+XxKjw28Eq/kZ8bVvrA4 beCVfyM+Nq32
Wb7Rhz9Y9VMSLYdXKUPY98CcP5ZfxXonY98CcP5ZfxXoqbR21fOfVej4YYlu yRun36bpS3ZJ
3X79N0r6ci6+ufbp/Fj0Uaz5y+XtPZHe0ObTAtIuCJKaxHtXNuyTuv36bpX0 5rQ1oaL2AtrN
z7VynXPt0/jCeijWfOXy+/ZHLi3RhmAuRxlNe3t9RXNuyTuv36bpX07KMxdr uRbbq9i5Trn2
6fxg6KNZ85fL3HsjtF3UwAuBrkptp+1c27JO6/fpulfTnNDhY32g6jZcp1z7 dP4wdFGs+cvm
FuyTuv36bpXDT2R3C7aYEXI1SU20favqC4a0NFhfaTrN0659un8YOijWfOXz G3ZJ3X79N0ri
/ZHDg3RhmIuBxlNe3t9YX1BcZRmDtdwLbdXsTrn26fxg6KNZ85fMbdkndfv0 3Sopqrsg05An
ZFETrAfNSi/tK+qKmCRik9vMx/E9TG2fbp/GEThfWfOXziGfsh1AJgijlA2l ktKbewriao7I
lOWh9M4udezWGnc4gbTYXNtY1+sL6PTuLsUqrnZFH/u9RS68VmBAI4iPaP2n rLF2+aIvGHR+
MLUYEVTnVPm8BFJ2Rpow+OmzNP7dNt2EHyEHVZcSy9kWCMySwBjGi5c6SmAH 817atp4YxFKy
GJsmkQjOGC+uRo28is8Iv/Qqz6p3wlRh/qE1x2dH4rVbPEf+U+b58KnshF5Y IWl7QCWh9NcA
7D/Iru2TsjONhTa/79MumLY5X4bjmGso5hE2rrGwzBsbe7Zx0gts1co1r6TD +lar9dn/APOj
8VOijWfN87t2Sd1+/TdKW7JO6/fpulfT0Vuufbp/GDoo1nzl8wt2Sd1+/TdK W7JO6/fpulfT
0Trn26fxg6KNZ85fMLdkndfv03SluyTuv36bpX09E659un8YOijWfOXzC3ZJ 3X79N0pbsk7r
9+m6V9PROufbp/GDoo1nzl8wt2Sd1+/TdKW7JO6/fpulfT0Trn26fxg6KNZ8 5fMLdkndfv03
SluyTuv36bpX09E659un8YOijWfOXzC3ZJ3X79N0pbsk7r9+m6V9PROufbp/ GDoo1nzl8wt2
Sd1+/TdKW7JO6/fpulfT0Trn26fxg6KNZ85fMLdkndfv03SluyTuv36bpX09 E659un8YOijW
fOXzC3ZJ3X79N0pbsk7r9+m6V9PROufbp/GDoo1nzl8wt2Sd1+/TdKW7JO6/ fpulfT0Trn26
fxg6KNZ85fMLdkndfv03SluyTuv36bpX09E659un8YOijWfOXzC3ZJ3X79N0 pbsk7r9+m6V9
PROufbp/GDoo1nzl8wt2Sd1+/TdKW7JO6/fpulfT0Trn26fxg6KNZ85fMLdk ndfv03SluyTu
v36bpX09E659un8YOijWfOXzC3ZJ3X79N0pbsk7r9+m6V9PROufbp/GDoo1n zl8wt2Sd1+/T
dKW7JO6/fpulfT0Trn26fxg6KNZ85fMLdkndfv03SluyTuv36bpX09E659un 8YOijWfOXzC3
ZJ3X79N0qvX0HZCxKjkpKqizwyWzN42nF7G42HyhfV0Uxts0zeKKb/8AqicG JymZ83mOB2BV
eG8F6Olr3S09THxmeJrmODbvcRrAPiIO1F6dFxVzv1TVPe2jKLP/2Q==
--------------070207000206010202080902--
Templates issue [message #263636 is a reply to message #263579] Mon, 25 August 2008 09:36 Go to previous messageGo to next message
------=_NextPart_000_0035_01C906C0.0202B870
charset="iso-8859-15"
The description template isn't behaving as i expected --- incase anyone =
wants to look at it --- it's defined as; http://pastebin.com/m7ae0df43. =
the cursor seems to jump fine on the first row only, that is, entering =
an item followed by enter (or tab) moves the cursor after the closing =
brace ], on subsequent rows, pressing enter has no effect, i have to =
manually navigate to the part after the closing ]. I hope i'm making =
sense. =20
If anyone is using the TeXclipse plug-in and has the right behaviour, =
I'd like to know how the template is meant to be defined.
Template;
\begin{description}
\item[${item}] ${cursor}
\end{description}
Note; on the first row pressing tab or enter moves the cursor position, =
on the following rows it doesn't.
Content-Type: text/html;
<HTML><HEAD>
charset=3Diso-8859-15">
<META content=3D"MSHTML 6.00.6000.16386" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY>
<DIV><FONT face=3DTahoma>Hi,</FONT></DIV>
<DIV><FONT face=3DTahoma></FONT>&nbsp;</DIV>
<DIV><FONT face=3DTahoma>The description template isn't behaving as i =
expected ---=20
incase anyone wants to look at it --- it's defined as; </FONT><A=20
href=3D"http://pastebin.com/m7ae0df43"><FONT=20
face=3DTahoma>http://pastebin.com/m7ae0df43</FONT></A><FONT =
face=3DTahoma>.&nbsp;=20
an item=20
followed by enter (or tab) moves the cursor after the closing brace ], =
on=20
subsequent rows, pressing enter has no effect, i have to manually =
navigate to=20
the part after the closing ].&nbsp;&nbsp;I hope i'm making sense.&nbsp;=20
</FONT></DIV>
<DIV><FONT face=3DTahoma>If anyone is using the TeXclipse plug-in and =
has the=20
right behaviour, I'd like to know how the template is meant to be=20
defined.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>Template;</FONT></DIV>
<DIV><FONT face=3D"DejaVu Sans Mono" =
size=3D2>\begin{description}<BR>&nbsp;=20
\item[${item}] ${cursor}<BR>\end{description}</FONT></DIV>
<DIV><FONT face=3D"DejaVu Sans Mono" size=3D2></FONT>&nbsp;</DIV>
<DIV><FONT face=3D"DejaVu Sans Mono" size=3D2>Note; on the first row =
pressing tab or=20
enter moves the cursor position, on the following rows it =
doesn't.</FONT></DIV>
<DIV><FONT face=3DTahoma>Thanks</FONT></DIV></BODY></HTML>
------=_NextPart_000_0035_01C906C0.0202B870--
Re: moving projects around [message #263771 is a reply to message #263599] Wed, 27 August 2008 09:54 Go to previous message
Upgraded Eclipse versions and now I do see the option for "copy project
contents". With 3.1 it wasn't there.
thank you all.
c
Previous Topic:Patch between different versions in CVS
Next Topic:@ previous posts
Current Time: Sat Nov 29 00:17:08 EST 2025
Powered by FUDForum. Page generated in 0.26610 seconds
