Home » Archived » BIRT » How to find jars outside birt-runtime-2_2_1_1
How to find jars outside birt-runtime-2_2_1_1 [message #263558] Wed, 19 December 2007 10:54 Go to next message
Originally posted by: erikvaningen.gmail.com
Hi all,
We would like to use the Report Engine directly and we use a scripted
dataset. The preview function works fine but the application on Tomcat
is not finding the jars that I need.
Does anyone know how to find the jars outside the Report Engine 2_2_1_1?
Kind Regards,
Erik
Re: How to find jars outside birt-runtime-2_2_1_1 [message #263569 is a reply to message #263558] Wed, 19 December 2007 11:21 Go to previous messageGo to next message
Erik,
Are you developing your own servlet using the RE API?
If so make sure to set
task.getAppContext().put(EngineConstants.APPCONTEXT_CLASSLOA DER_KEY,
RenderTaskExample.class.getClassLoader());
Where RenderTaskExample is the name of your class.
You can also add stuff to the engine classpath by using:
System.setProperty( EngineConstants.WEBAPP_CLASSPATH_KEY,
"/mydir/myjar1.jar;/mydir/myjar2.jar" );
If you are using the WebViewer these settings are already done. You can
put your classes in the scriptlib directory or the web-inf/lib directory.
Jason
Erik van Ingen wrote:
> Hi all,
> Kind Regards,
> Erik
Re: How to find jars outside birt-runtime-2_2_1_1 [message #263624 is a reply to message #263569] Thu, 20 December 2007 03:37 Go to previous messageGo to next message
Jason,
Thanks!
System.setProperty() works fine.
However I would prefer to use
and this is still not working in my configuration. It does not have any
effect
Is there something particular to pay attention when using
EngineConstants.APPCONTEXT_CLASSLOADER_KEY?
Kind Regards,
Erik
Jason Weathersby wrote:
> Erik,
> Jason
>> Hi all,
>> Kind Regards,
>> Erik
Re: How to find jars outside birt-runtime-2_2_1_1 [message #263640 is a reply to message #263624] Thu, 20 December 2007 10:19 Go to previous message
Erik,
Are the classes you need in the classpath of the classloader that loaded
your class? I assume you did change the RenderTaskExample name.
Jason
> Jason,
> Thanks!
> effect
> Kind Regards,
> Erik
>> Erik,
>> can put your classes in the scriptlib directory or the web-inf/lib
>> directory.
>> Jason
>>> Hi all,
>>> Tomcat is not finding the jars that I need.
>>> Kind Regards,
>>> Erik
Previous Topic:TOC with WordEmitter
Next Topic:Viewer Application Context Object error with PDF's, Excel
Current Time: Sun Aug 31 08:03:04 EDT 2025
Powered by FUDForum. Page generated in 0.04965 seconds
