Home » Archived » BIRT » Viewer Application Context Object error with PDF's, Excel
Viewer Application Context Object error with PDF's, Excel [message #263551] Wed, 19 December 2007 10:05 Go to next message
Originally posted by: spaddock.rogers.com
In an effort not to expose certain parameters in the raw HTML like BIRT
currently does with report parameters (see snippet below) I thought I
could use the application context variable as described in the wiki:
http://wiki.eclipse.org/Adding_an_Object_to_the_Application_ Context_for_the_Viewer_%28BIRT%29#Introduction
<TD NOWRAP WIDTH="100%">
<INPUT TYPE="HIDDEN" ID="control_type" VALUE="hidden">
NAME="myid"
VALUE="12"/>
ID="myid_displayText"
VALUE="12" />
</TD>
I found that worked great for the first pass, i could assign
MyTest.toString() to dataset parameters without ever having to set overall
report parameters. However, in the viewer I wasn't able to generate a
PDF, Excel etc. I would get a stack trace like this:
ReportDesign (id = 1):
- Retrieving binding data error
t
org.apache.coyote.http11.Http11Protocol$Http11ConnectionHand ler.process(Http11Protocol.java:584)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoin t.java:447)
at java.lang.Thread.run(Thread.java:595)
Caused by: org.eclipse.birt.data.engine.core.DataException: Invalid
expression to retrieve value in presentation.
org.eclipse.birt.data.engine.impl.document.util.ExprResultSe t.getValue(ExprResultSet.java:130)
org.eclipse.birt.data.engine.impl.document.ResultIterator.ge tValue(ResultIterator.java:150)
org.eclipse.birt.report.engine.data.dte.QueryResultSet.getVa lue(QueryResultSet.java:309)
org.eclipse.birt.report.engine.internal.document.v4.DataItem Executor.doExecute(DataItemExecutor.java:84)
... 69 more
How do the AJAX controls work? Obviously the request is gone after the
web report is displayed. Is this the reason for the hidden parameter
variables in the first place? If what I'm trying to accomplish can't be
done what is the purpose of using the application context object? Is it
just to get objects inside the report and script them to report
parameters? Or can you only use the application context object to display
the first report?
Any help would be greatly appreciated as I don't have much hair left to
pull out.
Kindest regards,
Shayne
Re: Viewer Application Context Object error with PDF's, Excel [message #263572 is a reply to message #263551] Wed, 19 December 2007 11:46 Go to previous messageGo to next message
Shayne,
If you create a blank report and add the data item in the app context
and run to pdf does this work?
Can you post your report? Also you can get at session variables in
script. Not sure if this is what you want, but it may help.
Jason
> NAME="myid"
> VALUE="12"/>
> VALUE="12" />
> </TD>
> overall report parameters. However, in the viewer I wasn't able to
> generate a PDF, Excel etc. I would get a stack trace like this:
> t
> at
> at
> at
> at
> ... 69 more
> display the first report?
> pull out.
> Kindest regards,
> Shayne
Re: Viewer Application Context Object error with PDF's, Excel [message #263585 is a reply to message #263572] Wed, 19 December 2007 13:03 Go to previous messageGo to next message
Shayne,
I see what the problem is now. This appears to be an issue with how the
ajax framework is building its url to submit exports and other things.
As a work around you could open the framesetfragment.jsp page and add
the following:
var qstring = "<%= request.getRequestURL() %>" +
"?<%=request.getQueryString() %>";
right above this line:
var soapURL = document.location.href;
Then open the BirtExportReportDialog.js and change this line:
var action = soapURL;
var action = qstring; //soapURL;
This code will most likely have to be changed in other locations in the
AJAX framework, so I will open a bugzilla entry for this issue. A
better option in your case is to add your object to session and retrieve
it that way.
Jason
Jason Weathersby wrote:
> Shayne,
> Jason
>> BIRT currently does with report parameters (see snippet below) I
>> thought I could use the application context variable as described in
>> the wiki:
>> NAME="myid"
>> VALUE="12"/>
>> VALUE="12" />
>> </TD>
>> t
>> at
>> at
>> at
>> at
>> at
>> ... 69 more
>> request is gone after the web report is displayed. Is this the reason
>> for the hidden parameter variables in the first place? If what I'm
>> trying to accomplish can't be done what is the purpose of using the
>> application context object? Is it just to get objects inside the
>> report and script them to report parameters? Or can you only use the
>> application context object to display the first report?
>> to pull out.
>> Kindest regards,
>> Shayne
Re: Viewer Application Context Object error with PDF's, Excel [message #263587 is a reply to message #263585] Wed, 19 December 2007 13:18 Go to previous messageGo to next message
See bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=213503
> Shayne,
> the following:
> it that way.
> Jason
>> Shayne,
>> Jason
>>> the wiki:
>>> NAME="myid"
>>> VALUE="12"/>
>>> VALUE="12" />
>>> </TD>
>>> t
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 69 more
>>> reason for the hidden parameter variables in the first place? If
>>> what I'm trying to accomplish can't be done what is the purpose of
>>> using the application context object? Is it just to get objects
>>> inside the report and script them to report parameters? Or can you
>>> only use the application context object to display the first report?
>>> to pull out.
>>> Kindest regards,
>>> Shayne
Re: Viewer Application Context Object error with PDF's, Excel [message #263612 is a reply to message #263587] Wed, 19 December 2007 22:12 Go to previous messageGo to next message
Thanks for logging the bug Jason it's good to no I haven't gone crazy...
yet.
I added my variables to the session and in the expression builder for a
dataset parameter calling:
reportContext.getHttpServletRequest().getSession().getAttrib ute( "birtId");
seems to work.
When I looked at the "Retrieve Session Information" wiki I figured setting
a global variable would be a better approach.
So inside beforeFactory I wrote:
var myid =
reportContext.setPersistentGlobalVariable("myBirtId", myid);
and then tried to verify it was being set by creating a label and in its'
onPrepare method writing:
myvar = reportContext.getPersistentGlobalVariable('myBirtId').toStri ng();
this.text = myvar;
I ran the report and the label was blank.
Oddly enough I moved the code out of the beforeFactory event over to the
initialize event and it populated the label properly but with the
following stack trace:
- There are errors evaluating script "var myid =
reportContext.getHttpServletRequest().getSession().getAttrib ute( "BIRTListOwnerId");
reportContext.setPersistentGlobalVariable("myBirtId", myid);":{1}.
Error.ScriptEvaluationError ( 1 time(s) )
detail : org.eclipse.birt.report.engine.api.EngineException: There are
reportContext.setPersistentGlobalVariable("BIRTID", myid);":{1}.
org.eclipse.birt.report.engine.executor.ExecutionContext.eva luate(ExecutionContext.java:577)
org.eclipse.birt.report.engine.executor.ExecutionContext.eva luate(ExecutionContext.java:550)
org.eclipse.birt.report.engine.script.internal.ScriptExecuto r.handleJSInternal(ScriptExecutor.java:60)
org.eclipse.birt.report.engine.script.internal.ScriptExecuto r.handleJS(ScriptExecutor.java:44)
org.eclipse.birt.report.engine.script.internal.ReportScriptE xecutor.handleInitialize(ReportScriptExecutor.java:30)
org.eclipse.birt.report.engine.api.impl.EngineTask.loadDesig n(EngineTask.java:1083)
org.eclipse.birt.report.engine.api.impl.RenderTask.<init>(RenderTask.java:70)
org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.c reateRenderTask(ReportEngineHelper.java:438)
org.eclipse.birt.report.engine.api.impl.ReportEngine.createR enderTask(ReportEngine.java:403)
org.eclipse.birt.report.service.ReportEngineService.renderRe port(Unknown
Source)
Source)
org.eclipse.birt.report.service.BirtViewerReportService.getP age(Unknown
Source)
org.eclipse.birt.report.service.actionhandler.AbstractGetPag eActionHandler.doExecution(Unknown
Source)
org.eclipse.birt.report.service.actionhandler.AbstractGetPag eActionHandler.__execute(Unknown
Source)
org.eclipse.birt.report.service.actionhandler.AbstractBaseAc tionHandler.execute(Unknown
Source)
org.eclipse.birt.report.soapengine.processor.AbstractBaseDoc umentProcessor.__executeAction(Unknown
Source)
org.eclipse.birt.report.soapengine.processor.AbstractBaseCom ponentProcessor.executeAction(Unknown
Source)
org.eclipse.birt.report.soapengine.processor.BirtDocumentPro cessor.handleGetPage(Unknown
Source)
at sun.reflect.GeneratedMethodAccessor117.invoke(Unknown Source)
org.eclipse.birt.report.soapengine.processor.AbstractBaseCom ponentProcessor.process(Unknown
Source)
org.eclipse.birt.report.soapengine.endpoint.BirtSoapBindingI mpl.getUpdatedObjects(Unknown
Source)
at sun.reflect.GeneratedMethodAccessor116.invoke(Unknown Source)
org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCP rovider.java:397)
org.apache.axis.providers.java.RPCProvider.processMessage(RP CProvider.java:186)
org.apache.axis.providers.java.JavaProvider.invoke(JavaProvi der.java:323)
org.apache.axis.strategies.InvocationStrategy.visit(Invocati onStrategy.java:32)
at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118)
at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83)
at org.apache.axis.handlers.soap.SOAPService.invoke(SOAPService .java:453)
at org.apache.axis.server.AxisServer.invoke(AxisServer.java:281 )
at org.apache.axis.transport.http.AxisServlet.doPost(AxisServle t.java:699)
org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherSer vlet.doPost(Unknown
Source)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:710)
org.apache.axis.transport.http.AxisServletBase.service(AxisS ervletBase.java:327)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:290)
org.apache.catalina.core.ApplicationFilterChain.doFilter(App licationFilterChain.java:206)
org.apache.catalina.core.ApplicationDispatcher.invoke(Applic ationDispatcher.java:654)
org.apache.catalina.core.ApplicationDispatcher.processReques t(ApplicationDispatcher.java:445)
org.apache.catalina.core.ApplicationDispatcher.doForward(App licationDispatcher.java:379)
org.apache.catalina.core.ApplicationDispatcher.forward(Appli cationDispatcher.java:292)
at com.zdirect.ReportManager.doPost(ReportManager.java:775)
com.zdirect.web.HibernateSessionRequestFilter.doFilter(Hiber nateSessionRequestFilter.java:36)
org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:235)
org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.java:233)
org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.java:175)
org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:128)
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorRepo rtValve.java:102)
org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java:109)
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAd apter.java:263)
org.apache.coyote.http11.Http11Processor.process(Http11Proce ssor.java:844)
Caused by: org.mozilla.javascript.EcmaError: TypeError: Cannot call method
"getSession" of null (<inline>#1)
org.mozilla.javascript.ScriptRuntime.constructError(ScriptRu ntime.java:3240)
org.mozilla.javascript.ScriptRuntime.constructError(ScriptRu ntime.java:3230)
at org.mozilla.javascript.ScriptRuntime.typeError(ScriptRuntime .java:3246)
org.mozilla.javascript.ScriptRuntime.typeError2(ScriptRuntim e.java:3265)
org.mozilla.javascript.ScriptRuntime.undefCallError(ScriptRu ntime.java:3284)
org.mozilla.javascript.ScriptRuntime.getPropFunctionAndThis( ScriptRuntime.java:1965)
org.mozilla.javascript.optimizer.OptRuntime.callProp0(OptRun time.java:114)
at org.mozilla.javascript.gen.c311._c0(<inline>:1)
at org.mozilla.javascript.gen.c311.call(<inline>)
org.mozilla.javascript.ContextFactory.doTopCall(ContextFacto ry.java:304)
at org.mozilla.javascript.ScriptRuntime.doTopCall(ScriptRuntime .java:2769)
at org.mozilla.javascript.gen.c311.exec(<inline>)
at org.eclipse.birt.core.script.ScriptContext.eval(ScriptContex t.java:223)
org.eclipse.birt.report.engine.executor.ExecutionContext.eva luate(ExecutionContext.java:571)
... 62 more
Have I not followed the event model properly?
As a side note, for some reason when I click the "Print PDF" ajax control
in my reports (while debugging the ajax bug) I'd have to press the button
twice, the first time it regenerated the HTML report, the second time it
created the PDF? Perhaps I should post that as a seperate issue.
Kindest regards,
Shayne
Re: Viewer Application Context Object error with PDF's, Excel [message #263643 is a reply to message #263612] Thu, 20 December 2007 10:36 Go to previous message
Shayne,
Put this in the onCreate of the label. beforeFactory is called before
the onPrepare event.
Jason
> this.text = myvar;
> yet.
> seems to work.
> setting a global variable would be a better approach.
> var myid =
> its' onPrepare method writing:
> this.text = myvar;
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> at
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> method "getSession" of null (<inline>#1)
> at
> at
> at org.mozilla.javascript.ScriptRuntime.typeError2(ScriptRuntim e.java:3265)
> at
> at
> at
> at org.mozilla.javascript.ContextFactory.doTopCall(ContextFacto ry.java:304)
> at
> ... 62 more
> control in my reports (while debugging the ajax bug) I'd have to press
> the button twice, the first time it regenerated the HTML report, the
> second time it created the PDF? Perhaps I should post that as a
> seperate issue.
> Kindest regards,
> Shayne
Previous Topic:How to find jars outside birt-runtime-2_2_1_1
Next Topic:Scripting for Gantt charts
Current Time: Sun Aug 31 08:20:36 EDT 2025
Powered by FUDForum. Page generated in 0.03612 seconds
