| Eclipse + Zend on Ubuntu [message #263310] |
Sun, 17 August 2008 08:58  |
Originally posted by: vizcarradavid.hotmail.com
(I've been at this for three days now. Right now it's 5:33 AM and I
haven't sleep)
I am trying to get Eclipse + Zend on Ubuntu. I was given two options:
a) 1) Install from command prompt and then 2) install PDT as new feature
b) Install all-in-one from Zend (or Eclipse + PDT)
I tried a-1 successfully and was able to HelloWorld on Java. My Eclipse
sits nicely at Applications -> Programming -> Eclipse.
I added the eclipse/pdt site but then when I try to install available new
features I get a message that the new feature requires "org.eclipse.wst
(2.0.0)". I don't know that that is but it's not listed in the available
features from eclipse
So I uninstalled eclipse
I tried b) and it was very easy, I extracted my Eclipse folder to my
desktop (although I much rather have it at Applications -> Programming ->
Eclipse) and I'm able to start Eclipse. However, I set my workspace as
"/var/www" but I could only do it once. Now I get a message that the
workspace cannot be created or it is in use. I did some research and
deleted all ".lock" files in my workspace and Eclipse folders, I've also
read that Eclipse needs to be killed sometimes but "ps -a" only results in
"ps", there's no Eclipse to kill.
So I tried the default /home/"me"/workspace as my workspace, once inside I
tried to change it back to "/var/www" and I get a message that another
instance of Eclipse is using it so I can't do that either.
I re-installed eclipse and uninstalled it, I cleaned up installation
files, I've rebooted like a hundred times now (well.. almost). I've
deleted directories, etc. No luck so far.
Any suggestions on how to fix either the a) or the b) approach?
Thanks in advance
| Re: Eclipse + Zend on Ubuntu [message #263313 is a reply to message #263310] |
Sun, 17 August 2008 11:06   |
> haven't sleep)
> new features I get a message that the new feature requires
> "org.eclipse.wst (2.0.0)". I don't know that that is but it's not listed
> in the available features from eclipse
> -> Eclipse) and I'm able to start Eclipse. However, I set my workspace
> as "/var/www" but I could only do it once. Now I get a message that the
> in "ps", there's no Eclipse to kill.
> I tried to change it back to "/var/www" and I get a message that another
> Thanks in advance
You didn't indicate whether your using Eclipse 3.3 (Europa) or 3.4
(Ganymede). Installing PDT with Ganymede is a bit trickier than
installing it with Europa.
I haven't tried making /var/www my workspace, so I don't know for sure,
but if you're running a web server, might that be locking stuff in
/var/www? Why not just put the workspace someplace safe (such as
~/Eclipse)? Note that you can put the PHP files for a project anyplace
accessible (presumably including /var/www) and still work on them from
Eclipse (by importing them into a project). Eclipse stores project
settings etc. in the workspace, but project source files can be elsewhere.
/Paul
| Re: Eclipse + Zend on Ubuntu [message #263383 is a reply to message #263380] |
Mon, 18 August 2008 23:10  |
Exquisitus wrote:
> True, I'm sorry. I'm trying to install 3.4 Ganymede. But if Europa is
> easier to install. I my just install it (since I'm new to Eclipse,
> anyways).
> Thanks for the suggestion.
You can get PDT working in Ganymede without *too* much hassle; it's just
not as convenient as with Europa. The instructions at
http://wiki.eclipse.org/PDT/Installation worked for me.
> So you're saying that my workspace can be in a folder (~/Eclipse for
> example) and then my PHP files in /var/www/mysite and then import them
> into my project?
Yes.
> Does this mean that I can continue creating PHP files
> in Eclipse and they can be stored in /var/www/mysite rather than in
> ~/Eclipse ?
Yes (as long as that directory is writable by whatever account you're
using when you run Eclipse). When you create a new PHP project, the
wizard will ask you to provide a project name. In that dialog, you'll
see "Project contents" with a check on "Use default". Uncheck that and,
in the "Directory" entry, browse to /var/www/mysite. Eclipse will store
both some metadata (.project etc.) and your PHP files there.
Alternatively, you can create a new PHP project the usual way, then
right-click the project in the PHP Explorer view and use Build Path ->
Link Source to link /var/www/mysite to the project. Give the linked
directory a name within the project structure (which could be, say,
'mysite'). That will import whatever is in /var/www/mysite, and any
file you create inside Eclipse in the 'mysite' folder will sit in
/var/www/mysite. The difference with this approach is that the metadata
files will be parked somewhere in the Eclipse workspace, rather than in
/var/www/mysite, and you can create additional folders for the same
project that live in the Eclipse workspace rather than having to put
everything in /var/www/mysite.
/Paul
FUDForum. Page generated in 0.09359 seconds
