Home » Archived » BIRT » How can I build the BIRT viewer source code?
How can I build the BIRT viewer source code? [message #263200] Thu, 13 December 2007 08:12 Go to next message
Originally posted by: sprudhom.nortel.com
Sorry for the repost, the first time I sent this as a reply to another post.
Not the right way to do it.
Greetings,
I have successfully installed the BIRT viewer and created some reports. Now
I would like to do some customization of the viewer. Therefore I need to
build the source code.
I downloaded birt-report-designer-all-in-one-2.1.3.zip and I tried building
BIRT_2_1_3_Release_20070705 from CVS (I also tried building 2.2.1 with the
2.2.1 all-in-one but had some many problems I switched to 2.1.3 which seemed
more promising.)
I am using Sun Java SDK (and JRE) 1.4.2_16
I have followed the instructions here:
http://www.eclipse.org/birt/phoenix/build/buildInstructions. php
And the build of the overall project works but I cannot build the WebViewer.
When I invoke "ant.." on BuildWebViewer.xml as suggested on the web page I
get the following error (see below).
Question: what is the procedure to build the BIRT viewer? I see post/blogs
from different people on the web that did it so I know it is possible but
how??
I cannot find org.eclipse.birt.data.oda anywhere, where is that coming from?
Serge
Here is the build Error:
Buildfile: D:\Profiles\SPRUDHOM.AMERICASE\Eclipse
Workspaces\BIRT_2_1_3\org.eclipse.birt.report.viewer\BuildWe bViewer.xml
init:
[delete] Deleting directory D:\Profiles\SPRUDHOM.AMERICASE\Eclipse
Workspaces\BIRT_2_1_3\org.eclipse.birt.report.viewer\birt_we b
[copy] Copying 545 files to D:\Profiles\SPRUDHOM.AMERICASE\Eclipse
[copy] Copied 52 empty directories to 4 empty directories under
enginesdk:
[mkdir] Created dir: D:\Profiles\SPRUDHOM.AMERICASE\Eclipse
Workspaces\BIRT_2_1_3\org.eclipse.birt.report.viewer\birt_we b\WEB-INF\platform
ExportSDK:
Workspaces\BIRT_2_1_3\org.eclipse.birt.report.viewer\birt_we b\WEB-INF\platform\configuration
[copy] Copying 1 file to D:\Profiles\SPRUDHOM.AMERICASE\Eclipse
Workspaces\BIRT_2_1_3\org.eclipse.birt.report.viewer\birt_we b\WEB-INF\platform\plugins
[copy] Copying 25 files to D:\Profiles\SPRUDHOM.AMERICASE\Eclipse
[copy] Copying 9 files to D:\Profiles\SPRUDHOM.AMERICASE\Eclipse
Workspaces\BIRT_2_1_3\org.eclipse.birt.report.viewer\birt_we b\WEB-INF\platform\plugins\com.lowagie.itext
[copy] Copying 4 files to D:\Profiles\SPRUDHOM.AMERICASE\Eclipse
Workspaces\BIRT_2_1_3\org.eclipse.birt.report.viewer\birt_we b\WEB-INF\platform\plugins\org.apache.commons.codec
[copy] Copying 15 files to D:\Profiles\SPRUDHOM.AMERICASE\Eclipse
Workspaces\BIRT_2_1_3\org.eclipse.birt.report.viewer\birt_we b\WEB-INF\platform\plugins\org.apache.xerces
[copy] Copying 21 files to D:\Profiles\SPRUDHOM.AMERICASE\Eclipse
Workspaces\BIRT_2_1_3\org.eclipse.birt.report.viewer\birt_we b\WEB-INF\platform\plugins\org.apache.batik
[copy] Copying 6 files to D:\Profiles\SPRUDHOM.AMERICASE\Eclipse
Workspaces\BIRT_2_1_3\org.eclipse.birt.report.viewer\birt_we b\WEB-INF\platform\plugins\org.apache.batik.pdf
Workspaces\BIRT_2_1_3\org.eclipse.birt.report.viewer\birt_we b\WEB-INF\platform\plugins\org.mozilla.rhino
Workspaces\BIRT_2_1_3\org.eclipse.birt.report.viewer\birt_we b\WEB-INF\platform\plugins\org.w3c.sac
Workspaces\BIRT_2_1_3\org.eclipse.birt.report.viewer\birt_we b\WEB-INF\platform\plugins\org.apache.derby.core
init:
compileSource:
Jar:
Export:
[jar] Building jar: D:\Profiles\SPRUDHOM.AMERICASE\Eclipse
Workspaces\BIRT_2_1_3\org.eclipse.birt.report.viewer\birt_we b\WEB-INF\platform\plugins\org.eclipse.birt.core_2.1.3.quali fier.jar
BUILD FAILED
Workspaces\BIRT_2_1_3\org.eclipse.birt.report.viewer\BuildWe bViewer.xml:252:
The following error occurred while executing this line:
Workspaces\BIRT_2_1_3\org.eclipse.birt.report.engine\BuildEn gine.xml:346:
java.io.FileNotFoundException: D:\Profiles\SPRUDHOM.AMERICASE\Eclipse
Workspaces\BIRT_2_1_3\org.eclipse.birt.data.oda\BuildOda.xml (The system
cannot find the file specified)
Total time: 30 seconds
Re: How can I build the BIRT viewer source code? [message #263210 is a reply to message #263200] Thu, 13 December 2007 09:48 Go to previous message
Serge,
look Here
http://wiki.eclipse.org/BIRT/FAQ/Birt_Project#Q:_How_do_I_bu ild_the_2.2_BIRT_Viewer.3F
Jason
> Greetings,
> more promising.)
> how??
> Cheers,
> Serge
> init:
> enginesdk:
> ExportSDK:
> init:
> compileSource:
> Jar:
> Export:
> BUILD FAILED
Previous Topic:BIRT exception - flatfile data source is not valid
Next Topic:Chart with cross tab as source of data
Current Time: Sun Aug 31 10:27:44 EDT 2025
Powered by FUDForum. Page generated in 0.06741 seconds
