Home » Archived » BIRT » Chart with cross tab as source of data
Chart with cross tab as source of data [message #263193] Thu, 13 December 2007 05:06 Go to next message
Hi there,
I have created a cross tab in a report, and given it a name. I am now
trying to create a chart with the crosstab cube's dimension as the x-axis
and the crosstab cube's measure as the y-axis.
On the 'Select data' view when editing a chart, I selected the 'Use report
item' option, and specified the name of my cross tab. However, when I do
this the 'Data Preview' area is blank.
In addition, when I click 'Finish' I get a 'The chart has not yet been
bound to a Data Set' message. I selected 'Proceed without fixing', and
tried to preview the report, but I get the following exception:
org.eclipse.birt.report.service.api.ReportServiceException: Error happened
while running the report; nested exception is:
java.lang.ClassCastException:
[Lorg.eclipse.birt.data.engine.api.IDataQueryDefinition;
Are cross-tabs not yet supported as the source of data for a chart?
Alex
Re: Chart with cross tab as source of data [message #263226 is a reply to message #263193] Thu, 13 December 2007 10:38 Go to previous message
This is not supported yet, but will be in BIRT 2.3, we are working on it.
thanks,
David
"Alex" <alzadude@hotmail.co.uk> wrote in message
news:73852036b3e4071f32a16750785bc509$1@www.eclipse.org...
> Hi there,
> Thanks
> Alex
Previous Topic:How can I build the BIRT viewer source code?
Next Topic:Sampel ODA Driver Help
Current Time: Fri Jul 25 02:38:35 EDT 2025
Powered by FUDForum. Page generated in 0.02833 seconds
