Home » Archived » BIRT » Saving an HTML report for later web viewing
Saving an HTML report for later web viewing [message #262903] Fri, 07 December 2007 08:43 Go to next message
I have a web page that is currently using the birt-viewer application to
show an HTML report. Of course this dynamically recreates the report each
time the web page is accessed.
How do I run the report one, save as an HTML page, and then load into a
web page?
Re: Saving an HTML report for later web viewing [message #262909 is a reply to message #262903] Fri, 07 December 2007 10:10 Go to previous messageGo to next message
You would read your URL as follows:
URL url = new URL("http://localhost/viewer/run?__report=...");
URLConnection connection = url.openConnection();
InputStream in = new DataInputStream(url.getInputStream());
Snjeza
> web page?
Re: Saving an HTML report for later web viewing [message #262998 is a reply to message #262909] Mon, 10 December 2007 07:13 Go to previous messageGo to next message
What you are doing is effectively saving the source of the generated
report?
I think that does not work. The problem is that the viewer generates
DHTML with DIVs for the animated loading bar thing and dynamically
displays the report in another DIV and so on.
All I want is straight HTML code.
Re: Saving an HTML report for later web viewing [message #263006 is a reply to message #262998] Mon, 10 December 2007 09:56 Go to previous messageGo to next message
Instead of "run" you can use "preview"
http://localhost/viewer/prevuew?__report=...
Malte
> report?
Re: Saving an HTML report for later web viewing [message #263128 is a reply to message #263006] Wed, 12 December 2007 09:05 Go to previous messageGo to next message
Marvelous!
Are these things documented anywhere?
Re: Saving an HTML report for later web viewing [message #263134 is a reply to message #263128] Wed, 12 December 2007 09:47 Go to previous message
Here you can find some informations
http://www.eclipse.org/birt/phoenix/deploy/viewerUsage2.2.ph p
Rob Scott wrote:
> Marvelous!
Previous Topic:Birt in a java application
Next Topic:BIRT tool - deployment in ear file
Current Time: Wed Nov 19 08:09:30 EST 2025
Powered by FUDForum. Page generated in 0.05113 seconds
