Home » Newcomers » Newcomers » Software Update problem
Software Update problem [message #262895] Mon, 11 August 2008 14:45 Go to next message
When I launch (the latest) Europa and go to Help->SOftware Updates->Find
and Install, I get a spinning cursor for a couple of seconds, then no
window (I usually get one) and if I try it again, I get an alert message
to the effect that
Another install/update job is in progress. Please cancel it and the
re-launch this action. OK.
This hasn't happened to me before and now it's all that happens whenever I
launch Eclipse.
Thanks for the help.
Re: Software Update problem [message #262920 is a reply to message #262895] Tue, 12 August 2008 00:35 Go to previous message
did you try to start eclipse with the "-clean" option? This takes a
little longer, but should reinitialize your plug-ins on startup (at
least I didn't loose any plug-ins or settings, but got rid off an
installation problem as well with that option).
see
http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.platform.doc.user/tasks/running_eclipse.htm
Michael
Previous Topic:Build Path
Next Topic:Need help changing general font color in eclipse
Current Time: Sat Jul 26 23:05:01 EDT 2025
Powered by FUDForum. Page generated in 0.08503 seconds
