Home » Newcomers » Newcomers » Could not find the main class. Program will exit.
Could not find the main class. Program will exit. [message #262627] Wed, 06 August 2008 14:45 Go to next message
Originally posted by: djmunshi.yahoo.com
I've created a jar file from my project and when I double-click on it, it
gives this error.
The error goes away when I remove all the try-catch statements from the
code. I keep all my code, just remove the try statement and the catch
block.
I'm catching the Exception as in,
try
..some code...
catch (Exception e)
What is the reason ? Any help would be greatly appreciated.
Thanks so much,
Darius.
Re: Could not find the main class. Program will exit. [message #262630 is a reply to message #262627] Wed, 06 August 2008 16:24 Go to previous messageGo to next message
Originally posted by: cmattmiller.gmail.com
Darius Munshi wrote:
> Hello,
> gives this error.
> block.
> try
> ..some code...
> catch (Exception e)
> Thanks so much,
> Darius.
Where is your try/catch located? In Main?
Re: Could not find the main class. Program will exit. [message #262633 is a reply to message #262630] Wed, 06 August 2008 17:07 Go to previous message
The try-catch blocks are in public methods in the class that contains
main, but none are in main
Previous Topic:Whatever happened to a project that just produces a jar file?
Next Topic:Broken DHTML in Help system after upgrading to Eclipse 3.3
Current Time: Tue Nov 25 03:23:25 EST 2025
Powered by FUDForum. Page generated in 0.12765 seconds
