Home » Newcomers » Newcomers » texlipse plugin: delete previous version before updgrade?
texlipse plugin: delete previous version before updgrade? [message #262434] Sun, 03 August 2008 12:55 Go to next message
Originally posted by: shaziam.ifi.uio.no
Main problem is, In the navigator I see all the files from my workspace,
but the text editor come up with following error:
"unable to create this part due to an internal error. Reason for the
failure: the editor class could not be instantiated. The usually indicated
that the editor's class name was mistyped in the plugin.xml"
Now the system hangs with an pop-up window warning me about error
and it won't disappear.
How do I solve this problem?
It all happened after I have run version update.
First I ran version update for eclipse,
and after wards I ran upgrade for Latex plugin;
from version TeXlipse 1.1.0 to TeXlipse 1.2.2.
According to installation guide for TeXlipse 1.2.2
( url: http://texlipse.sourceforge.net/manual/installation.html)
I am supposed "0. Delete the previous version of TeXlipse..."
than run -clean and then fetch updates.
However, FAQ for eclipse
(url: http://wiki.eclipse.org/FAQ_How_do_I_remove_a_plug-in%3F)
tell me "You should not remove plug-ins from Eclipse...."
Thing is, I have updated the TeXlipse without removing the previous
version (and hoped for it should work)
Eclipse came up with some error and all functions to TeXplugin
from function bar are removed.
I have tried out dozens of different things to solve the problem,
One stunt I have tried is renaming the folder under
/eclipse/plugins/Net.sourceforge.texlipse_1.1.0
I have even tried to run new update after renaming the new folder
Net.sourceforge.texlipse_1.2.2. But its not working.
I hope someone can help me. I am not very much familiar with eclipse
and need to get started with writing my Tex-documents. Please help.
- sm
Re: texlipse plugin: delete previous version before updgrade? [message #262463 is a reply to message #262434] Mon, 04 August 2008 10:23 Go to previous messageGo to next message
Originally posted by: codeslave.ca.ibm.com
Assuming you installed texlipse into ~/eclipse/plugins/ and
~/eclipse/features... just search for folders or files called
"net.sourceforge.texlipse*" and delete them.
Then you can cleanly reinstall Texlipse 1.2.2 w/o there being any
leftover bits of 1.1.0 to conflict.
sm wrote:
> Hello,
> indicated that the editor's class name was mistyped in the plugin.xml"
> and after wards I ran upgrade for Latex plugin; from version TeXlipse
> However, FAQ for eclipse (url:
> Eclipse came up with some error and all functions to TeXplugin from
> I have tried out dozens of different things to solve the problem, One
> - sm
Nick Boldt :: Release Engineer, IBM Toronto Lab
Eclipse Modeling :: http://www.eclipse.org/modeling
http://wiki.eclipse.org/index.php/User:Nickb
Re: texlipse plugin: delete previous version before updgrade? [message #262665 is a reply to message #262463] Thu, 07 August 2008 09:12 Go to previous messageGo to next message
Originally posted by: Prof_NARF.hotmail.com
I have the exact same problem. After updating to the new version of
Texlipse in Eclipse 3.2. I get these strange error messages which reappear
each time I click OK. Removing the old plugins in the filesystem and
re-installing Texlipse did not solve the problem either.
Maybe a version problem, so Texlipse does not work with Eclipse 3.2
anymore?
Prof_NARF
Re: texlipse plugin: delete previous version before updgrade? [message #262667 is a reply to message #262665] Thu, 07 August 2008 09:17 Go to previous message
Yes, it was a version problem. Texlipse 1.2.2 needs Eclipse 3.3 or higher.
So I used 1.2.1 and everything works again now.
Hope that helps,
Prof_NARF
Previous Topic:Why aren't I seeing JAR files?
Next Topic:CDT indexer has no project #defines?
Current Time: Thu Jul 17 21:51:04 EDT 2025
Powered by FUDForum. Page generated in 0.12760 seconds
