Home » Archived » BIRT » Cant startup the OSGI framework
Cant startup the OSGI framework [message #261632] Mon, 19 November 2007 06:23 Go to next message
Originally posted by: peter.pmb.mine.nu
Hi again Birt users
I hope someone will be able to help me I am trying to get birt running in a WS web application in Geronimo v2.0.2 using
Birt v2.2.1.1 I have successfully fetched a ServlectContext object but for some reason the OSGI framework will not start up.
I have been following the servlet example on birt wiki http://wiki.eclipse.org/Servlet_Example_%28BIRT%29_2.1 I realize
that the example code is for birt 2.1 and I am therefore even more interested in getting some input from you all.
The layout is as described in the wiki example and below is a code snippet and the stack trace.
FYI I am running this on a ubuntu linux box and Geronimo is automatically extracting the war up on deployment don't know
if it has anything to do with things though ( and I doubt it ;) ).
thanks
Peter Petersson
EngineConfig config = new EngineConfig();
config.setEngineHome("");
IPlatformContext context = new PlatformServletContext(sc);
config.setPlatformContext(context);
try {
Platform.startup(config);
IReportEngineFactory factory = (IReportEngineFactory)
Platform.createFactoryObject(IReportEngineFactory.EXTENSION_ REPORT_ENGINE_FACTORY);
if(factory==null){logger.error("BirtEngine::getBirtEngine factory is null");}
birtEngine = factory.createReportEngine(config);
} catch (BirtException e) {
logger.error("BirtEngine::getBirtEngine ",e);
return birtEngine;
12:01:00,283 INFO [BirtEngine] BirtEngine::getBirtEngine logLevel=FINEST
12:01:00,392 ERROR [BirtEngine] BirtEngine::getBirtEngine
org.eclipse.birt.core.exception.BirtException: Cant startup the OSGI framework
at org.eclipse.birt.core.framework.Platform.startup(Platform.ja va:90)
at com.scandorama.ticket.reportgenrator.control.BirtEngine.getB irtEngine(BirtEngine.java:76)
at com.scandorama.ticket.reportgenrator.control.ReportGenerator .executeReport(ReportGenerator.java:91)
at com.scandorama.ticket.reportgenrator.control.ReportGenerator .createReport(ReportGenerator.java:63)
at com.scandorama.ticket.jws.TicketService.create(TicketService .java:95)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.apache.axis2.jaxws.server.dispatcher.JavaBeanDispatcher. invokeService(JavaBeanDispatcher.java:163)
at org.apache.axis2.jaxws.server.dispatcher.JavaBeanDispatcher. invoke(JavaBeanDispatcher.java:90)
at org.apache.axis2.jaxws.server.EndpointController.invoke(Endp ointController.java:172)
at org.apache.axis2.jaxws.server.JAXWSMessageReceiver.receive(J AXWSMessageReceiver.java:113)
at org.apache.axis2.engine.AxisEngine.receive(AxisEngine.java:1 45)
at org.apache.axis2.transport.http.HTTPTransportUtils.processHT TPPostRequest(HTTPTransportUtils.java:275)
at org.apache.geronimo.axis2.pojo.POJOWebServiceContainer.proce ssPOSTRequest(POJOWebServiceContainer.java:114)
at org.apache.geronimo.axis2.Axis2WebServiceContainer.doService 2(Axis2WebServiceContainer.java:248)
at org.apache.geronimo.axis2.Axis2WebServiceContainer.doService (Axis2WebServiceContainer.java:205)
at org.apache.geronimo.axis2.Axis2WebServiceContainer.invoke(Ax is2WebServiceContainer.java:167)
at org.apache.geronimo.webservices.WebServiceContainerInvoker.s ervice(WebServiceContainerInvoker.java:84)
at org.apache.geronimo.webservices.POJOWebServiceServlet.servic e(POJOWebServiceServlet.java:79)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(App licationFilterChain.java:206)
at org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.java:230)
at org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.java:175)
at org.apache.geronimo.tomcat.valve.DefaultSubjectValve.invoke( DefaultSubjectValve.java:56)
at org.apache.geronimo.tomcat.GeronimoStandardContext$SystemMet hodValve.invoke(GeronimoStandardContext.java:353)
at org.apache.geronimo.tomcat.valve.GeronimoBeforeAfterValve.in voke(GeronimoBeforeAfterValve.java:47)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:128)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorRepo rtValve.java:104)
at org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java:109)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogVa lve.java:563)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAd apter.java:261)
at org.apache.coyote.http11.Http11Processor.process(Http11Proce ssor.java:844)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHand ler.process(Http11Protocol.java:581)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoin t.java:447)
at java.lang.Thread.run(Thread.java:595)
Caused by: org.eclipse.birt.core.exception.BirtException: Can not start up OSGI - null
at org.eclipse.birt.core.framework.osgi.OSGILauncher.startup(OS GILauncher.java:169)
at org.eclipse.birt.core.framework.Platform.startup(Platform.ja va:78)
... 36 more
Re: Cant startup the OSGI framework [message #261661 is a reply to message #261632] Mon, 19 November 2007 11:26 Go to previous messageGo to next message
It seems the initPropertiesMethod.invoke( null, new Object[]{properties} ); method is throwing a exception and
the catch below is throwing it with PluginId="org.eclipse.birt.core".
I would be great full if anyone with knowledge of the OSGILauncher or what may cause the invoke method to throw a
exception (could not debug it) could shed some light over this !?
thanks
Peter Petersson
if ( initPropertiesMethod != null )
System.setProperty(
"osgi.framework.useSystemProperties", "false" ); //$NON-NLS-1$ //$NON-NLS-2$
properties.put( "osgi.framework.useSystemProperties", "false" );
====throws====>>>>>>>> initPropertiesMethod.invoke( null, new Object[]{properties} );
else
Iterator iter = properties.entrySet( ).iterator( );
while ( iter.hasNext( ) )
Map.Entry entry = (Map.Entry) iter.next( );
String key = (String) entry.getKey( );
String value = (String) entry.getValue( );
System.setProperty( key, value );
System.setProperty(
"osgi.framework.useSystemProperties", "true" ); //$NON-NLS-1$ //$NON-NLS-2$
Method runMethod = clazz.getMethod(
"startup", new Class[]{String[].class, Runnable.class} ); //$NON-NLS-1$
bundleContext = runMethod.invoke( null, new Object[]{new String[]{}, null} );
frameworkContextClassLoader = Thread.currentThread( )
.getContextClassLoader( );
catch ( Exception e )
throw new BirtException( PluginId, "Can not start up OSGI - {0}", e
.getLocalizedMessage( ) );
Peter Petersson wrote:
> Hi again Birt users
> in a WS web application in Geronimo v2.0.2 using Birt v2.2.1.1 I have
> http://wiki.eclipse.org/Servlet_Example_%28BIRT%29_2.1 I realize that
> automatically extracting the war up on deployment don't know if it has
> thanks
> Peter Petersson
> try {
> null");}
> birtEngine =
> return birtEngine;
> framework
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> up OSGI - null
> at
> at
> ... 36 more
Re: Cant startup the OSGI framework [message #261770 is a reply to message #261661] Tue, 20 November 2007 10:39 Go to previous messageGo to next message
Peter,
In your example do you have a configuration directory in the
web-inf/platform directory?
Jason
> what may cause the invoke method to throw a exception (could not debug
> thanks
> Peter Petersson
> System.setProperty(
> "false" );
> else
> System.setProperty(
> {0}", e
>> Hi again Birt users
>> thanks
>> Peter Petersson
>> try {
>> null");}
>> birtEngine =
>> factory.createReportEngine(config); } catch
>> (BirtException e) {
>> return birtEngine;
>> framework
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 36 more
Re: Cant startup the OSGI framework [message #261790 is a reply to message #261661] Tue, 20 November 2007 11:39 Go to previous messageGo to next message
I have now found out exactly what is going wrong (I think) but I still need some help resolving the problem.
Via a System.getProperties call in the method setupOSGiProperties() (in
org.eclipse.birt.core.framework.osgi.OSGILauncher.java) a propertie that is not a String but a HashSet is set and
processed by the initPropertiesMethod.invoke( null, new Object[]{properties} ); method and the OSGILauncher throws a
exception a java.lang.ClassCastException that is beening masked to "Cant startup the OSGI framework".
In my case the offending key/value par is key="org.apache.activeio.journal.active.lockMap" value=HashSet<E>
As I understand it a system propertie should not be anything but a String but clearly not everyone share that view :) so
maybe a patch like "value instanceof String" check should be done also for system properties as it is done for the
osgiConfig properties? in Birt v2.2.1.2 ?
I should probably contact the Geronimo list to see if there is someway to remove/replace the HashSet propertie but if
someone here knows a solution please share it with me/us!
thanks
Peter Petersson
public void startup( PlatformConfig config ) throws BirtException
if ( frameworkClassLoader != null )
logger.log( Level.WARNING, "Framework is already started" ); //$NON-NLS-1$
return;
platformConfig = config;
IPlatformContext context = config.getPlatformContext( );
if ( context == null )
PluginId,
"PlatformContext is not setted - {0}", new Object[]{"PlatformConfig"} ); //$NON-NLS-1$
// process install.area
String root = context.getPlatform( );
platformDirectory = new File( root );
if ( !platformDirectory.exists( ) || !platformDirectory.isDirectory( ) )
"Could not start the Framework - {0}" + root, root ); //$NON-NLS-1$
String path = new File( platformDirectory, "plugins" ).toString( ); //$NON-NLS-1$
path = searchFor( "org.eclipse.osgi", path ); //$NON-NLS-1$
if ( path == null )
PluginId,
"Could not find the Framework - {0}", "org.eclipse.osgi" ); //$NON-NLS-1$
try
osgiFramework = new File( path ).toURL( );
catch(MalformedURLException ex)
//cannot be here
ClassLoader original = Thread.currentThread( ).getContextClassLoader( );
try
ClassLoader loader = this.getClass( ).getClassLoader( );
frameworkClassLoader = new ChildFirstURLClassLoader(
new URL[]{osgiFramework}, loader );
// frameworkClassLoader = new OSGIClassLoader(
// new URL[]{frameworkUrl}, loader );
// Weblogic 8.1SP6 contains old version JS.JAR, we need
// set pref-web-inf to true, if we set it to true, the
// URL classloader still loads the JS in weblogic, so
// load the class explicitly.
try
loader.loadClass( "org.mozilla.javascript.Context" );
loader.loadClass( "org.mozilla.javascript.Scriptable" );
loader.loadClass( "org.mozilla.javascript.ScriptableObject" );
// frameworkClassLoader.loadClass(
// "org.mozilla.javascript.Context"
catch ( Exception ex )
Class clazz = frameworkClassLoader.loadClass( ECLIPSE_STARTER );
setupOSGiProperties();
Method initPropertiesMethod = clazz.getMethod(
"setInitialProperties", new Class[]{Map.class} ); //$NON-NLS-1$
System.setProperty(
====throws==>> initPropertiesMethod.invoke( null, new Object[]{properties} );
else
System.setProperty(
finally
Thread.currentThread( ).setContextClassLoader( original );
private void setupOSGiProperties()
properties = new HashMap( );
//copy all system properties to the property.
Properties systemProperties = System.getProperties( );
if ( systemProperties != null )
for ( Iterator it = systemProperties.entrySet( ).iterator( ); it
.hasNext( ); )
Map.Entry entry = (Map.Entry) it.next( );
Object value = entry.getValue( );
if ( !key.startsWith( "osgi." ) && !key.startsWith( "eclipse." )
&& !key.startsWith( "org.osgi." ) )
===Sets HashSet==>> properties.put( key, value );
else
properties.put( key, null );
//load the config.ini distribued with BIRT system.
File configFolder = new File( platformDirectory, CONFIG_FOLDER );
try
HashMap configProps = loadConfiguration( configFolder.toURL( ) );
properties.putAll( configProps );
catch(Exception ex){/* do nothing */}
//copy properties defined by the caller
Map osgiConfig = platformConfig.getOSGiConfig( );
if ( osgiConfig != null )
Iterator iter = osgiConfig.entrySet( ).iterator( );
Object key = entry.getKey( );
if ( key instanceof String )
if ( value == null || value instanceof String )
//set up the properied defined by BIRT
/* osgi.install.area, always using the one defined by BIRT_HOME. */
properties.put( PROP_OSGI_INSTALL_AREA, platformDirectory
.getAbsolutePath( ) ); //$NON-NLS-1$
/* setup the osgi framework, it is the osgi.jar in the platform/plugins */
properties.put( "osgi.framework", osgiFramework.toExternalForm( ) ); //$NON-NLS-1$//$NON-NLS-2$
/* setup the config area, it is the /configuration under platform */
String configArea = getProperty( properties, PROP_OSGI_CONFIGURATION_AREA );
if (configArea == null)
File configDirectory = new File (platformDirectory, CONFIG_FOLDER );
properties.put( PROP_OSGI_CONFIGURATION_AREA, configDirectory.getAbsolutePath( ) );
// instance.area, it is the workspace under platform
String instanceArea = getProperty( properties, PROP_OSGI_INSTANCE_AREA );
if ( instanceArea == null )
File workspaceDirectory = new File( platformDirectory, INSTANCE_FOLDER ); //$NON-NLS-1$
if ( !workspaceDirectory.exists( ) )
workspaceDirectory.mkdirs( );
properties.put( PROP_OSGI_INSTANCE_AREA, workspaceDirectory
properties.put( PROP_ECLIPSE_IGNOREAPP, "true" );//$NON-NLS-1$
properties.put( PROP_OSGI_NOSHUTDOWN, "true" ); //$NON-NLS-1$
//set -clean if the user doens't define it.
String clean = getProperty(properties, PROP_OSGI_CLEAN);
if (clean == null)
properties.put( PROP_OSGI_CLEAN, "true" );
> thanks
> Peter Petersson
> System.setProperty(
> "false" );
> else
> System.setProperty(
> {0}", e
>> Hi again Birt users
>> thanks
>> Peter Petersson
>> try {
>> null");}
>> birtEngine =
>> (BirtException e) {
>> return birtEngine;
>> framework
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 36 more
Re: Cant startup the OSGI framework [message #261793 is a reply to message #261770] Tue, 20 November 2007 11:44 Go to previous messageGo to next message
Jason Weathersby wrote:
> Peter,
Thanks for your responce Jason, yes I have containing a config.ini file with the following content
#Product Runtime Configuration File
eclipse.product=org.eclipse.birt.report.engine.ReportEngineS DK
osgi.bundles=org.eclipse.equinox.common@2:start, org.eclipse.update.configurator@start, org.eclipse.birt.core@start
osgi.framework.extensions=org.eclipse.birt.api
osgi.bundles.defaultStartLevel=4
As you can see in my last/next post I have found out what is going on.
thanks
Peter Petersson
> Jason
>> thanks
>> Peter Petersson
>> System.setProperty(
>> "false" );
>> else
>> System.setProperty(
>> - {0}", e
>>> Hi again Birt users
>>> running in a WS web application in Geronimo v2.0.2 using Birt
>>> thanks
>>> Peter Petersson
>>> try {
>>> null");}
>>> birtEngine =
>>> (BirtException e) {
>>> return birtEngine;
>>> logLevel=FINEST
>>> framework
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 36 more
Re: Cant startup the OSGI framework [message #261800 is a reply to message #261790] Tue, 20 November 2007 11:53 Go to previous messageGo to next message
Here is a Geronimo GIRA on the matter apparently it is a ActiveMQ propertie.
http://www.mail-archive.com/dev@geronimo.apache.org/msg47532 .html
I will now seek help on the Geronimo list to see if I somehow can remove the offending propertie.
thanks
Peter
> is not a String but a HashSet is set and processed by the
> and the OSGILauncher throws a exception a java.lang.ClassCastException
> String but clearly not everyone share that view :) so maybe a patch like
> properties as it is done for the osgiConfig properties? in Birt v2.2.1.2 ?
> to remove/replace the HashSet propertie but if someone here knows a
> thanks
> Peter Petersson
> //$NON-NLS-1$
> return;
> PluginId,
> ); //$NON-NLS-1$
> ); //$NON-NLS-1$
> if ( path == null )
> PluginId,
> try
> //cannot be here
> try
> try
> loader.loadClass(
> ECLIPSE_STARTER );
> //$NON-NLS-1$
> System.setProperty(
> "false" );
> else
> System.setProperty(
> {0}", e
> finally
> ); it
> .hasNext( ); )
> "eclipse." )
> else
> try
> platform/plugins */
> platform */
> CONFIG_FOLDER );
> if (clean == null)
>> thanks
>> Peter Petersson
>> System.setProperty(
>> "false" );
>> else
>> System.setProperty(
>> - {0}", e
>>> Hi again Birt users
>>> thanks
>>> Peter Petersson
>>> try {
>>> null");}
>>> birtEngine =
>>> (BirtException e) {
>>> return birtEngine;
>>> logLevel=FINEST
>>> framework
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 36 more
Re: Cant startup the OSGI framework [message #261818 is a reply to message #261800] Tue, 20 November 2007 14:53 Go to previous message
Just for the record: Problem solved
Workaround was to set "-Dorg.apache.activeio.journal.active.DisableLocking=true" in JAVA_OPTS read by Geronimo.
Newer version (5.0) of ActiveMQ has fixed the problem.
Cheers
Peter Petersson
> propertie.
> thanks
> Peter
>> (in org.eclipse.birt.core.framework.osgi.OSGILauncher.java) a
>> propertie that is not a String but a HashSet is set and processed by
>> method and the OSGILauncher throws a exception a
>> v2.2.1.2 ?
>> thanks
>> Peter Petersson
>> ); //$NON-NLS-1$
>> return;
>> PluginId,
>> ); //$NON-NLS-1$
>> if ( path == null )
>> PluginId,
>> try
>> //cannot be here
>> try
>> try
>> loader.loadClass(
>> ECLIPSE_STARTER );
>> //$NON-NLS-1$
>> System.setProperty(
>> "false" );
>> else
>> System.setProperty(
>> - {0}", e
>> finally
>> ); it
>> .hasNext( ); )
>> "eclipse." )
>> else
>> try
>> BIRT_HOME. */
>> platform/plugins */
>> platform */
>> CONFIG_FOLDER );
>> if (clean == null)
>>> thanks
>>> Peter Petersson
>>> System.setProperty(
>>> "false" );
>>> else
>>> System.setProperty(
>>> - {0}", e
>>>> Hi again Birt users
>>>> thanks
>>>> Peter Petersson
>>>> try {
>>>> null");}
>>>> birtEngine =
>>>> return birtEngine;
>>>> logLevel=FINEST
>>>> framework
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> ... 36 more
Previous Topic:Problem While Rendering Report from Report design file
Next Topic:BIRT OutOfMemoryError
Current Time: Thu Oct 16 06:04:35 EDT 2025
Powered by FUDForum. Page generated in 0.04857 seconds
