Home » Newcomers » Newcomers » JBoss server hangs in state "starting"
JBoss server hangs in state "starting" [message #261587] Mon, 21 July 2008 07:30 Go to next message
Originally posted by: mike_e_price.hotmail.com
I am running eclipse 3.3.2 with a runtime and server configured with JBoss
4.2.2.
It has been working fine for some time. Now when I start the server, using
the JBoss server view, the server actually starts and I can run web
applications that are deployed to JBoss but the server status hangs in
"starting" state. Becuase of this I can't do other server operations while
I am trying to develop and deploy my application.
I deleted and rebuilt the workspace from scratch and it still does it.
Also if I just start JBoss from the command line - no problems. But then I
don't have the advantages of running it in eclipse.
Re: JBoss server hangs in state "starting" [message #261608 is a reply to message #261587] Mon, 21 July 2008 11:17 Go to previous messageGo to next message
> "starting" state.
One possibility for that symptom is the amount of time Eclipse waits for the
server to start. On the Preferences dialog, under 'Server', you can
set 'Server timeout delay' to various things. Those things aren't numbers,
unfortunately, but through some experimenting I settled on 'Longer' when I
encountered something like what you describe.
Re: JBoss server hangs in state "starting" [message #267431 is a reply to message #261608] Thu, 01 January 2009 20:35 Go to previous messageGo to next message
>> "starting" state.
Was this problem ever resolved?
I have this problem now with eclipse 3.4.1 and JBoss 4.2.2.
The timeouts are no longer configured via the Preference dialog, but
directly specified in the server configuration. It is a single number now
and I've put it to the maximum (1800 seconds). The console output finishes
with:
02:24:03,584 INFO [Server] JBoss (MX MicroKernel) [4.2.2.GA (build:
SVNTag=JBoss_4_2_2_GA date=200710221139)] Started in 48s:151ms
The server listed in the server tab hangs in state "starting". Actually,
the server is fully operational, but it shuts down when the specified
timeout expires.
Re: JBoss server hangs in state "starting" [message #267462 is a reply to message #267431] Mon, 05 January 2009 09:18 Go to previous messageGo to next message
>>> using
>>> "starting" state.
>> for the
>> numbers,
>> when I
You should probably ask on the eclipse.webtools newsgroup, where the JEE
and app server integration plugins (collectively known as WTP) are
usually discussed.
Eric
> now and I've put it to the maximum (1800 seconds). The console output
> finishes with:
> timeout expires.
Re: JBoss server hangs in state "starting" [message #267472 is a reply to message #267462] Mon, 05 January 2009 14:22 Go to previous message
Originally posted by: nickboldt+eclipse+newsgroup.gmail.com
Better yet, for JBoss Tools or JBoss Developer Studio issues, please use
these forums:
http://www.jboss.com/index.html?module=bb&op=main&c= 20
Nick
>>>> using
>>>> "starting" state.
>>> for the
>>> numbers,
>>> when I
> usually discussed.
> Eric
>> finishes with:
>> timeout expires.
Nick Boldt :: http://wiki.eclipse.org/User:Nickb
Previous Topic:Can't debug Qt program
Next Topic:Getting JPA to work in Eclipse
Current Time: Sun Nov 23 09:28:12 EST 2025
Powered by FUDForum. Page generated in 0.10271 seconds
