Home » Archived » BIRT » UNSUPPORTED_VERSION exception
UNSUPPORTED_VERSION exception [message #261327] Tue, 13 November 2007 11:12 Go to next message
Originally posted by: spap13.gmail.com
I updated birt through the eclipse update manager (eclipse 3.3.1).
I use eclipse only for designing the reports, while the web application
is running from IBM RAD. Now when i am trying to run the report from the
application i get the UNSUPPORTED_VERSION (3.1.5 or 2- if i am not
mistaken,
don't have it in fron of me right now) exception. Within eclipse the
preview
report works fine.
I am really not sure how to take action. I am not sure whether the
reports are compiled twice or something..once in Eclipse and once in RAD
and i do
not want to delete or replace files in any of the plugin directories and
end up
with a bigger mess...
Any advice that could help will be much appreciated...
Thanks in advance
Spiros P.
Re: UNSUPPORTED_VERSION exception [message #261494 is a reply to message #261327] Thu, 15 November 2007 12:04 Go to previous message
Spiros,
Its sounds like your runtime and your designer are two different
versions of BIRT. The runtime must be older. BIRT reports are not
compiled and the version is at the top of the report. When the engine
runs it checks this version. You probably need to download the older
version of the designer or update your runtime to the latest version.
Jason
Spiros Papadopoulos wrote:
> mistaken,
> preview
> report works fine.
> and i do
> end up
> Thanks in advance
> Spiros P.
Previous Topic:showing one header row
Next Topic:Comparators
Current Time: Mon Jul 21 22:24:16 EDT 2025
Powered by FUDForum. Page generated in 0.03178 seconds
