Problem with my plugin in RCP designer [message #261312] |
Tue, 13 November 2007 06:04  |
Originally posted by: guy.desvignes.centraliens.net
I wrote a Datasource plugin inspired from
org.eclipse.birt.report.data.oda.sampledb. It works fine under Eclipse
platform, but when I install it under RCP designer, I get an error :
!SESSION 2007-11-13 10:11:59.984
eclipse.buildId=unknown
java.version=1.6.0_02
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=fr_FR
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.ui 4 0 2007-11-13 10:12:27.140
!MESSAGE Unhandled event loop exception
!STACK 0
java.lang.NoClassDefFoundError: org/eclipse/core/runtime/Platform
com.vermeg.omega.birt.datasource.ConnectionFactory$OracleCla ssLoader. <init>(ConnectionFactory.java:164)
It seems Platform class is not found but I don't know why. Can some body
help me?
Re: Problem with my plugin in RCP designer [message #261543 is a reply to message #261418] |
Fri, 16 November 2007 08:24  |
Thanks for your answer,
Yes, BIRT_HOME is set, but there is something ever stranger (at least for
me) :
I tried to recompile org.eclipse.birt.report.data.oda.sampledb plugin with
3.2 or 3.3 eclipse version. I installed my plugin version and I get the
very same error. Does this mean I have to recompile RCP designer as well
if I just want to add a plugin ? Are there some compilation options in my
environment I have to set to a specific value ...
Any clue is welcome
FUDForum. Page generated in 0.27713 seconds
