Home » Eclipse Projects » Eclipse Platform » can't find class IFile
| can't find class IFile [message #261193] |
Tue, 13 July 2004 11:39  |
I'm encountering an odd problem. I'm running our application in the
debugger. When I go to load my wizard, I get an error stating
org/eclipse/core/resources/IFile can not be found.
I made sure that org.eclipse.core.resource was a required plugin in my
plugin file:
<requires>
<import plugin="org.eclipse.core.boot"/>
<import plugin="org.eclipse.core.resources"/>
<import plugin="org.eclipse.core.runtime"/>
I also have org.eclipse.core.resources checked as a visible plugin from
the debug wizard menu, so it should load it fine.
Other than that, I don't see why it can't find it.
Here is a snippet of the log:
!SESSION Jul 13, 2004 11:33:35.609
java.version=1.4.1_02
Command-line arguments: -pdelaunch -dev bin,runtime -feature
org.eclipse.platform -data C:\ADE\runtime-workspace -os win32 -ws win32
-arch x86 -nl en_US -configuration
file:C:/ADE/workspace/.metadata/.plugins/org.eclipse.pde.cor e/C__ADE_runtime-workspace/platform.cfg
-install file:C:/ADE/
!ENTRY org.eclipse.ui.workbench 4 2 Jul 13, 2004 11:33:35.609
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.ui.workbench".
!STACK 0
java.lang.NoClassDefFoundError: org/eclipse/core/resources/IFile
com.avaya.ade.core.ui.wizards.ADEProjectWizard.<init>(ADEProjectWizard.java:93)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Nativ e Method)
sun.reflect.NativeConstructorAccessorImpl.newInstance(Native ConstructorAccessorImpl.java:39)
sun.reflect.DelegatingConstructorAccessorImpl.newInstance(De legatingConstructorAccessorImpl.java:27)
at java.lang.reflect.Constructor.newInstance(Constructor.java:2 74)
at java.lang.Class.newInstance0(Class.java:306)
| Re: can't find class IFile [message #261206 is a reply to message #261193] |
Tue, 13 July 2004 12:04   |
Originally posted by: ddmonner.rockwellcollins.com
It looks like you're trying to create an IFile, which is an interface, not a
class. To get an IFile (representing a file in the Eclipse workspace), you
have to get the workspace root and then call getFile("filename") on it:
IFile myIFile =
ResourcesPlugin.getWorkspace().getRoot().getFile("myFileName ");
Then, you can create it (if it doesn't exist) or open it:
if(myIFile.exists())
... = myIFile.getContents();
else
myIFile.create(...);
Hope that helps.
Derek Monner
"NG" <neilg@avaya.com> wrote in message news:cd0vna$1ub$1@eclipse.org...
> plugin file:
> <requires>
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> !STACK 0
> at
93)
> at
sorImpl.java:39)
> at
| Re: can't find class IFile [message #261252 is a reply to message #261206] |
Tue, 13 July 2004 13:38   |
Thanks for the reply.
I am using it as you mentioned:
modelFile =
ResourcesPlugin.getWorkspace().getRoot().getFile(projpath.ap pend(ADE.NAVIGATOR_FILE_NAME));
The problem stems from the fact it doesn't even find the definition of
IFile. It gives a noclassdef error even though I have the resources
plugin available.
Is there anyplace else I might have to setup something up to find that
plugin?
> IFile myIFile =
> else
> Hope that helps.
> Derek Monner
> > plugin file:
> > <requires>
> > org.eclipse.platform -data C:ADEruntime-workspace -os win32 -ws win32
> > !STACK 0
> > at
> 93)
> > at
> sorImpl.java:39)
> > at
| Re: can't find class IFile [message #261260 is a reply to message #261252] |
Tue, 13 July 2004 13:56  |
Ah, looks like I solved it. There was another plugin that was loaded by
this one that required the resources plugin and it wasn't in that plugins
list of required.
> modelFile =
> plugin available.
> plugin?
a
> > IFile myIFile =
> > else
> > Hope that helps.
> > Derek Monner
> > > plugin file:
> > > <requires>
> > > !STACK 0
> > > at
> > 93)
> > > at
> > sorImpl.java:39)
> > > at
Current Time: Tue Nov 18 21:14:38 EST 2025
Powered by FUDForum. Page generated in 0.06580 seconds
