NoSuchMethodException when creating report engine [message #261053] |
Fri, 09 November 2007 12:39  |
Originally posted by: joglekar_amit.yahoo.com
I am getting NoSuchMethodException when instantiating report engine. I am
using BIRT runtime version 2.1.2. Following is the stack trace.
java.lang.NoSuchMethodException:
org.eclipse.core.runtime.adaptor.EclipseStarter.setInitialPr operties(java.util.Map)
at java.lang.Class.throwNoSuchMethodException(Class.java:275)
at java.lang.Class.getMethod(Class.java:780)
org.eclipse.birt.core.framework.osgi.OSGILauncher.startup(OS GILauncher.java:143)
at org.eclipse.birt.core.framework.Platform.startup(Platform.ja va:77)
at org.eclipse.birt.core.framework.Platform.initialize(Platform .java:115)
org.eclipse.birt.report.engine.api.ReportEngine.<init>(ReportEngine.java:50)
This is how I am trying to create an engine instance:
EngineConfig config = new EngineConfig();
config.setEngineHome("C:\\birt\\birt-runtime-2_1_2\\ReportEngine ");
ReportEngine engine = new ReportEngine(config);
Has anybody seen this type of error before? I suspect that this is a setup
issue, but don't know what is the cause. Any clues?
Amit
Re: NoSuchMethodException when creating report engine [message #261067 is a reply to message #261053] |
Fri, 09 November 2007 13:01  |
Amit,
Have you modified the version of eclipse in your 2.1.2 runtime?
Try this code to get the engine
IReportEngine engine=null;
EngineConfig config = null;
try{
config = new EngineConfig( );
config.setBIRTHome(" C:/birt/birt-runtime-2.2.0m5rc/birt-runtime-2_2_0/ReportEngi ne ");
config.setLogConfig(null, Level.FINE);
Platform.startup( config );
IReportEngineFactory factory = (IReportEngineFactory) Platform
.createFactoryObject(
IReportEngineFactory.EXTENSION_REPORT_ENGINE_FACTORY );
engine = factory.createReportEngine( config );
}catch( Exception ex){
ex.printStackTrace();
Obviously change your birt home.
Jason
Amit wrote:
> am using BIRT runtime version 2.1.2. Following is the stack trace.
> at
> at
> setup issue, but don't know what is the cause. Any clues?
> Amit
FUDForum. Page generated in 0.04517 seconds
