Home » Eclipse Projects » Eclipse Platform » Help needed getting started with a new application
Help needed getting started with a new application [message #261051] Tue, 13 July 2004 05:47 Go to next message
Originally posted by: john.turnbull.nospam.name
I am very new to Eclipse and would like some guidance. I wish to develop an
application whose interface is very similar to the IDE with a number of
resizable panels each with a tabbed pane in it but which must be able to run
outside of Eclipse itself.
Where do I start, just broadly speaking? Could someone direct me to those
areas of the source which are relevant to building an interface of that
kind?
Your help would be greatly appreciated as the amount of available source to
go through is imposing.
-JT
Re: Help needed getting started with a new application [message #261060 is a reply to message #261051] Tue, 13 July 2004 06:12 Go to previous message
> an application whose interface is very similar to the IDE with a number of
> run outside of Eclipse itself.
> kind?
> to go through is imposing.
> -JT
You might want to read up on RCP, the Rich Client Platform. This provides
the framework in which Eclipse runs, but without the application. So all
this work is done for you. You will find lots of references to it on the
Eclipse web site and in the archive for this newsgroup.
David
Previous Topic:No output from eclipse test framework
Next Topic:All new to me
Current Time: Thu Nov 13 13:53:21 EST 2025
Powered by FUDForum. Page generated in 0.05614 seconds
