Home » Newcomers » Newcomers » Searching through my project
Searching through my project [message #261042] Mon, 14 July 2008 11:43 Go to next message
Hi, I have a properties file in my Java project open. I want to search
for instances of a property "MY_PROP" in my project, but when I highlight
"MY_PROP" and right click on it, I don't see a "References" sub-item as I
do with code snippets.
How do I search through my project for references to "MY_PROP"?
Thanks, - Dave
Re: Searching through my project [message #261050 is a reply to message #261042] Mon, 14 July 2008 11:59 Go to previous messageGo to next message
> search for instances of a property "MY_PROP" in my project, but when I
> highlight "MY_PROP" and right click on it, I don't see a "References"
> sub-item as I do with code snippets.
Simply Ctrl+Click on the key. This will take you directly to the
location(s) where it is used. Alternatively you can perform a text
search (Ctr+H).
Dani
> Thanks, - Dave
Re: Searching through my project [message #261072 is a reply to message #261050] Mon, 14 July 2008 13:23 Go to previous messageGo to next message
Originally posted by: srikanth.m.mailcity.com
If I have to search within a file using Ctrl-K. By default eclipse does
not wrap the search and start from beginning.
Is there any option to enable this?
Thanks in advance.
Srikanth
Re: Searching through my project [message #261089 is a reply to message #261072] Mon, 14 July 2008 15:29 Go to previous message
Originally posted by: codeslave.ca.ibm.com
CTRL-K just redoes the last search as configured by CTRL-F. Whatever
settings you have there (regex, wrap, case sensitive) will be applied to
CTRL-K / CTRL-SHIFT-K.
> Thanks in advance.
> Srikanth
Nick Boldt :: Release Engineer, IBM Toronto Lab
Eclipse Modeling :: http://www.eclipse.org/modeling
http://wiki.eclipse.org/index.php/User:Nickb
Previous Topic:Language Fragments in 3.3 or 3.4
Next Topic:Ant editor outline view support for ant-contrib?
Current Time: Sun Aug 31 21:26:00 EDT 2025
Powered by FUDForum. Page generated in 0.21661 seconds
