Home » Eclipse Projects » Eclipse Platform » RCP & Undo Action Label problem
RCP & Undo Action Label problem [message #261037] Tue, 13 July 2004 05:09 Go to next message
I am trying to internationlize my RCP application but I do not succeed to
display default actions like cut/copy/paste in a MenuManager in another
language than english.
The setText() on IWorkbenchAction seems to do not have effects.
Does anyone have a solution ?
Here is my code :
MenuManager menu = new MenuManager(TodanAppMessages.EDIT_MENU_LABEL,
IWorkbenchActionConstants.M_EDIT);
menu.add(new GroupMarker(IWorkbenchActionConstants.EDIT_START));
ActionFactory.IWorkbenchAction undo = ActionFactory.UNDO.create(window);
undo.setText(TodanAppMessages.EDIT_UNDO_ITEM_LABEL);
undo.setToolTipText(TodanAppMessages.EDIT_UNDO_ITEM_LABEL);
menu.add(undo);
Re: RCP & Undo Action Label problem [message #261066 is a reply to message #261037] Tue, 13 July 2004 06:00 Go to previous messageGo to next message
Originally posted by: scheglov_ke.nlmk.ru
Stephane fournier <stephane.fournier@netcourrier.com> wrote:
I am sure there are some articles about this, but I just get
messages.properties from org.ui.workbench.messages (from package
org.eclipse.ui.internal), rename it to messages_ru.properties and change
messages for actions and other Eclipse elements. I place this file in
separate fragment plugin.
> Here is my code :
> menu.add(undo);
SY, Konstantin.
Advanced Eclipse SWT Designer (http://www.swt-designer.com)
Re: RCP & Undo Action Label problem [message #261202 is a reply to message #261066] Tue, 13 July 2004 11:48 Go to previous message
Thanks it works !!
> > Here is my code :
> > menu.add(undo);
Previous Topic:Exception launching Eclipse Platform
Next Topic:Problems kicking the compatibility habit
Current Time: Mon Sep 01 05:08:26 EDT 2025
Powered by FUDForum. Page generated in 0.04963 seconds
