Home » Archived » BIRT » Chart width in '%' no longer allowed with BIRT 2.2.1?
Chart width in '%' no longer allowed with BIRT 2.2.1? [message #261004] Thu, 08 November 2007 23:57 Go to next message
Back in BIRT 2.1.3 (at least with the RCP designer), I could set the chart
width to 100% and it would scale to fit its container.
Now I find with BIRT 2.2.1 using the Eclipse designer, '%' is not an
option for the width.
How do I create a chart that fills its container? Do I need to resort to
some JavaScript voodoo magic?
Pax.
Re: Chart width in '%' no longer allowed with BIRT 2.2.1? [message #261150 is a reply to message #261004] Mon, 12 November 2007 07:33 Go to previous messageGo to next message
This is not supported, even in the previous version. Charts are generated as
images, and cannot be re-sized in the browser without being distorted and
loosing their imagemap mapping for tooltips and hyperlinks. So that's why
the % is no longer an option anymore, since it will break the chart in the
browser.
David
<allachan@au1.ibm.com> wrote in message
news:fh0pci$r8a$1@build.eclipse.org...
> Cheers,
> Pax.
Re: Chart width in '%' no longer allowed with BIRT 2.2.1? [message #261282 is a reply to message #261150] Mon, 12 November 2007 23:27 Go to previous messageGo to next message
I understand that stretching the (very well) rendered charts could make
them as ugly as sin.
Is there a possibility of intercepting the report before the chart code
renders it (like changing datasource properties in beforeOpen) to change
the image properties based on the container?
For example, if we can detect that the chart is contained in a table cell
600x400 pixels, can the chart width be changed to 590x390 pixels before
its creation?
Some reports seem silly in that the tables stretch the entire width of the
screen but the charts have to be built for the minimum screen size.
Re: Chart width in '%' no longer allowed with BIRT 2.2.1? [message #261331 is a reply to message #261282] Tue, 13 November 2007 11:27 Go to previous message
Yes, if you can find out the size you want to render at runtime.
Implement this in beforeFactory or beforeRender in the report script:
this.getReportElement("ChartItemName").setWidth("600pt");
David
news:fhb93p$jdj$1@build.eclipse.org...
> its creation?
Previous Topic:Mixed type in a column of "ANY" type
Next Topic:auto Increment Value showing 1.0,2.0 instead of 1,2
Current Time: Sun Aug 31 10:02:28 EDT 2025
Powered by FUDForum. Page generated in 0.03601 seconds
