Home » Archived » BIRT » removing the bookmarks from a PDF
removing the bookmarks from a PDF [message #260971] Wed, 07 November 2007 17:09 Go to next message
I'm using BIRT 2.0.1 and I'm having the following problem:
I created a report design file with a table and some other information.
That table is using the grouping of the information inside. When opening
the generated PDF with Adobe Reader 8 I see that there were also generated
some bookmarks (usually it's the list of the elements that are grouped
after). For example:
if I'm grouping after the column "userName", the generated table would
look like:
UserName Information
John Doe1 information11
John Doe1 information12
John Doe1 information13
John Doe2 information21
John Doe2 information22
and the bookmarks will contain the list:
John Doe1
John Doe2
I didn't specified anywhere in the report to use any bookmarks. I would
like to turn them off. Is there any way to remove those bookmarks, to stop
get them generated? Or is it a BUG?
Thank you,
Cristian
Re: removing the bookmarks from a PDF [message #260972 is a reply to message #260971] Wed, 07 November 2007 18:29 Go to previous messageGo to next message
It's a feature. When you create a group, the default behavior is to create a
TOC (bookmarks in PDF) using the group values. When creating/editing a
group, you'll see a TOC expression option in the group editor. Delete the
expression there to remove the TOC entries/bookmarks.
"Cristian" <ceol.gael@gmail.com> wrote in message
news:14b59c4ba69607b30f41c87866003c46$1@www.eclipse.org...
> look like:
> UserName Information John Doe1 information11
> John Doe1
> John Doe2
> Thank you,
> Cristian
Re: removing the bookmarks from a PDF [message #260997 is a reply to message #260972] Thu, 08 November 2007 11:46 Go to previous messageGo to next message
Originally posted by: vencat.b.gmail.com
I have to try this but curious if there will be atleast any marginal
improvement in performance with no TOC, because these need not be generated
in my case as well.
"Diana Peh" <diana.peh@actuate.com> wrote in message
news:fgthpb$auc$1@build.eclipse.org...
> a TOC (bookmarks in PDF) using the group values. When creating/editing a
>> generated some bookmarks (usually it's the list of the elements that are
>> grouped after). For example:
>> look like:
>> John Doe1
>> John Doe2
>> stop get them generated? Or is it a BUG?
>> Thank you,
>> Cristian
Re: removing the bookmarks from a PDF [message #261392 is a reply to message #260997] Wed, 14 November 2007 10:13 Go to previous message
Venc,
I would recommend logging a Bugzilla entry that defines exactly what types
of improvements you are looking for.
Scott Rosenbaum
> generated in my case as well.
>> create a TOC (bookmarks in PDF) using the group values. When
>> creating/editing a group, you'll see a TOC expression option in the
>> group editor. Delete the expression there to remove the TOC
>> entries/bookmarks.
>>> Hi,
>>> information.
>>> opening
>>> are
>>> would
>>> look like:
>>> John Doe1
>>> John Doe2
>>> would like to turn them off. Is there any way to remove those
>>> bookmarks, to stop get them generated? Or is it a BUG?
>>> Thank you,
>>> Cristian
Previous Topic:how to display two lines in an overlay line chart?
Next Topic:Scripted Datasource Preview issue
Current Time: Tue Nov 04 19:42:10 EST 2025
Powered by FUDForum. Page generated in 0.05711 seconds
