Home » Language IDEs » Java Development Tools (JDT) » ICompilationUnit and IMethod
ICompilationUnit and IMethod [message #260956] Fri, 03 July 2009 16:37 Go to next message
Hi Guys,
Thanks for all your help. I have the following questions.
1)
How can i check if an ICompilotionUnit is a normal class or an interface.
I would like to use different image for a normal class and another image
if the ICompilotionUnit is an interface.
2)
How can i know if an IMethod is a constructor or a normal method.
Thanks for your help.
Eddy Freeman
Re: ICompilationUnit and IMethod [message #260964 is a reply to message #260956] Mon, 06 July 2009 03:19 Go to previous messageGo to next message
ICompilationUnit represent .java files whereas IType represent classes and
interfaces. So you should see IType.isClass() IType.isInterface().
To find out if an IMethod is a constructor see IMethod.isConstructor()
Re: ICompilationUnit and IMethod [message #261019 is a reply to message #260956] Mon, 06 July 2009 10:54 Go to previous message
Eddy Freeman wrote:
> Hi Guys,
> 1)
> interface. I would like to use different image for a normal class and
> another image if the ICompilotionUnit is an interface.
Not that this is already possible if you check 'Java Type Indicator' on
General > Appearance > Label Decorations preference page.
Dani
> 2)
> Eddy Freeman
Previous Topic:Reuse basic Java Editor
Next Topic:First opening of javadoc fails
Current Time: Sat Nov 22 20:56:26 EST 2025
Powered by FUDForum. Page generated in 0.04834 seconds
