Home » Language IDEs » Java Development Tools (JDT) » Get IResource for java file knowning IClassFile derived from it?
Get IResource for java file knowning IClassFile derived from it? [message #260847] Sun, 28 June 2009 03:57 Go to next message
Is there an easy way to lookup the original java file, as IResource
ideally, knowing the class file that was compiled from it? I'm trying to
indirectly use JDT's dependency analyzer to find out which java files were
compiled inside an Ant builder/custom task. I can get Eclipse pass the
incremental build resource delta to my Ant script which includes generated
class files, and I need to resolve them to their originating source files.
Perhaps there is a better way to solve this? Thanks.
-V.
Re: Get IResource for java file knowning IClassFile derived from it? [message #260864 is a reply to message #260847] Mon, 29 June 2009 05:55 Go to previous messageGo to next message
There's no single API that would give you this.
Dani
> I'm trying to indirectly use JDT's dependency analyzer to find out
> which java files were compiled inside an Ant builder/custom task. I
> can get Eclipse pass the incremental build resource delta to my Ant
> script which includes generated class files, and I need to resolve
> them to their originating source files. Perhaps there is a better way
> -V.
Re: Get IResource for java file knowning IClassFile derived from it? [message #260887 is a reply to message #260864] Mon, 29 June 2009 14:25 Go to previous messageGo to next message
> Dani
Fair enough. Then it looks like the solution will be to search in the
source folders inside the corresponding packages. Does this sound like a
plausible approach?
-Vladimir
Re: Get IResource for java file knowning IClassFile derived from it? [message #261014 is a reply to message #260887] Mon, 06 July 2009 10:49 Go to previous message
>> Dani
> a plausible approach?
Yep. As a first guess you could simply check whether there's a
corresponding *.java file / Compilation Unit and if not, do the search.
Dani
> -Vladimir
Previous Topic:A modal dialog box like Open Type Dialog Box
Next Topic:Reuse basic Java Editor
Current Time: Wed Nov 19 19:17:08 EST 2025
Powered by FUDForum. Page generated in 0.03267 seconds
