Home » Language IDEs » Java Development Tools (JDT) » Question about build path problem
Question about build path problem [message #260590] Fri, 12 June 2009 12:06 Go to next message
Hey,
I want to create an error marker if there is some problem in the build
path of a java project based on our specific rule. I don't want the java
builder to build the project if the project has that kinkd of problem.
However, I don't know where is the best place to create the marker. My
scenario is very similar to the eclipse behavior that, in eclipse, if the
build path of a java project is broken, e.g. an imported jar does not
exist, eclipse shows a error marker on the problem. Then, the java builder
is not kicked in.
I tried to use the CompilationParticipant extension but I could not
prevent the java builder from being called. Any thought.
Thanks.
Re: Question about build path problem [message #260642 is a reply to message #260590] Tue, 16 June 2009 09:28 Go to previous message
Raymond wrote:
> Hey,
> java builder to build the project if the project has that kinkd of
> problem. However, I don't know where is the best place to create the
> marker. My scenario is very similar to the eclipse behavior that, in
> eclipse, if the build path of a java project is broken, e.g. an
> imported jar does not exist, eclipse shows a error marker on the
> problem. Then, the java builder is not kicked in.
You have to create the marker on the project and remove the Java builder
from the projects build spec, see
org.eclipse.core.resources.IProjectDescription.getBuildSpec( ) for details.
Dani
> Thanks.
Previous Topic:Syntax coloring per file type and background?
Next Topic:Specifying source location for libraries
Current Time: Tue Nov 25 17:26:51 EST 2025
Powered by FUDForum. Page generated in 0.03620 seconds
