Home » Eclipse Projects » Eclipse Platform » RCP startup error
RCP startup error [message #260359] Sat, 10 July 2004 10:31 Go to next message
Originally posted by: lesliesoftware.yahoo.com
I have a strange startup error with my RCP application. When I launch my
application I get the error message "Could not launch the configuration.
Details are in the log. Would you like to open it?". I have attached the
log below. It looks like Eclipse is trying to run an exception class.
DataAccessException is derived from Exception. My application's run
method is never even called so I do not see how it could be caused by
hitting an exception. I have several plug-ins in my RCP application:
com.lesliesoftware.lcommon
com.lesliesoftware.lphoto
com.lesliesoftware.lphoto.dataaccess
and I wrote a wrapper plug-in for Xindice
org.apache.xindice
My application LPhotoApplication resides in .lphoto and the
DataAccessException class is in .lphoto.dataaccess. I recreated this
project from the version I was using in M8 to be 3.0 plug-ins. I had it
working step by step until I added the database back in (the Xindice
plug-in the dataaccess plug-in and some of the code to use it in my
application).
My launch configuration has the correct application specified and I have
checked and rechecked that the plug-in list is correct.
Any advice would be appreciated.
IL
---8<---
!SESSION Jul 10, 2004 07:21:48.46
eclipse.buildId=unknown
java.version=1.4.1_02
Command-line arguments: -application
com.lesliesoftware.lphoto.LPhotoApplication
!ENTRY org.eclipse.osgi Jul 10, 2004 07:21:48.46
!MESSAGE Application error
!STACK 1
java.lang.NoClassDefFoundError:
com/lesliesoftware/lphoto/dataaccess/errors/DataAccessExcept ion
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Class.java:15 90)
at java.lang.Class.getConstructor0(Class.java:1762)
at java.lang.Class.newInstance0(Class.java:276)
at java.lang.Class.newInstance(Class.java:259)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:141)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:124)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:113)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:303)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:256)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:127)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:638)
at org.eclipse.core.launcher.Main.main(Main.java:622)
Re: RCP startup error [message #260373 is a reply to message #260359] Sat, 10 July 2004 14:02 Go to previous message
Originally posted by: pascal.ibm.canada
Try running with -clean once.
PaScaL
> org.apache.xindice
> application).
> IL
> ---8<---
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> !STACK 1
> at
> at
> at
> at
> at
> at
> at
> at
Previous Topic:Installing eclipse 3.0 in a common Linux directory
Next Topic:Plugini export does not see linked directory
Current Time: Sat Jul 26 09:29:48 EDT 2025
Powered by FUDForum. Page generated in 0.06981 seconds
