Home » Eclipse Projects » Eclipse Platform » eclipse failed to launch
eclipse failed to launch [message #260170] Fri, 09 July 2004 11:02 Go to next message
Originally posted by: mjsongNOSPAM.hotmail.com
I just started using Eclipse a couple of days ago, for a Java
desktop project. It has been great.
But I could not start eclipse today. It directed me to an error log
file.
Here is the content of the log file.
!SESSION Jul 09, 2004 10:42:19.385
eclipse.buildId=I200406251208
java.version=1.4.1_01
!ENTRY org.eclipse.osgi Jul 09, 2004 10:42:19.385
!MESSAGE Application error
!STACK 1
java.lang.ClassFormatError: org/eclipse/jface/resource/ImageDescriptor
(Illegal Field name "DEFAULT_;MAGE_DATA")
at java.lang.ClassLoader.defineClass0(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:502)
org.eclipse.osgi.framework.internal.defaultadaptor.DefaultCl assLoader.defineClass(DefaultClassLoader.java:298)
org.eclipse.core.runtime.adaptor.EclipseClassLoader.defineCl ass(EclipseClassLoader.java:223)
org.eclipse.osgi.framework.internal.defaultadaptor.DefaultCl assLoader.findClassImpl(DefaultClassLoader.java:281)
org.eclipse.osgi.framework.internal.defaultadaptor.DefaultCl assLoader.findClass(DefaultClassLoader.java:172)
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. findLocalClass(AbstractClassLoader.java:220)
org.eclipse.core.runtime.adaptor.EclipseClassLoader.basicFin dLocalClass(EclipseClassLoader.java:135)
org.eclipse.core.runtime.adaptor.EclipseClassLoader.findLoca lClass(EclipseClassLoader.java:59)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:371)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:402)
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. loadClass(AbstractClassLoader.java:93)
at java.lang.ClassLoader.loadClass(ClassLoader.java:255)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:315 )
at org.eclipse.jface.dialogs.Dialog.<clinit>(Dialog.java:119)
org.eclipse.ui.internal.ide.IDEApplication.promptForWorkspac e(IDEApplication.java:314)
org.eclipse.ui.internal.ide.IDEApplication.checkInstanceLoca tion(IDEApplication.java:219)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:83)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:183)
at org.eclipse.core.launcher.Main.run(Main.java:644)
at org.eclipse.core.launcher.Main.main(Main.java:628)
<end of log>
My eclipse version is 3.0. JRE version is 1.4.1_01. I am running on
Win2K professional.
I would like to check with the group first before filing it as a bug.
Mike
Re: eclipse failed to launch [message #260740 is a reply to message #260170] Mon, 12 July 2004 11:28 Go to previous message
Originally posted by: chaves.nospam.inf.ufsc.br.ok
It seems the JAR file containing the mentioned class is corrupted.
Reinstalling would probably fix your problem. Opening a bug would be good,
so the problem could be investigated (in that case, you should preserve
the problematic install).
Rafael
> file.
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> !STACK 1
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> <end of log>
> Win2K professional.
> Mike
Previous Topic:Mouse wheel
Next Topic:Problems in PDE Build
Current Time: Sun Jul 27 12:51:54 EDT 2025
Powered by FUDForum. Page generated in 0.03688 seconds
