Home » Archived » BIRT » getMarker() deprecated
getMarker() deprecated [message #259996] Tue, 30 October 2007 18:49
I'm using Eclipse 3.3.1 and the BIRT Chart Engine SDK 2.2.1. The compiler
says that getMarker() is deprecated, and after doing a bit of research I
found some documentation that it is indeed deprecated:
http://www.birt-exchange.com/documentation/BIRT_220/ChartJav adoc/chart/api/deprecated-list.html
The documentation says to "Use Markers property instead.", but I cannot
figure out how to do that or the reason why the getMarker() function is
actually deprecated. Many code examples on the BIRT site are using
setMarkers().
So, why is that function deprecated, is there a better way to set the
markers on a plot, and how shall I do that using the Markers property?
Thanks much in advance...
~Tim
Previous Topic:Report Data Source feeding from Tomcat or JBoss DataSource
Next Topic:BIRT_VIEWER_WORKING_FOLDER and BIRT_VIEWER_DOCUMENT_FOLDER
Current Time: Mon Sep 01 01:39:04 EDT 2025
Powered by FUDForum. Page generated in 0.04080 seconds
