Home » Eclipse Projects » Eclipse Platform » How to find the location of the plugin in Eclipse 3.0?
How to find the location of the plugin in Eclipse 3.0? [message #259989] Thu, 08 July 2004 23:45 Go to next message
In eclipse 2.0 version i was able to get the location (absolute path) of a
plugin with the aid of pluginId in the following way.
URL installURL =
Platform.getPluginRegistry().getPluginDescriptor(pluginId).g etInstallURL();
String location = Platform.resolve(installURL).getFile().substring(1);
In eclipse 3.0, I can get the location using the same code but the method
getPluginRegistry() from the type Platform is deprecated.
I could find any another way to get the location of the plugin so that i
can avoid using the deprecated ones.
Any ideas?
Mahi
Re: How to find the location of the plugin in Eclipse 3.0? [message #260025 is a reply to message #259989] Fri, 09 July 2004 03:14 Go to previous messageGo to next message
the only way I know is to remember the BundleContext in the Plugin#start(BundleContext)
method, then get all Bundles from the context (BundleContext#getBundles()), iterate
over it and compare each Bundle#getSymbolicName() with your pluginId.
When you have the bundle, use
URL installURL = bundle.getEntry("/");
Peter Schaich
> URL installURL =
> Any ideas?
> Mahi
Dipl.-Inf. Peter Schaich
Mind8 GmbH
Gänsheidestraße 59
D-70184 Stuttgart, Germany
+49-(0)711-210707-14 (phone)
+49-(0)711-210707-99 (fax)
www.mind8.com
Re: How to find the location of the plugin in Eclipse 3.0? [message #260076 is a reply to message #260025] Fri, 09 July 2004 08:14 Go to previous messageGo to next message
Originally posted by: pascal.ibm.canada
To get the bundles you can use Platform.getBundle("bundleId")
Peter Schaich wrote:
> Hello,
> Peter Schaich
>> of a
>> URL installURL =
>> Any ideas?
>> Mahi
Re: How to find the location of the plugin in Eclipse 3.0? [message #260286 is a reply to message #260076] Fri, 09 July 2004 17:52 Go to previous messageGo to next message
Thanks Peter/Pascal
I was able to get location by doing the follwing
URL installURL = Platform.getBundle(pluginId).getEntry("/");
> > Hello,
> > Regards,
> > Peter Schaich
> >> of a
> >> URL installURL =
> >> Any ideas?
> >> Mahi
Re: How to find the location of the plugin in Eclipse 3.0? [message #260298 is a reply to message #260286] Fri, 09 July 2004 18:30 Go to previous message
Originally posted by: richkulp.NO.SPAM.us.ibm.com
But be aware there is no requirement that the install location be a
local file directory. If could be on a remote machine.
Thanks, Rich Kulp
Previous Topic:How to change username for ${user} ?
Next Topic:Ant input tag
Current Time: Sat Jul 26 13:16:14 EDT 2025
Powered by FUDForum. Page generated in 0.08371 seconds
