Home » Archived » BIRT » Setting Table Run direction in BIRT 2.2
Setting Table Run direction in BIRT 2.2 [message #259940] Tue, 30 October 2007 08:09 Go to next message
Originally posted by: bpraveena2002.gmail.com
Hi All,
I'm trying to create a pdf using BIRT 2.2 where the tables run direction
will change based on the locale used
For eg, When the Locale is english the table would look like
Column1 Column2 Column3
Row1-1 Row1-2 Row1-3
Row2-1 Row2-2 Row2-3
When the locale is Arabic the table should appear like
Column3 Column2 Column1
Row1-3 Row1-2 Row1-1
Row2-3 Row2-2 Row2-1
Where the entire table has been transposed. It is possible to achive this
in itext by setting
the rundirection property of the PdfPTable.
Is it possible to achive this through configuration settings in BIRT.
Or is there any other way to achive this through code modification?
Thanks and Regards,
Praveena
Re: Setting Table Run direction in BIRT 2.2 [message #259956 is a reply to message #259940] Tue, 30 October 2007 11:42 Go to previous message
Praveena,
I know this is handled in the HTML by using the RTL flag in the url, but
I do not see this handled in the pdftable. You can call the deapi from
script and modify the table on the fly based on locale. Attached is an
example. Can you log an enhancement request to get the rtl flag put on
the rundirection for the the pdf table?
Jason
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.14"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.2.0.v20070620 Build &lt;2.2.0.v20070626-1003></property>
<property name="units">in</property>
<property name="comments">Copyright (c) 2007 &lt;&lt;Your Company
Name here>></property>
<html-property name="description">Creates a blank report with no
predefined content.</html-property>
<method name="beforeFactory"><![CDATA[importPackage(
Packages.org.eclipse.birt.report.model.api );
mylocale = reportContext.getLocale().toString();
if( mylocale == "ar"){
mytable =
reportContext.getReportRunnable().designHandle.getDesignHand le().findElement( "mytable");
tabledetail = mytable.getDetail( ).get( 0 );
tableheader = mytable.getHeader( ).get( 0 );
hcell1 = tableheader.getCells( ).get( 0 );
hcell2 = tableheader.getCells( ).get( 1 );
hcell4 = tableheader.getCells( ).get( 3 );
hcell5 = tableheader.getCells( ).get( 4 );
hdata1 = hcell1.getContent( ).get(0);
hdata2 = hcell2.getContent( ).get(0);
hdata4 = hcell4.getContent( ).get(0);
hdata5 = hcell5.getContent( ).get(0);
hcell1.getContent( ).drop(hdata1);
hcell1.getContent( ).add(hdata5);
hcell2.getContent( ).drop(hdata2);
hcell2.getContent( ).add(hdata4);
hcell4.getContent( ).drop(hdata4);
hcell4.getContent( ).add(hdata2);
hcell5.getContent( ).drop(hdata5);
hcell5.getContent( ).add(hdata1);
cell1 = tabledetail.getCells( ).get( 0 );
cell2 = tabledetail.getCells( ).get( 1 );
cell4 = tabledetail.getCells( ).get( 3 );
cell5 = tabledetail.getCells( ).get( 4 );
data1 = cell1.getContent( ).get(0);
data2 = cell2.getContent( ).get(0);
data4 = cell4.getContent( ).get(0);
data5 = cell5.getContent( ).get(0);
cell1.getContent( ).drop(data1);
cell1.getContent( ).add(data5);
cell2.getContent( ).drop(data2);
cell2.getContent( ).add(data4);
cell4.getContent( ).drop(data4);
cell4.getContent( ).add(data2);
cell5.getContent( ).drop(data5);
cell5.getContent( ).add(data1);
}]]></method>
<text-property name="displayName">Blank Report</text-property>
<property name="iconFile">/templates/blank_report.gif</property>
<data-sources>
<oda-data-source
extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source"
id="6">
<property
name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver </property>
<property name="odaURL">jdbc:classicmodels:sampledb</property>
<property name="odaUser">ClassicModels</property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
name="Data Set" id="7">
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">ORDERNUMBER</property>
<property name="dataType">integer</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">PRODUCTCODE</property>
<property name="dataType">string</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">QUANTITYORDERED</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">PRICEEACH</property>
<property name="dataType">float</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">ORDERLINENUMBER</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<structure>
<property name="nativeName">ORDERNUMBER</property>
<property name="nativeDataType">4</property>
</structure>
<structure>
<property name="nativeName">PRODUCTCODE</property>
<property name="nativeDataType">12</property>
</structure>
<structure>
<property name="nativeName">QUANTITYORDERED</property>
</structure>
<structure>
<property name="nativeName">PRICEEACH</property>
<property name="nativeDataType">8</property>
</structure>
<structure>
<property name="nativeName">ORDERLINENUMBER</property>
<property name="nativeDataType">5</property>
</structure>
</list-property>
<property name="queryText">select *
from orderdetails
</property>
</oda-data-set>
</data-sets>
<styles>
<style name="crosstab" id="4">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab-cell" id="5">
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property
name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<data id="43">
<list-property name="boundDataColumns">
<structure>
<property name="name">Column Binding</property>
<expression name="expression">mylocale</expression>
<property name="dataType">any</property>
</structure>
</list-property>
<property name="resultSetColumn">Column Binding</property>
</data>
<table name="mytable" id="8">
<property name="width">100%</property>
<property name="dataSet">Data Set</property>
<structure>
<expression
name="expression">dataSetRow["ORDERNUMBER"]</expression >
</structure>
<structure>
<expression
name="expression">dataSetRow["PRODUCTCODE"]</expression >
</structure>
<structure>
<expression
name="expression">dataSetRow["QUANTITYORDERED"]</expression >
</structure>
<structure>
<expression
name="expression">dataSetRow["PRICEEACH"]</expression>
</structure>
<structure>
<expression
name="expression">dataSetRow["ORDERLINENUMBER"]</expression >
</structure>
</list-property>
<column id="37"/>
<column id="38"/>
<column id="39"/>
<column id="40"/>
<column id="41"/>
<header>
<row id="9">
<cell id="10">
<label id="11">
<text-property
name="text">ORDERNUMBER</text-property>
</label>
</cell>
<cell id="12">
<label id="13">
<text-property
name="text">PRODUCTCODE</text-property>
</label>
</cell>
<cell id="14">
<label id="15">
<text-property
name="text">QUANTITYORDERED</text-property>
</label>
</cell>
<cell id="16">
<label id="17">
<text-property
name="text">PRICEEACH</text-property>
</label>
</cell>
<cell id="18">
<label id="19">
<text-property
name="text">ORDERLINENUMBER</text-property>
</label>
</cell>
</row>
</header>
<detail>
<row id="20">
<cell id="21">
<data id="22">
<property
name="resultSetColumn">ORDERNUMBER</property>
</data>
</cell>
<cell id="23">
<data id="24">
<property
name="resultSetColumn">PRODUCTCODE</property>
</data>
</cell>
<cell id="25">
<data id="26">
<property
name="resultSetColumn">QUANTITYORDERED</property>
</data>
</cell>
<cell id="27">
<data id="28">
<property
name="resultSetColumn">PRICEEACH</property>
</data>
</cell>
<cell id="29">
<data id="30">
<property
name="resultSetColumn">ORDERLINENUMBER</property>
</data>
</cell>
</row>
</detail>
<footer>
<row id="31">
<cell id="32"/>
<cell id="33"/>
<cell id="34"/>
<cell id="35"/>
<cell id="36"/>
</row>
</footer>
</table>
</body>
</report>
Praveena Babu wrote:
> Hi All, I'm trying to create a pdf using BIRT 2.2 where the tables
> run direction will change based on the locale used
> this in itext by setting the rundirection property of the PdfPTable.
> Is it possible to achive this through configuration settings in BIRT. Or
> Thanks and Regards,
> Praveena
Previous Topic:Chart example with DateTime - amount - revenue
Next Topic:cell heigh diff in diff. version
Current Time: Sun Jul 27 12:41:35 EDT 2025
Powered by FUDForum. Page generated in 0.03538 seconds
