Home » Newcomers » Newcomers » Selection Listner needs to forget
Selection Listner needs to forget [message #259833] Wed, 02 July 2008 18:02 Go to next message
Originally posted by: daved99.comcast.net
I admit I started this mess. I was working with an editor and created a
selection listener. I forgot to remove it in the dispose method. Things
worked fine for a while so I was fat sassy and happy. Now I have changed
the selection listener process (removed some processing)and Eclipse
continues to run the original. I tried -refresh, -clear, re-installing
ganymede all to no avail.
How the heck to I get rid of the old process?
Where is eclipse remembering the listener?
Re: Selection Listner needs to forget [message #259925 is a reply to message #259833] Thu, 03 July 2008 10:24 Go to previous message
Originally posted by: rtroy.sciencetools.com
MAYBE it's in java itself. JVMs can keep objects going if it doesn't see a
reason to destroy them. Check if a JVM is still around - try restarting
ALL JVMs on the box...
As a side note, I'm a beginner with Eclipse and have also noticed some
behavioral problems with Eclipse's refusal to see the world as it is not
as it was. And I haven't figured those out, either, so if I'm wrong, we
have more to learn!
Previous Topic:Compile but the debug doesn't run
Next Topic:using p2
Current Time: Sat Nov 22 02:32:55 EST 2025
Powered by FUDForum. Page generated in 0.07307 seconds
