Home » Eclipse Projects » Technology Project and PMC » can't start Eclipse in RedHat 7.1
can't start Eclipse in RedHat 7.1 [message #25673] Thu, 19 September 2002 09:43 Go to next message
Originally posted by: hlin.vonage.com
Hi, I just start to try Eclipse but can't get it to run. I got this error
when I type ./eclipse
An unexpected exception has been detected in native code outside the VM.
Unexpected Signal : 11 occurred at PC=0x4D46D098
Function=XmCreateScrolledList+0x38
Library=/usr/X11R6/lib/libXm.so.2
I'm using Eclipse 2.0.1 (motif version) on RedHat 7.1. Also where can I find
document regarding installation ? Thanks,
Howard Lin
Re: can't start Eclipse in RedHat 7.1 [message #26044 is a reply to message #25673] Fri, 20 September 2002 05:02 Go to previous messageGo to next message
> Howard Lin
Make sure the motif library shipped with eclipse is used.
e.g. check/unset LD_LIBRARY_PATH
Re: can't start Eclipse in RedHat 7.1 [message #26085 is a reply to message #25673] Fri, 20 September 2002 11:47 Go to previous message
Originally posted by: al.thompsonlogic.com
make sure you specify the correct jvm on the command line, as it may be
trying to use the kaffe jre, which is installed by default on 7.1 (they
got rid of that awful thing on later versions). try this command:
./eclipse -vm <path to java vm>
for example:
./eclipse -vm /usr/java/j2sdk1.4.1/bin/java
hth,
alvin
> Howard Lin
Re: can't start Eclipse in RedHat 7.1 [message #582957 is a reply to message #25673] Fri, 20 September 2002 05:02 Go to previous message
> Howard Lin
Re: can't start Eclipse in RedHat 7.1 [message #582978 is a reply to message #25673] Fri, 20 September 2002 11:47 Go to previous message
for example:
hth,
alvin
> Howard Lin
Previous Topic:Building an email client using Eclipse platform
Next Topic:?? Can't Set a Breakpoint ?? See Image
Current Time: Tue Jun 03 17:09:59 EDT 2025
Powered by FUDForum. Page generated in 0.10045 seconds
