Home » Language IDEs » Java Development Tools (JDT) » HELP - JavaModelException
HELP - JavaModelException [message #259681] Wed, 22 April 2009 11:42 Go to next message
Hello Everybody,
Thanks for all your help. I have a little problem when i try to open the
view of my plugin. I have the following view class. The intention is to
create a view with a label and i set the text of the view to just the name
of a SimpleName element. This is the class:
public class TableView extends ViewPart{
public TableView(){
public void createPartControl(Composite parent){
GridLayout gridLayout = new GridLayout();
parent.setLayout(gridLayout);
Label label = new Label(parent, SWT.CENTER);
ICompilationUnit icomp = this.findProject();
CompilationUnit comp = this.parse(icomp);
SimpleName sn =
((TypeDeclaration)comp.types().get(0)).getName();
label.setText(sn.getFullyQualifiedName());
public void setFocus(){
protected CompilationUnit parse(ICompilationUnit unit) {
ASTParser parser = ASTParser.newParser(AST.JLS3);
parser.setKind(ASTParser.K_COMPILATION_UNIT);
parser.setSource(unit); // set source
parser.setResolveBindings(true); // we need bindings later on
return (CompilationUnit)parser.createAST(null /* IProgressMonitor
*/); // parse
public ICompilationUnit findProject(){
IWorkspaceRoot root = ResourcesPlugin.getWorkspace().getRoot();
// "org.integ.proj.sl" is the project name
IProject project = root.getProject("org.integ.proj.sl");
if (project.exists() && !project.isOpen())
try {
project.open(null /* IProgressMonitor */);
} catch (CoreException e1) {
e1.printStackTrace();
IJavaProject javaProject = JavaCore.create(project);
IType lwType = null;
try {
// "Menu" is a class in the "org.integ.proj.sl.gui" package
lwType = javaProject.findType("org.integ.proj.sl.gui.Menu");
} catch (JavaModelException e) {
e.printStackTrace();
ICompilationUnit lwCompilationUnit =
lwType.getCompilationUnit();
return lwCompilationUnit;
After i execute the project as "Eclipse Application", i get a new
workspace and when i try to open the view, i get the following errors and
exception:
Error creating the view
java.lang.NoClassDefFoundError: org/eclipse/jdt/core/JavaModelException
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Class.java:23 57)
at java.lang.Class.getConstructor0(Class.java:2671)
at java.lang.Class.newInstance0(Class.java:321)
at java.lang.Class.newInstance(Class.java:303)
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:170)
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:788)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugi n.java:252)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work benchPlugin.java:248)
org.eclipse.ui.internal.registry.ViewDescriptor.createView(V iewDescriptor.java:69)
org.eclipse.ui.internal.ViewReference.createPartHelper(ViewR eference.java:327)
org.eclipse.ui.internal.ViewReference.createPart(ViewReferen ce.java:227)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:592)
org.eclipse.ui.internal.WorkbenchPage$ActivationList.setActi ve(WorkbenchPage.java:4080)
org.eclipse.ui.internal.WorkbenchPage$17.runWithException(Wo rkbenchPage.java:3145)
org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3659)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3296)
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:801)
org.eclipse.ui.internal.Workbench$25.runWithException(Workbe nch.java:1342)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2309)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
at org.eclipse.equinox.launcher.Main.main(Main.java:1148)
I am asking if you can help me to track why and where this exception is
coming from so that i can solve it.. Thank you very much. Regards,Eddy.
Re: HELP - JavaModelException [message #259685 is a reply to message #259681] Wed, 22 April 2009 11:56 Go to previous messageGo to next message
Hello Everybody,
Due to how my post is poorly rendered, i would like to point you to
this address to read it and answer give me your answers. I tried to delete
it and post it again but there is no deletion link. Go to this site where
i have posted the same question. Thanks. The site is:
http://www.nabble.com/JDT---PARSER----HELP-----Exception-pro blem-td23167770.html
Re: HELP - JavaModelException [message #259687 is a reply to message #259681] Wed, 22 April 2009 18:17 Go to previous message
You're not seeing a separate log entry right below it? Try
launching using Debug mode and adding an exception breakpoint for
JavaModelException to see when it's being thrown.
http://help.eclipse.org/ganymede/topic/org.eclipse.jdt.doc.u ser/reference/views/breakpoints/ref-breakpoints_view.htm
http://help.eclipse.org/ganymede/topic/org.eclipse.jdt.doc.u ser/reference/views/breakpoints/ref-addexception_viewaction. htm
Nitin Dahyabhai
Eclipse WTP Source Editing
IBM Rational
Previous Topic:APT and QuickFixes
Next Topic:Keeping Track of AST after ASTRewrite
Current Time: Sat Nov 08 16:02:33 EST 2025
Powered by FUDForum. Page generated in 0.03795 seconds
