Home » Archived » BIRT » BIRT - reusable component
BIRT - reusable component [message #259615] Fri, 26 October 2007 07:26 Go to next message
Our project is using BIRT 2.2.0.
We are developeing a reusable component for outputs based on BIRT 2.2.0.
For the above purpose, whether can we say that BIRT runtime is a reusable
component which is in the business layer?
Also then I have to deploy my output component(which uses BIRT) to
application server. We are using OC4J server. Is it possible for BIRT
component to use OC4J (Oracle) application server?
I have not found any material regarding deployment of BIRT to Oracle
application server.
Thanks and regards,
Shomy
Re: BIRT - reusable component [message #259655 is a reply to message #259615] Fri, 26 October 2007 11:05 Go to previous message
Shomy,
I have never deployed birt as part of OC4J and it is not a configuration
that the dev team explicitly test. That said it should work.
Jason
Shomy Jose wrote:
> reusable component which is in the business layer?
> application server.
> Thanks and regards,
> Shomy
Previous Topic:Referring to page number a report item is on
Next Topic:Table grouping and column header
Current Time: Tue Jul 15 14:06:11 EDT 2025
Powered by FUDForum. Page generated in 0.06683 seconds
