'Computing Source' has encountered a problem [message #259590] |
Mon, 30 June 2008 08:42  |
Originally posted by: tweak.lavabit.com
Hi all
I am using Eclipse Ganymede with CDT.
I have one project where the complete project is indexed correctly.
Everything is recognized correctly (for autocomplete and syntax
highlighting).
However, when i hover the mouse over items that are in files which need to
be refreshed
( the ones when you open them that say: "Resource is out of sync with the
file system '/filepathandname'. -press F5 or select File > Refresh to
refresh the file )
, i get a
"'Computing Source' has encountered a problem. An internal error occurred
during: 'Computing Source'".
If i open up those files, press F5, then in the original file, the
hovering will work.
Is anybody else having this problem? Should i create a bug report for
this?
And is there anywhere a HowTo how to create a bug report ? :)
FUDForum. Page generated in 0.29555 seconds
