Home » Language IDEs » Java Development Tools (JDT) » Get Tab Size from Preferences
Get Tab Size from Preferences [message #259549] Tue, 14 April 2009 20:27 Go to next message
I suppose this is the right group to ask the question.
I'm trying to get the Tab size in java source files, which is set by the
current code formatter. In the XML file of the formatter it has the key:
"org.eclipse.jdt.core.formatter.tabulation.size"
And I suppose that it is contained in some PreferenceStore, but calling
PlatformUI.getPreferenceStore().getInt("org.eclipse.jdt.core.formatter.tabulation.size ")
does not return the value.
Do you know how can I get the value?
Thank You!
Nikolay
Re: Get Tab Size from Preferences [message #259563 is a reply to message #259549] Wed, 15 April 2009 06:31 Go to previous messageGo to next message
Nikolay wrote:
> Hello,
> the current code formatter. In the XML file of the formatter it has
> the key:
The Platform UI plug-in knows nothing about JDT and hence you won't find
it there.
I suggest to take a look at
org.eclipse.jdt.internal.corext.util.CodeFormatterUtil.getTa bWidth(IJavaProject).
Dani
> Thank You!
> Nikolay
Re: Get Tab Size from Preferences [message #259588 is a reply to message #259563] Thu, 16 April 2009 16:32 Go to previous message
Wow, Thank you Dani! :)) It worked perfectly :P
Previous Topic:Extending Java Search Functionality From the Result View Toolbar
Next Topic:How to add superinterface to IType
Current Time: Tue Jul 22 14:47:41 EDT 2025
Powered by FUDForum. Page generated in 0.04006 seconds
