Home » Eclipse Projects » Eclipse Platform » dependent Java projects and classpath problems...
dependent Java projects and classpath problems... [message #259548] Thu, 08 July 2004 06:33 Go to next message
Originally posted by: sunay.yaldiz.gentleware.com
I have two projects A and B, and B depends on A.
When I say in project settings that B is dependent on A, this is not
enough for B to compile in most cases. I have to add the jars in the
project A's classpath manually to the classpath of the project B.
So, whenever there is a change on the classpath of A, I also have to
change the classpath of B.
Is there a way somehow to say my project B is dependent on project A and
also add all the libraries in classpath of A to B?
All answers are appreciated,
Sunay
Re: dependent Java projects and classpath problems... [message #259558 is a reply to message #259548] Thu, 08 July 2004 07:09 Go to previous messageGo to next message
You need to export the libraries of A so they are visible to B. To do so,
check the libraries you want to export in the Order and Export tab in the
Java Build Path dialog.
Jerome
"Sunay Yaldiz" <sunay.yaldiz@gentleware.com> wrote in message
news:ccj7os$r12$1@eclipse.org...
> Hello,
> Thanks
> Sunay
Re: dependent Java projects and classpath problems... [message #259896 is a reply to message #259558] Thu, 08 July 2004 18:11 Go to previous message
Originally posted by: richkulp.NO.SPAM.us.ibm.com
Also, make sure that you used the "Java Build Path" to set the dependent
projects. DO NOT use the "Project References" tab.
Thanks, Rich Kulp
Previous Topic:eclipse close lifttime
Next Topic:Hyperlinks? How do I add annotations to an editor?
Current Time: Sat Nov 08 00:48:55 EST 2025
Powered by FUDForum. Page generated in 0.03333 seconds
