Home » Newcomers » Newcomers » org.eclipse.jface.window ApplicationWindow instantiation -- NoClassDefFoundError
org.eclipse.jface.window ApplicationWindow instantiation -- NoClassDefFoundError [message #259540] Sun, 29 June 2008 14:18 Go to next message
Originally posted by: publicMailingAddress.gmail.com
I am attempting to instantiate an ApplicationWindow and am getting a
NoClassDefFoundError: org/eclipse/core/runtime/IProgressMonitor.
To the build path of the package, I have attached:
org.eclipse.jface_3.4.0.I20080606-1300.jar
I also tried a Java Source Attachment of:
D:/eclipse/plugins/org.eclipse.jface.source_3.4.0.I20080606- 1300.jar
That, at least, enabled me to conveniently see the source code.
This is the code:
// line 1
import org.eclipse.swt.*;
import org.eclipse.swt.widgets.*;
import org.eclipse.jface.*;
import org.eclipse.jface.window.*;
// line 6
public class TestApp
// line 9
public static void main( String[] args )
Display OS_Interface = new Display();
Shell mainWindow = new Shell( OS_Interface );
WindowManager wm = new WindowManager();
ApplicationWindow aw = new ApplicationWindow( mainWindow ); // line 15
} // line 16
and this is the stack trace:
Exception in thread "main" java.lang.NoClassDefFoundError:
at TestApp.main(TestApp.java:15)
Caused by: java.lang.ClassNotFoundException:
org.eclipse.core.runtime.IProgressMonitor
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
... 1 more
as you can see, the WindowManager Class does not throw an exception, but
it belongs to the org.eclipse.jface.window.* package also. It appears that
none of the classes called by the ApplicationWindow are outside of this
package.
Does anybody know why this is happening? Specifically, am I doing
something incorrectly, or is there something wrong with this specific jar.
Is there something I forgot to set up, etc. It would seem that this could
not be my fault, since I am following the javadoc and since the other
class works just fine.
Thanks for your help,
Ryan
Re: org.eclipse.jface.window ApplicationWindow instantiation -- NoClassDefFoundError [message #259543 is a reply to message #259540] Sun, 29 June 2008 14:50 Go to previous message
I'm starting to figure this out from the following link:
http://wiki.eclipse.org/index.php/JFace#Setting_Up_an_Eclips e_Project_to_use_SWT_and_JFace
finding the plugins in the PDE was difficult because the AJAX tools demo
had, earlier, walked me through changing the target platform.
Basically, it looks like there are more dependencies than I knew about.
Previous Topic:What process modeling language is under this process framework?
Next Topic:How to switch between the test class and the production class ?
Current Time: Thu Nov 06 16:00:44 EST 2025
Powered by FUDForum. Page generated in 0.10242 seconds
