Home » Eclipse Projects » Eclipse Platform » Java files not getting compiled. Eclipse 3.0
Java files not getting compiled. Eclipse 3.0 [message #259470] Thu, 08 July 2004 01:19 Go to next message
Originally posted by: mravi.web.de
I am using Eclipse 3.0. I have a project with src and bin folders. When
I save the java file, it used to be compiled and the class file copied
to bin folder. But all of a sudden, it stopped working. I haven't made
any setting changes.
Where can I enable the autobuild for the java files? Is thr any way to
manually compile each file?
Thanks in advance.
Ravi.
Re: Java files not getting compiled. Eclipse 3.0 [message #259508 is a reply to message #259470] Thu, 08 July 2004 04:10 Go to previous messageGo to next message
Originally posted by: ramim.kauhajoki.fi
I had similar problems when I used the Sysdeo tomcat plug-in. I solved
this by removing a line from the Project's Java build path (at the moment
I don't recall the line I removed ...).
Otherwise the R3 has worked perfectly !! :)
Ravi wrote:
> Thanks in advance.
> Ravi.
Re: Java files not getting compiled. Eclipse 3.0 [message #259518 is a reply to message #259508] Thu, 08 July 2004 04:46 Go to previous messageGo to next message
yeah. I installed Sysdeo tomcat plugin about 3 days back. Haven't
realised the this automatic compiling stopped working after the plugin
is installed.
just let me know in case u remember the changes you have done for this
to work.
Thanx
Ravi.
> Ravi wrote:
>>Hi,
>>Thanks in advance.
>>Ravi.
Re: Java files not getting compiled. Eclipse 3.0 [message #259631 is a reply to message #259518] Thu, 08 July 2004 10:19 Go to previous messageGo to next message
Originally posted by: glongman.intelligentworks.nospam.com
Make sure you have the latest Sysdeo plugin version (3.0 beta?) There's bug
in older versions of Sysdeo that adds TOMCAT_HOME to the build path.
Also, see this bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=64646
Geoff
"Ravi" <mravi@web.de> wrote in message news:ccj1k8$f7q$1@eclipse.org...
> is installed.
> to work.
> Thanx
> Ravi.
moment
> > Ravi wrote:
> >>Hi,
> >>Thanks in advance.
> >>Ravi.
Re: Java files not getting compiled. Eclipse 3.0 [message #259772 is a reply to message #259518] Thu, 08 July 2004 11:58 Go to previous message
As 'G Longman' already posted, you need to remove the "TOMCAT_HOME" line
from your Java Build Path (see Project's properties). After this, all
works as they supposed to do.
This extra line affected only in the current project. Other projects were
OK ... atleast on my computer.
Haven't tested the Sysdeo 3 version yet (it wasn't available at the moment
I installed the Eclipse R3).
Ravi wrote:
> is installed.
> to work.
> Thanx
> Ravi.
> > Ravi wrote:
> >>Hi,
> >>Thanks in advance.
> >>Ravi.
Previous Topic:Worker thread question
Next Topic:How to customize help topics in org.eclipse.help plugin?
Current Time: Tue Nov 18 16:57:41 EST 2025
Powered by FUDForum. Page generated in 0.05359 seconds
