| Java files not getting compiled. Eclipse 3.0 [message #259470] |
Thu, 08 July 2004 01:19  |
Originally posted by: mravi.web.de
I am using Eclipse 3.0. I have a project with src and bin folders. When
I save the java file, it used to be compiled and the class file copied
to bin folder. But all of a sudden, it stopped working. I haven't made
any setting changes.
Where can I enable the autobuild for the java files? Is thr any way to
manually compile each file?
Thanks in advance.
Ravi.
| Re: Java files not getting compiled. Eclipse 3.0 [message #259772 is a reply to message #259518] |
Thu, 08 July 2004 11:58  |
Originally posted by: ramim.kauhajoki.fi
As 'G Longman' already posted, you need to remove the "TOMCAT_HOME" line
from your Java Build Path (see Project's properties). After this, all
works as they supposed to do.
This extra line affected only in the current project. Other projects were
OK ... atleast on my computer.
Haven't tested the Sysdeo 3 version yet (it wasn't available at the moment
I installed the Eclipse R3).
Ravi wrote:
> yeah. I installed Sysdeo tomcat plugin about 3 days back. Haven't
> realised the this automatic compiling stopped working after the plugin
> is installed.
> just let me know in case u remember the changes you have done for this
> to work.
> Thanx
> Ravi.
> noon wrote:
> > I had similar problems when I used the Sysdeo tomcat plug-in. I solved
> > this by removing a line from the Project's Java build path (at the moment
> > I don't recall the line I removed ...).
> > Otherwise the R3 has worked perfectly !! :)
> > Ravi wrote:
> >>Hi,
> >>Thanks in advance.
> >>Ravi.
FUDForum. Page generated in 0.04853 seconds
