Home » Newcomers » Newcomers » Ant editor outline view support for ant-contrib?
Ant editor outline view support for ant-contrib? [message #259443] Fri, 27 June 2008 15:19 Go to next message
Originally posted by: ednotover.gmail.com
Greetings,
I'm new to Eclipse and I'm using it for ant. Many of my build files
make use of ant-contrib (e.g., <if>, <var>, etc.). It does not appear
that the ant editor's outline is aware of the ant-contrib syntax, so the
nice outline support doesn't come into play for, say, property definitions
within an <if>. In my outline view, I just see:
- <> if
. isset
+ <> then
- <> else
. property
There I'm not seeing the representative property icon, and I'm not seeing
the property's name displayed.
Is there a plugin I can use that will add recognition for ant-contrib?
If not, where in the eclipse source should I start looking to make
modifications for this sort of support?
Ed
Re: Ant editor outline view support for ant-contrib? [message #261094 is a reply to message #259443] Mon, 14 July 2008 18:30 Go to previous message
I know of no plug-in that will add ant-contrib support.
If you are interested in adding the support, please log a bug report so we
can all follow/help your progress.
The outline model is based on subclasses of /org.eclipse.ant.ui/Ant Tools
Support/org/eclipse/ant/internal/ui/model/AntElementNode.jav a
Likely you would want to base your implementation off of the
org.eclipse.ant.internal.ui.model.AntPropertyNode.
Sorry for the delay on a response
Darins
http://runnerwhocodes.blogspot.com
"Ed" <ednotover@gmail.com> wrote in message
news:b4f64211c81a19d63f3fa3eda3b52e58$1@www.eclipse.org...
> Greetings,
> - <> if
> . isset
> + <> then
> - <> else
> . property
> Ed
Previous Topic:Searching through my project
Next Topic:Deactivate password dialog at startup
Current Time: Thu Nov 06 22:50:59 EST 2025
Powered by FUDForum. Page generated in 0.08461 seconds
