Home » Archived » BIRT » Dynamic Cross Tab
Dynamic Cross Tab [message #259413] Thu, 25 October 2007 05:16 Go to next message
Hi there
last couple of days i did search and search on how to create cross tab
report Programatically with design engine API.But google couldn't give me
any answer :)
oops.... i even looked into the birt CVS repository.
any help would be great.
Re: Dynamic Cross Tab [message #259486 is a reply to message #259413] Thu, 25 October 2007 10:48 Go to previous messageGo to next message
Raju,
I don't think that we have this in our examples yet. I will try and get
it built today.
If you are inpatient and want to get it sooner, I would recommend having
a look at the BIRT source in CVS. The org.eclipse.birt.report.item.crosstab.core.tests
project has examples of building a Crosstab through code. In particular
if you look at TestEngine.java in the org.eclipse.birt.report.item.crosstab.core.re
package you will find the createCrosstab method.
The test suite is often a little tricky to figure out, but the basics should
be there.
Scott Rosenbaum
> Hi there
> give me any answer :) oops.... i even looked into the birt CVS
> repository.
Re: Dynamic Cross Tab [message #259705 is a reply to message #259486] Sat, 27 October 2007 01:20 Go to previous message
Hi Scott
Thanks for your reply.really grateful to you.
Thanks once again
Previous Topic:problem with exported library on design engine
Next Topic:internationalization Problem
Current Time: Wed Nov 05 19:29:12 EST 2025
Powered by FUDForum. Page generated in 0.03345 seconds
