Home » Archived » BIRT » Using BIRT taglib with custom engine home location
Using BIRT taglib with custom engine home location [message #259409] Thu, 25 October 2007 03:32 Go to next message
Originally posted by: abelo.telecable.es
is there any way to configure BIRT in a webapp for using the taglib with
the engine installed in a custom path?
For example, "C:\birt-runtime-2_1_0\birt-runtime-2_1_0\ReportEngine"
instead of the default "WEB-INF/platform" setup.
Thanks in advance.
Re: Using BIRT taglib with custom engine home location [message #259483 is a reply to message #259409] Thu, 25 October 2007 10:51 Go to previous message
Abel,
I think the only way this is possible is to modify the webviewer code.
If you look at the ReportEngineService.java class there is a method
called setEngineContext. This uses a PlatformServletContext which sets
the WEB-INF/platform directory. You could swap this for a
PlatformFileContext and set BIRT_HOME.
Jason
Abel Pastur wrote:
> Hello,
> Thanks in advance.
Previous Topic:where is the console?
Next Topic:Export Report in webviewer
Current Time: Tue Oct 28 02:29:36 EDT 2025
Powered by FUDForum. Page generated in 0.03328 seconds
