Home » Archived » BIRT » Referring to page number a report item is on
Referring to page number a report item is on [message #259405] Thu, 25 October 2007 03:16 Go to next message
Originally posted by: firstname.lastname.napa.fi
Hi!
Is it possible to somehow refer to the page number a report item is on?
An example of what I'd like to do:
I have a table somewhere in my report. In another part of the report I'd
like to say:
blah, blah, please see table YY on page X.
I'd like to be able to place some javascript snippet in place of X that
would in the render phase be replaced by the page number the referred to
report item is on. I'd need to use this with pdf and word doc output
formats.
In word, this feature is called cross-reference and is trivial to make.
If this is not possible, should I file an enhancement request?
-Antti-
Re: Referring to page number a report item is on [message #259501 is a reply to message #259405] Thu, 25 October 2007 11:51 Go to previous messageGo to next message
Antti,
You may be able to do something with script on the pageBreak event, but
the main issue would be that a table may span multiple pages.
Jason
Antti Karanta wrote:
> Hi!
> I'd like to say:
> that would in the render phase be replaced by the page number the
> referred to report item is on. I'd need to use this with pdf and word
> doc output formats.
> -Antti-
Re: Referring to page number a report item is on [message #259593 is a reply to message #259501] Fri, 26 October 2007 02:48 Go to previous messageGo to next message
On Thu, 25 Oct 2007 18:51:20 +0300, Jason Weathersby
That's not an issue - I'd like to be able to point to a page number the
table (or any other report item, e.g. a text item) starts on. Being able
to get the page it ends on would be a bonus, but not that necessary.
I don't quite get you - pageBreak event of what report item? Do you mean
e.g. a table whose page number I want to know? I would suppose there is no
such event if the table does not span multiple pages?
-Antti-
>> Hi!
>> on?
>> I'd like to say:
>> doc output formats.
>> make.
>> -Antti-
Re: Referring to page number a report item is on [message #259652 is a reply to message #259593] Fri, 26 October 2007 10:59 Go to previous message
Antti,
I was saying you could add a script to each pageBreak event for all
elements. This is not very clean but attached is an example. I still
think this would be a good thing to log a bugzilla enhancement for.
Jason
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.14"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.2.0.v20070620 Build &lt;2.2.0.v20070626-1003></property>
<property name="units">in</property>
<property name="comments">Copyright (c) 2007 &lt;&lt;Your Company
Name here>></property>
<html-property name="description">Creates a blank report with no
predefined content.</html-property>
<method name="beforeFactory"><![CDATA[pn= 1;]]></method>
<text-property name="displayName">Blank Report</text-property>
<property name="iconFile">/templates/blank_report.gif</property>
<data-sources>
<oda-data-source
extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source"
id="6">
<property
name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver </property>
<property name="odaURL">jdbc:classicmodels:sampledb</property>
<property name="odaUser">ClassicModels</property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
name="Data Set" id="7">
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">ORDERNUMBER</property>
<property name="dataType">integer</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">PRODUCTCODE</property>
<property name="dataType">string</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">QUANTITYORDERED</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">PRICEEACH</property>
<property name="dataType">float</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">ORDERLINENUMBER</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<structure>
<property name="nativeName">ORDERNUMBER</property>
<property name="nativeDataType">4</property>
</structure>
<structure>
<property name="nativeName">PRODUCTCODE</property>
<property name="nativeDataType">12</property>
</structure>
<structure>
<property name="nativeName">QUANTITYORDERED</property>
</structure>
<structure>
<property name="nativeName">PRICEEACH</property>
<property name="nativeDataType">8</property>
</structure>
<structure>
<property name="nativeName">ORDERLINENUMBER</property>
<property name="nativeDataType">5</property>
</structure>
</list-property>
<property name="queryText">select *
from orderdetails
</property>
<xml-property name="designerValues"><![CDATA[<?xml
version="1.0" encoding="UTF-8"?>
<model:DesignValues
xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design"
xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>1.0</Version>
<design:ResultSets derivedMetaData="true">
<design:resultSetDefinitions>
<design:resultSetColumns>
<design:resultColumnDefinitions>
<design:attributes>
<design:name>ORDERNUMBER</design:name>
<design:position>1</design:position>
<design:nativeDataTypeCode>4</design:nativeDataTypeCode>
<design:precision>10</design:precision>
<design:scale>0</design:scale>
<design:nullability>Nullable</design:nullability>
</design:attributes>
<design:usageHints>
<design:label>ORDERNUMBER</design:label>
<design:formattingHints>
<design:displaySize>11</design:displaySize>
</design:formattingHints>
</design:usageHints>
</design:resultColumnDefinitions>
<design:attributes>
<design:name>PRODUCTCODE</design:name>
<design:position>2</design:position>
<design:nativeDataTypeCode>12</design:nativeDataTypeCode>
<design:precision>15</design:precision>
<design:usageHints>
<design:label>PRODUCTCODE</design:label>
<design:displaySize>15</design:displaySize>
<design:attributes>
<design:name>QUANTITYORDERED</design:name>
<design:position>3</design:position>
<design:usageHints>
<design:label>QUANTITYORDERED</design:label>
<design:attributes>
<design:name>PRICEEACH</design:name>
<design:position>4</design:position>
<design:nativeDataTypeCode>8</design:nativeDataTypeCode>
<design:usageHints>
<design:label>PRICEEACH</design:label>
<design:displaySize>22</design:displaySize>
<design:attributes>
<design:name>ORDERLINENUMBER</design:name>
<design:position>5</design:position>
<design:nativeDataTypeCode>5</design:nativeDataTypeCode>
<design:precision>5</design:precision>
<design:usageHints>
<design:label>ORDERLINENUMBER</design:label>
<design:displaySize>6</design:displaySize>
</design:resultSetColumns>
</design:resultSetDefinitions>
</design:ResultSets>
</model:DesignValues>]]></xml-property>
</oda-data-set>
<oda-data-set
name="Data Set1" id="99">
<structure>
<property name="name">OFFICECODE</property>
</structure>
<structure>
<property name="name">CITY</property>
</structure>
<structure>
<property name="name">PHONE</property>
</structure>
<structure>
<property name="name">ADDRESSLINE1</property>
</structure>
<structure>
<property name="name">ADDRESSLINE2</property>
</structure>
<structure>
<property name="position">6</property>
<property name="name">STATE</property>
</structure>
<structure>
<property name="position">7</property>
<property name="name">COUNTRY</property>
</structure>
<structure>
<property name="position">8</property>
<property name="name">POSTALCODE</property>
</structure>
<structure>
<property name="position">9</property>
<property name="name">TERRITORY</property>
</structure>
</list-property>
</structure>
<structure>
<property name="nativeName">OFFICECODE</property>
</structure>
<structure>
<property name="nativeName">CITY</property>
</structure>
<structure>
<property name="nativeName">PHONE</property>
</structure>
<structure>
<property name="nativeName">ADDRESSLINE1</property>
</structure>
<structure>
<property name="nativeName">ADDRESSLINE2</property>
</structure>
<structure>
<property name="nativeName">STATE</property>
</structure>
<structure>
<property name="nativeName">COUNTRY</property>
</structure>
<structure>
<property name="nativeName">POSTALCODE</property>
</structure>
<structure>
<property name="nativeName">TERRITORY</property>
</structure>
</list-property>
from offices</property>
<model:DesignValues
<design:attributes>
<design:name>OFFICECODE</design:name>
<design:usageHints>
<design:label>OFFICECODE</design:label>
<design:displaySize>10</design:displaySize>
<design:attributes>
<design:name>CITY</design:name>
<design:precision>50</design:precision>
<design:usageHints>
<design:label>CITY</design:label>
<design:displaySize>50</design:displaySize>
<design:attributes>
<design:name>PHONE</design:name>
<design:usageHints>
<design:label>PHONE</design:label>
<design:attributes>
<design:name>ADDRESSLINE1</design:name>
<design:usageHints>
<design:label>ADDRESSLINE1</design:label>
<design:attributes>
<design:name>ADDRESSLINE2</design:name>
<design:usageHints>
<design:label>ADDRESSLINE2</design:label>
<design:attributes>
<design:name>STATE</design:name>
<design:position>6</design:position>
<design:usageHints>
<design:label>STATE</design:label>
<design:attributes>
<design:name>COUNTRY</design:name>
<design:position>7</design:position>
<design:usageHints>
<design:label>COUNTRY</design:label>
<design:attributes>
<design:name>POSTALCODE</design:name>
<design:position>8</design:position>
<design:usageHints>
<design:label>POSTALCODE</design:label>
<design:attributes>
<design:name>TERRITORY</design:name>
<design:position>9</design:position>
<design:usageHints>
<design:label>TERRITORY</design:label>
</oda-data-set>
</data-sets>
<styles>
<style name="crosstab" id="4">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab-cell" id="5">
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property
name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<grid id="56">
<property name="width">100%</property>
<column id="57"/>
<column id="58"/>
<column id="59"/>
<row id="60">
<cell id="61">
<data id="90">
<list-property name="boundDataColumns">
<structure>
<property name="name">pncount</property>
<expression name="expression">"This
item is on page " + pn;</expression>
</structure>
</list-property>
<property name="resultSetColumn">pncount</property>
</data>
</cell>
<cell id="62"/>
<cell id="63"/>
</row>
<row id="64">
<cell id="65">
<label id="88">
<text-property name="text">Place
Holder</text-property>
</label>
</cell>
<cell id="66"/>
<cell id="67"/>
</row>
<row id="68">
<cell id="69"/>
<cell id="70"/>
<cell id="71"/>
</row>
</grid>
<table id="8">
<property name="dataSet">Data Set</property>
<structure>
<expression
name="expression">dataSetRow["ORDERNUMBER"]</expression >
</structure>
<structure>
<expression
name="expression">dataSetRow["PRODUCTCODE"]</expression >
</structure>
<structure>
<expression
name="expression">dataSetRow["QUANTITYORDERED"]</expression >
</structure>
<structure>
<expression
name="expression">dataSetRow["PRICEEACH"]</expression>
</structure>
<structure>
<expression
name="expression">dataSetRow["ORDERLINENUMBER"]</expression >
</structure>
<structure>
<expression name="expression">"This item is on page
<property name="dataType">any</property>
</structure>
<structure>
<property name="name">pnfinal</property>
<expression name="expression">"This element ends on
</structure>
</list-property>
<method name="onPageBreak"><![CDATA[pn = pn+1;]]></method>
<column id="37"/>
<column id="38"/>
<column id="39"/>
<column id="40"/>
<column id="41"/>
<header>
<row id="91">
<cell id="92">
<data id="97">
<property
</data>
</cell>
<cell id="93"/>
<cell id="94"/>
<cell id="95"/>
<cell id="96"/>
</row>
<row id="9">
<cell id="10">
<label id="11">
<text-property
name="text">ORDERNUMBER</text-property>
</label>
</cell>
<cell id="12">
<label id="13">
<text-property
name="text">PRODUCTCODE</text-property>
</label>
</cell>
<cell id="14">
<label id="15">
<text-property
name="text">QUANTITYORDERED</text-property>
</label>
</cell>
<cell id="16">
<label id="17">
<text-property
name="text">PRICEEACH</text-property>
</label>
</cell>
<cell id="18">
<label id="19">
<text-property
name="text">ORDERLINENUMBER</text-property>
</label>
</cell>
</row>
</header>
<group id="42">
<property name="groupName">NewTableGroup1</property>
<property name="interval">none</property>
<property name="sortDirection">asc</property>
<expression name="keyExpr">row["ORDERNUMBER"]</expression>
<structure name="toc">
<expression
name="expressionValue">row["ORDERNUMBER"]</expression>
</structure>
<property name="repeatHeader">true</property>
<property name="hideDetail">false</property>
<property
name="pageBreakAfter">always-excluding-last</property>
<property name="pageBreakBefore">auto</property>
<property name="pageBreakInside">auto</property>
<header>
<row id="43">
<cell id="44">
<data id="55">
<property
name="resultSetColumn">ORDERNUMBER</property>
</data>
</cell>
<cell id="45"/>
<cell id="46"/>
<cell id="47"/>
<cell id="48"/>
</row>
</header>
<footer>
<row id="49">
<cell id="50"/>
<cell id="51"/>
<cell id="52"/>
<cell id="53"/>
<cell id="54"/>
</row>
</footer>
</group>
<detail>
<row id="20">
<cell id="21"/>
<cell id="23">
<data id="24">
<property
name="resultSetColumn">PRODUCTCODE</property>
</data>
</cell>
<cell id="25">
<data id="26">
<property
name="resultSetColumn">QUANTITYORDERED</property>
</data>
</cell>
<cell id="27">
<data id="28">
<property
name="resultSetColumn">PRICEEACH</property>
</data>
</cell>
<cell id="29">
<data id="30">
<property
name="resultSetColumn">ORDERLINENUMBER</property>
</data>
</cell>
</row>
</detail>
<footer>
<row id="31">
<cell id="32">
<data id="165">
<property
name="resultSetColumn">pnfinal</property>
</data>
</cell>
<cell id="33"/>
<cell id="34"/>
<cell id="35"/>
<cell id="36"/>
</row>
</footer>
</table>
<grid id="72">
<column id="73"/>
<column id="74"/>
<column id="75"/>
<row id="76">
<cell id="77">
<data id="98">
<structure>
<property name="name">pncnt</property>
</structure>
</list-property>
<property name="resultSetColumn">pncnt</property>
</data>
</cell>
<cell id="78"/>
<cell id="79"/>
</row>
<row id="80">
<cell id="81">
<label id="89">
</label>
</cell>
<cell id="82"/>
<cell id="83"/>
</row>
<row id="84">
<cell id="85"/>
<cell id="86"/>
<cell id="87"/>
</row>
</grid>
<table id="100">
<property name="dataSet">Data Set1</property>
<structure>
<expression
name="expression">dataSetRow["OFFICECODE"]</expression>
</structure>
<structure>
<expression
name="expression">dataSetRow["CITY"]</expression>
</structure>
<structure>
<expression
name="expression">dataSetRow["PHONE"]</expression>
</structure>
<structure>
<expression
name="expression">dataSetRow["ADDRESSLINE1"]</expression >
</structure>
<structure>
<expression
name="expression">dataSetRow["ADDRESSLINE2"]</expression >
</structure>
<structure>
<expression
name="expression">dataSetRow["STATE"]</expression>
</structure>
<structure>
<expression
name="expression">dataSetRow["COUNTRY"]</expression>
</structure>
<structure>
<expression
name="expression">dataSetRow["POSTALCODE"]</expression>
</structure>
<structure>
<expression
name="expression">dataSetRow["TERRITORY"]</expression>
</structure>
<structure>
</structure>
</list-property>
<column id="149"/>
<column id="150"/>
<column id="154"/>
<column id="155"/>
<column id="157"/>
<header>
<row id="158">
<cell id="159">
<data id="164">
<property
</data>
</cell>
<cell id="160"/>
<cell id="161"/>
<cell id="162"/>
<cell id="163"/>
</row>
<row id="101">
<cell id="102">
<label id="103">
<text-property
name="text">OFFICECODE</text-property>
</label>
</cell>
<cell id="104">
<label id="105">
<text-property name="text">CITY</text-property>
</label>
</cell>
<cell id="112">
<label id="113">
<text-property
name="text">STATE</text-property>
</label>
</cell>
<cell id="114">
<label id="115">
<text-property
name="text">COUNTRY</text-property>
</label>
</cell>
<cell id="118">
<label id="119">
<text-property
name="text">TERRITORY</text-property>
</label>
</cell>
</row>
</header>
<detail>
<row id="120">
<cell id="121">
<data id="122">
<property
name="resultSetColumn">OFFICECODE</property>
</data>
</cell>
<cell id="123">
<data id="124">
<property
name="resultSetColumn">CITY</property>
</data>
</cell>
<cell id="131">
<data id="132">
<property
name="resultSetColumn">STATE</property>
</data>
</cell>
<cell id="133">
<data id="134">
<property
name="resultSetColumn">COUNTRY</property>
</data>
</cell>
<cell id="137">
<data id="138">
<property
name="resultSetColumn">TERRITORY</property>
</data>
</cell>
</row>
</detail>
<footer>
<row id="139">
<cell id="140"/>
<cell id="141"/>
<cell id="145"/>
<cell id="146"/>
<cell id="148"/>
</row>
</footer>
</table>
</body>
</report>
>> but the main issue would be that a table may span multiple pages.
> the table (or any other report item, e.g. a text item) starts on. Being
> able to get the page it ends on would be a bonus, but not that necessary.
> mean e.g. a table whose page number I want to know? I would suppose
> there is no such event if the table does not span multiple pages?
> -Antti-
>>> Hi!
>>> is on?
>>> report I'd like to say:
>>> doc output formats.
>>> make.
>>> -Antti-
Previous Topic:Runtime Hangs with frameset
Next Topic:BIRT - reusable component
Current Time: Thu Nov 06 17:26:30 EST 2025
Powered by FUDForum. Page generated in 0.03826 seconds
