Home » Eclipse Projects » Eclipse Platform » RCP and Java Web Start
RCP and Java Web Start [message #259385] Wed, 07 July 2004 16:12 Go to next message
Originally posted by: noreply.noreply.com
I recently built a handful of SWT/JFace applications that I distribute
through java web start. I took a somewhat successful stab at converting
them into the RCP, but I would also like to distribute that through java
web start rather than through installers. I was wondering if anyone had
any luck, suggestions, or advice?
Thanks...
Re: RCP and Java Web Start [message #259569 is a reply to message #259385] Thu, 08 July 2004 07:22 Go to previous message
Originally posted by: pascal.ibm.canada
There are some difficulties with doing that because the startup sequence
makes assumptions about some directory names (for example plugins) to
find the plugins specified on the osgi.bundles list.
I'm trying to find way around that by using jnlp installers but I
haven't found a perfect solution yet.
There is a bug report about that in the equinox section.
PaScaL
> distribute through java web start. I took a somewhat successful stab at
> converting them into the RCP, but I would also like to distribute that
> through java web start rather than through installers. I was wondering
> if anyone had any luck, suggestions, or advice?
> Thanks...
Previous Topic:Calling a dll changed in 3.0 final
Next Topic:Multiuser configuration
Current Time: Tue Nov 11 10:52:23 EST 2025
Powered by FUDForum. Page generated in 0.18799 seconds
